Old 03-21-2008, 08:08 PM   #1 (permalink)
Chyna Black's Avatar
John
Front dampner/spring question.
What is the correct way of removing the front spring from the shock?
Chyna Black is offline   Reply With Quote
Old 03-21-2008, 08:18 PM   #2 (permalink)
Removal
1. Turn the ignition switch ON (II), then turn on the windshield wipers. Turn the ignition switch off when the wipers are near the A-pillars.
2. Raise the front of the vehicle, and support it with safety stands in the proper locations.
3. Remove the front wheel.
4. Remove the wheel sensor harness clip (A) and the brake hose bracket (B) from the damper. Do not disconnect the wheel sensor connector.
5. Remove the damper pinch bolts (A) and self-locking nuts (B) from the damper.
6. Remove the service cap (A) and the lid (B).
7. Remove the three flange nuts (C) from the top of the damper.
NOTEamper springs are different, left and right. Mark the springs L and R before you continue.
Be careful not to damage the body.
8. Remove the damper assembly (A).
Thne insert the housing into a spring compressor and remove..
Old 03-21-2008, 08:25 PM   #3 (permalink)
John
I followed the DYI, how do I get the dampner off? I would not have asked the question if I guess I should have asked question better!
Old 03-21-2008, 08:27 PM   #4 (permalink)
No..My bad, I suggest a spring compressor to remove springs. Most say its not needed, although its added security.
For 23 bucks why not...MACPHERSON STRUT COIL SPRING COMPRESSORS - JCWhitney Auto Parts
Old 03-21-2008, 08:34 PM   #5 (permalink)
John
I have a spring compressor, just trying to figure out how to remove spring from dampner. I would imagine I compress spring on the outside, the remove bolt from top; slowly uncompress spring?
Old 03-21-2008, 08:36 PM   #6 (permalink)
Yeah..Once off the car slowly uncompress the spring take the pressure off the top hat . MOST lowering springs dont need a compressor to install..
Old 03-21-2008, 08:43 PM   #7 (permalink)
John
Damn, okay right now I have everything off the car, do I need to put strut back in to remove dampner? Or can I removethe dampner with it off the car?
Old 03-21-2008, 08:55 PM   #8 (permalink)
Louder than 4 F404-GE-400
Paul
You need an offest wrench with a hole in the top.
The offest wrench goes around the nut.
An allen wrench goes in the shaft to keep it from spinning.
Then loosen the nut.
Old 03-21-2008, 09:01 PM   #9 (permalink)
John
Cool I am pressing on then, not trying to kill myself; I would hate to be the only one I know to go out with a spring in my a$$! Thanks for patience and help!
Old 03-23-2008, 07:10 AM   #10 (permalink)
John
Thanks for all the help, springs are on!
Old 03-23-2008, 07:35 AM   #11 (permalink)
Jardiniboy's Avatar
Jasten
Post some pictures. What springs do you choose to use?
Front Spring/Damper Removal/Install Highrev1 Suspension and Brakes 32 10-05-2008 12:09 AM
torque dampner dnbsi Bolt-Ons And All-Motor 4 11-30-2007 11:44 AM
Ingalls torque dampner question anavrin351 Mechanical Problems & Technical Chat 0 11-10-2007 10:02 PM
Front Spring Install / Noise problem found unplugged Suspension and Brakes 0 04-06-2007 04:34 PM
