#21 (permalink) |
I tryed this combo and ther rear shocks will blow just like the stock ones in time.. the valving is real close to the HFP.. Im not a huge fan of the pro kits.. the rear drop is to much IMO.. If you have blown out stock shocks and already have pro kits.. I say get the tok blues... its a nice set up.. im not sure how long you will get out of the rears... but they should be good for 30-40K miles.. if you are shopping.. I say go HFP.. its by far the best performance combo around.. then get some front camber bolts and call it a day... with a progress rear bar and HFP's with a good aliment.. you are looking at one hell of a ride... it you want lower then HFP the tok-pro kit combo will be a nice set up.. just rember it needs rear camber arms is you want ok tire life and better then stock performance
#22 (permalink) | |
#23 (permalink) |
Stiffer does not always equal better. You actually want to run the softest springs you can while still keeping body roll in a minimum. If the springs are too stuff the tire can lose contact w/the ground, and a tire that's not touching the ground isn't doing you any good!
#24 (permalink) |
I don't want HFP. I don't like the stance it gives. I have the pro-kits on stock shocks and I can tell you with absolute certainty that my car handles better. The turn in response is way better and there is way less understeer at high speeds. I used to get front end push on off ramps even in the summer when the tires get to operating temps much better and my car handles better now in the freezing cold better than before. I haven't added the Tokicos yet and I'm still waiting to order the rear sway bar. After that it should be even better. I hope.
#25 (permalink) | |
). Still pushes some, but I'm hoping that once I get a bigger rear sway bar it'll be more neutral. I'm not getting the Tokico's though, I'm waiting till the Koni's come out.
#26 (permalink) | |
#27 (permalink) |
I've got about -1.5 up front and -1.5 in the rear. I wanted -1.0 in the rear, but the shop said that was the best they could do. Toe is pretty neutral all the way around. I definetly want better tires....I'm still on the stock all season's. But they're staying on 'till they're wore out, then I'm going to try some Azenis I think.
#29 (permalink) |
More proof that these shocks are covered under lifetime warranty when paired up with lowering springs, I think most of you would be happy with the progress drop.
"Thank you for contacting Tokico Performance Products. The HP series is a great choice for the Civic and will definitely handle the drop you're doing. Very smart of you to be thinking about this. Most people lower their cars and don't think twice about their shocks. OE shocks are not designed to handle modifications such as larger wheels and lowering. HP series are stiffer than OE and also designed to handle the extra stress put on by these modifications. Our products are covered under warranty as long as they were installed properly and not used with excessive lowering (3+ inch drop etc.) The springs you are using will be perfect. If you have any questions, feel free to contact me. Thank you, David David Chou HITACHI Automotive Products (USA), Inc. TOKICO PERFORMANCE SHOCKS 550 West Artesia Blvd. Compton, CA 90220 P: 562-295-2513 F: 310-212-0222 Web: Tokico Gas Shocks " |
#30 (permalink) |
I don't know if some of you are new to modding, but Tokico Blues have been available for tons of cars over the years and many people have paired them up with lowering springs so they don't blow their shocks with lowering springs. They're nothing new, they're proven to do their job, which is what 90% of you are looking for.
I don't know why people think that the 8th gen civic is so special that ONLY the factory lowering kit will work perfectly. Admit it or not, MOST of you are only concerned with the lowered look and I bet few of you can tell the difference or care that your handling is that much better than stock. Anything 1.5 inches or lower is such a mild drop, I don't know why you all get your panties up in a bunch over something like that, the blues work fine. You don't need to waste your money on fancy Konis/Teins/Zeal, if all you want to do is bring your groceries home in a lowered stance and impress the girls as you drive up and down the boulevard on a Friday night. EVEN if you do some occasional auto-x and lapping, a fancy suspension isn't going to help you as much as some racing lessons will. I hate it when people get burnt on the track and they go out and buy another new suspension, face it, you suck at the moment, practice or read a book or something. |
#31 (permalink) | |
I want to wait for the Koni's to come out because that's clearly going to be a better shock, but I really don't know how much to expect to pay for those. |
#32 (permalink) | |
Existing Yellows for other cars go from 449 - 649, so when the ones for the FG eventually come out, 500 is a good guess - existing Yellows for other Civics are like 530. |
#33 (permalink) | |
#34 (permalink) |
Louder than 4 F404-GE-400
I think they are going to be a lot closer to $750. The RSX sports are 729 for the set on Koni's web site and they are inserts which is what Koni said they would have to do for our cars. You can't base any price on the old hondas because they had a completely different suspension in which dampers are cheaper because they are not a weight supporting member of the suspension.
You know what the sun's all about when the light go out. |
#35 (permalink) | |
#36 (permalink) | |
![]() Well said bro. I just can't believe how many people think the HFP is the only suspension that will improve your handling. And I'll tell you this, my boy has the HFP on his 08 coupe and I'm running pro-kit with stock shocks. My car rides so much softer and smoother on harsh roads. That HFP is spine crushing stiff. I don't like it at all and he isn't any faster than me in the twisties.
#37 (permalink) | |
#38 (permalink) | |
#39 (permalink) |
8thcivic Sponsor
You can get the TOKICO's for less than that. In fact, we have them for $400 shipped to the cont US and we have them in stock. The front shock is going to be where the cost is and I would venture to say the KONI setup is going to be about $700-$800 shipped to the end consumer, with a discount. Yes the KONI Yellow is going to be a better shock but you have to compare apples to apples. The KONI STR is comparable to the TOKICO HP. The TOKICO Illumina or D-Spec would be closer to the KONI Yellow.
I agree with RX_AGENT; TOKICO HP's are a great shock for a lowering spring that isn't too aggressive.
EXCELERATE PERFORMANCE - Your Official 8thCivic Vendor and Honda Performance Parts Specialist!! See our CT Engineering, ROTORA, Injen, TEIN, TOKICO, Random Technology, AEM, KAIXEN HID, Unorthodox Racing, P2R, Buddy Club, Innovative Mounts, and K Sport Sales at The Sponsored Posting Forum by Excelerate Performance NEW WEB STORE: Store.ExceleratePerformance.com AIM: Excelerate04 Phone: 203-483-6100 http://www.ExceleratePerformance.com |
| Eibach pro kit Vs Comptech springs | 1cleanfg2 | Suspension and Brakes | 41 | 03-28-2008 02:51 PM |
| SI sedan hfp supension vs tokico blues + eibach pro kit | malditoron | Suspension and Brakes | 23 | 03-11-2008 09:13 PM |
| EIBACH Pro-Kit Springs | Hondacivicsi23 | Suspension and Brakes | 1 | 06-25-2007 04:37 PM |
| Are eibach pro kit good springs? | Civic Pride | Suspension and Brakes | 7 | 01-28-2007 08:38 PM |
| Springs - Progress or Eibach Pro-kit | bhoy | Suspension and Brakes | 13 | 12-16-2006 05:59 AM |
