brake rotor diameter
can someone point me to where I can find specs of brake rotors to all US honda vehicles minus the motorcycles??? Planning on upgrading my Si rotors to a much bigger one but don't want slotted or dimpled or drilled rotors just want them bigger.
#2 (permalink) | |
Why do you want them bigger. They are big enough, unless you want the "look". Added weight and weight distribution of larger rotors will slow down the acceleration of your car. My 98 eclipse GSX had 10 3/4" rotors up front with 2 piston calipers and they worked great on a 3150lb car. However, the 10 1/4" rotors with single piston calipers on the GS-T models(FWD) were severely weak and faded very rapidly. To save money if you were looking for better heat dissipation, you could go with a cross drilled/slotted rotor. Slotted only is not really worth it IMO. If you go with a much bigger rotor, you may need a bigger caliper too putting you in the $1-2K range. They make kits with larger rotors with caliper extender brackets too. But again, on our cars, the brakes are quite sufficient for most peeps. Good Luck. Type in big Brakes civic Si in the google search for some ideas |
#6 (permalink) | |
To further answer you question ... there is no one database of rotor sizes ... WHY, because the size is somewhat irrelevent, because a large rotors from XXX car may (probabaly) not bolt up to any other car than what it was designed for. There is to many other variables. -Rotor diameter -Rotor bolt pattern -Rotor hub-bore -Rotor thickness -Rotor offset (distance from hub to friction surface) -Caliper offset -Caliper bolt pattern -Caliper "mouth" size All these will impact if a rotor will bolt up, and will a specifc caliper and pd work with this new combination This is proven in the knowledge base of brake upgrades for the 88-00 Civics ...when you increase the size of the rotor you invariably have to swap the rotor, caliper AND Knuckle to get it to work ... and in somecases custom machining is required anyways If you read this stickied article you will have a better idea of what options are avaiable to you, both OE and aftermarket. Brake options Moose Last edited by Moose; 03-13-2008 at 05:31 PM. |
#7 (permalink) | |
If anyone is looking for a quick upgrade to the stock brakes for trackdays and the like, you could always switch to a higher temp racing compound. Cheaper and more effective than randomly applying different parts to the brake system. |
| Brake options | Moose | Suspension and Brakes | 386 | 10-10-2008 04:46 PM |
| DIY Front Brake Pads | 60103 | Suspension | 11 | 08-27-2008 09:46 PM |
| ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only | Excelerate | Excelerate Performance | 41 | 02-07-2008 04:09 PM |
| DIY Parking Brake Adjustment | 60103 | Do It Yourself Articles | 4 | 09-25-2007 03:42 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 3 | 12-07-2006 01:59 AM |
