EX STRUTS AND SPRINGS AND DAMPENERS on LX???
Is it possible to install the EX springs and struts on a LX? I have an LX and would also like to know what’s the different from the Ex and LX suspension? Is there a benefit to do this swap? I saw this on ebay and if there a benefit, I might consider doing it.
http://cgi.ebay.com/ebaymotors/2006-...69149923QQrdZ1 |
The 2DR EX and LX use the exact same damper and spring.
The 2DR DX uses the Si damper with the EX/LX spring The Si has uses the damper common to DX with an exclusive higher rate spring. If you want to swap something get DX struts, if you put Si struts on an LX you will raise your ride height +10mm. -SWRT |
#7 (permalink) | |
Webby's Minion
