Old 02-28-2008, 10:15 PM   #1 (permalink)
Jan Guzman
Eibach Pro Kit. Need Camber Kit?
well i have both parts ready to be installed. i'm just wondering if i really do need the camber kit. i read through some threads with people that have pro kits without the camber kit because they said its not needed. no tire wear. is this true?
Hi-ReV is offline   Reply With Quote
Old 02-28-2008, 10:26 PM   #2 (permalink)
Your really killing my Highrev NAME ALignment sticky at the top of the page...OR JUST IM or PM ME!!! Sorry I took a minute for this last question...
Since the same question is reposted about 5 times a day I thought I would repost my own information. Its a repost lets see how long it stays
WHEN TO USE CAMBER KITS?/DO I NEED A CAMBER KIT? YES!!!!
The real answer is its up to you. Do you want to handle better, reduce tire wear or have real control over your suspension?
ALIGNMENTS!!
IN ORDER TO CHANGE CAMBER YOU WILL NEED A FRONT AND REAR CAMBER KIT!!!!!
Well you guys spend alot of money on your suspension parts right. Then you go right back to the OEM alignment which uh sucks. That alignment is not for performance. It is strickly to make tires last and make sure your car understeers. Both of those things don't make a car turn well. You will need a set or 2 of front camber bolts, and a rear camber kit to adjust camber.
Old 02-28-2008, 10:30 PM   #3 (permalink)
t('.'t )
m1k3's Avatar
i didnt get a rear camber kit for my LX on prokits
i got it aligned though and they said it would be fine..
looks and drives just fine.
06 FG1 LX MT
AEM CAI | Magnaflow Cat-Back | Comptech SS | TWM Bushings | Eibach Prokit | Enkei Evo 6
m1k3 is offline   Reply With Quote
Old 02-28-2008, 10:39 PM   #4 (permalink)
I had an Eibach Pro Kit on my wife's '07 SI. It looked great. I would definitely look into getting a camber kit. The front wont be too bad but the rear will really lean in. Also plan on a much stiffer ride(with any lowering spring). I actually ended up taking them back off because I was afraid my wife was going to hit a bump too hard and tear something up.
JesseJames is offline   Reply With Quote
Old 02-28-2008, 10:41 PM   #5 (permalink)
You're crazy if you don't get an alignment. I waited a week and a half and could already see tire wear. I had tow like a b#$ch!
Old 02-28-2008, 11:00 PM   #6 (permalink)
slicknick's Avatar
I had the HFP on my FG2, which is roughly same drop (1") as the pro-kit and they said it was within factory specs.
slicknick is offline   Reply With Quote
Old 02-28-2008, 11:01 PM   #7 (permalink)
Civic Pride's Avatar
he did.
Civic Pride is offline   Reply With Quote
Old 02-29-2008, 12:09 AM   #8 (permalink)
If you want to handle well, and have even tire wear a camber kit is necessary whether you are lowered or not. I got my spc kit months before I bolted on the HFP parts.
CanyonDriver is offline   Reply With Quote
Old 02-29-2008, 12:14 AM   #9 (permalink)
You're going to hear this more than once if you keep continuing the path you've chosen..
PLEASE SEARCH!! I cannot stress this enough!
When To Use Camber Kits?/do I Need A Camber Kit?
Tires, Camber, Caster, Toe!!!
Suspensions!!!
All written by the ONE and ONLY HIGHREV!
That should be enough bedtime reading for you.
eXTCspeed is offline   Reply With Quote
Old 02-29-2008, 12:17 AM   #10 (permalink)
Suspensions!!!
i respond to overkill questions on nights like this when i'm bored. Tonight is one of those nights...
Old 02-29-2008, 01:35 AM   #11 (permalink)
Jan Guzman
people, im just saying if i need it or not because other people said there won't be any wear on the tires. the reason why i got the camber kit was cause of that. thats all.
Old 02-29-2008, 01:49 AM   #12 (permalink)
Jan Guzman
Suspensions!!!
Old 02-29-2008, 01:51 AM   #13 (permalink)
If its just for camber correction then no U probably dont NEED them...
Old 02-29-2008, 09:34 AM   #14 (permalink)
I have a 4 door with the pro kit. I also installed front and rear camber kits. Alignment cannot be right without them. The car handles much better with a proper alignment and you will not be disappointed.
mwinters601 is offline   Reply With Quote
Eibach Pro Kit Install Help in Phoenix Tigger1 Suspension and Brakes 3 06-12-2006 12:20 PM
Eibach pro kit pictures pigman Garage 11 05-13-2006 11:54 AM
Honda Civic Si On Eibach Pro Kit nindoo Garage 13 10-28-2005 05:56 AM
