Old 05-28-2006, 04:36 PM   #1 (permalink)
S-Tech or Sportlines?
The time has come for the drop. I just received an extra 500 bucks at work for pretty much no reason. To celebrate in gonna blow it on a mod I have HFP 18's and I want a nice low drop to make an aggressive stance, but I was concerned that the Sportlines might rub? Any advice?
Hndasiguy is offline   Reply With Quote
Old 05-28-2006, 06:32 PM   #2 (permalink)
the drop of the stechs and the sportlines are pretty much identical, and someone i know has tein stech springs with 18x8.5 rims with out rubbing
subieguy83 is offline   Reply With Quote
Old 05-28-2006, 07:14 PM   #3 (permalink)
Tim
Super Moderator
Tim's Avatar
with what offset though?
Tim is offline   Reply With Quote
Old 05-28-2006, 09:03 PM   #4 (permalink)
it was +48 offset
5 Zigen FNO1RC rims. 18x8.5 +48 offset Bronze. Wrapped in Nitto Neo Gen 225/40/18
http://www.fgcoupe.com/forum/showthr...t=showstoppers
Old 05-28-2006, 10:43 PM   #5 (permalink)
Tim
Super Moderator
Tim's Avatar
I fitted a 215/40-18 to an 18 x 8 wheel with a 35 offset on a Sportline drop, and the wheel store said that I probably could go up to a 225/40 without any problems. 225 tires might look a little pinched on that wide of a wheel. But I'm going to venture to say that it should fit fine. Is there any way you can test fit it before buying?
Old 05-28-2006, 10:53 PM   #6 (permalink)
so then the factory HFP wheels should be fine without rubbing i take it?
Old 05-28-2006, 11:07 PM   #7 (permalink)
Tim
Super Moderator
Tim's Avatar
uh huh
Old 05-29-2006, 12:01 AM   #8 (permalink)
good stuff thanks!
Old 05-29-2006, 05:55 PM   #9 (permalink)
I would go with the lowering spring that has the closest to stock spring rate.
Unless you enjoy bouncing. Also the stock struts will last longer with a less agressive spring rate. Plan on a camber kit for the rear too, I am not saying that you have to have one but if you want decent tire life it's requisite.
shawn
sbmon is offline   Reply With Quote
H tech or S tech?? ahslimjim Suspension and Brakes 25 03-30-2007 03:02 PM
post pictures of sportlines pdiddy2386 Wheel And Tire Upgrades 9 07-23-2006 05:36 AM
New Artsy Pics with Eibach Sportlines larryd Introduction & Pictures 19 05-30-2006 12:14 AM
sportlines and 18's pdiddy2386 Suspension and Brakes 2 05-19-2006 12:25 AM
anyone have any interest in honda tech shirt/pants webby Garage 4 03-03-2006 02:32 PM
