08 Si suspension on a 07 Ex ?
I have a 08 Si sedan and I`m looking to install HFP supension on it .Can I install my Si suspension on my wifes 07 Ex sedan with out any major issues ?Will I need to up grade the sway bar or install a rear sway bar ?
#6 (permalink) | |
no, sooo not true. everything will be affected. here is a pic of my family member's EX on my old Si springs. the front end is very loose now. the height was raised. handlingwise, its not much better. Because the stock EX springs makes the front stick better i think stockers will give you more handling than Si. im going back to the stock EX springs soon. Remember, Si is couple hundred pounds heavier than EX. my opinion, Dont do it.
#7 (permalink) | |
#8 (permalink) | |
The Si is a heavier car. The light EX doesn't push down on them as much. So they are higher not lower. |
#9 (permalink) | |
I only changed out my EX rear springs for Si springs and the car is soo much better. With Si rear sway bar it should be even tighter. If the weather clears up this week I will swap the front springs and we'll see if that makes it worse..????
#10 (permalink) | |
and to the OP Si engines do weigh significantly more. that is one of the reasons some autocrossers race with a Lx, not Si. even if you swap the springs and struts, they are still made for a heavier front end. just my opinion... |
#11 (permalink) |
The Si is heavier and the springs will reflect that. At the same time the stock Si suspension is a PACKAGE. The components were designed to work together, especially the spring/damper combo. The EX or LX dampers will not have stiff enough damping to control the extra force created by the stiffer springs of the Si, especially in rebound. This would be felt as a "loose" or severely underdamped condition in almost all suspension modes. Roll is probably the one you will be the most sensitive you when talking about handling in the twisties. The car will feel like it kind of rolls back and forth just a little bit when you first point the car in, its a very unsettling feeling as the car never seems to "plant" in the corner.
Add in the fact that the Si is heavier and you have effectively increased the natural frequency (which can be thought of as how fast something would vibrate if it didn't have any friction) of your EX above that of the Si. Essentially, your car is now "stiffer" than the Si. With a slightly different weight distribution you would probably notice more "pogo-ing" of the suspension over washboards or expansion joints. Without also swapping over the anti-roll bars of the Si, you will severely alter the roll moment distribution of the vehicle and therefore all aspects of its handling from intitial turn-in, to mid-corner, to exit. To put it simply you car will probably feel "tight" but the ride will be harsh and bouncy, and handling will be compromised. I wouldn't be surprised if it would end up less balanced than a stock EX. just my .02 |
#12 (permalink) |
Joey
Short answer: Parts will fit.
Long Answer: I would not recommend doing it. You will compromise handling! There is a reason Honda Engineered different HFP suspensions for following: Si Sedan, Si Coupe, EX/LX Coupe AT, EX/X Sedan AT, EX/LX Coupe MT, EX/X Sedan MT. Chaning only 1/2 of the suspension, especially with one which is not designed for the trim level, is just crazy. |
#13 (permalink) | |
Untill we get a complete chart of the spring weights and lengths along with shock rates - we can only assume the theory of stiffer springs is better. I know that just rear only Si springs on my Ex auto trans has improved the car greatly. Within a few days we will know if the Si front springs makes it better or worse. trial by fire |
#15 (permalink) |
^ Thats what everyone has been talking about.
Si shock is designed for a SI EX shock is designed for an EX As previously mentioned: "Long Answer: I would not recommend doing it. You will compromise handling! There is a reason Honda Engineered different HFP suspensions for following: Si Sedan, Si Coupe, EX/LX Coupe AT, EX/X Sedan AT, EX/LX Coupe MT, EX/X Sedan MT." i think Xtreme Thunder pretty much put it in the right words |
#16 (permalink) | ||
I think if you re-read most of the thread people are talking about changing springs only. |
#17 (permalink) | |
We really don't know if or how much of a difference there is between the shocks and springs on the HFPs. So I don't buy into the threory of only honda HFP kits will work correctly. After all isn't Honda that simple stuffed a fatter sway bar on the sedan and kept all other parts the same on the coupe? Then on the Dx verse Ex all they did was stick a sway bar on the car. To the OP. If you can just install the rear springs and take it for a test drive. I am pleased with my car with only the rear Si springs. Then you can try the Si front springs. |
#18 (permalink) |
I think the real point was to be that the HFP suspension is designed to work together, and the standard EX,LX,DX,Si suspensions were designed to work together.
You say they simply stuffed a fatter antiroll bar and called it a day, which is far from the truth. A lot of testing and tuning went into that decision and you have no idea of knowing what else they tried before deciding on that antiroll bar rate. Could be they trie 100 other options but in the end it was that "simple" change that best met their requirements, which does include some compromise leaning toward safety and ride comfort. Can you mix and match? You bet your @ss you can, but if you don't understand the complex interactions of springs, dampers, roll bars, weight distribution, tires, and alignment you could very well end up back on here in a couple of weeks complaining about how your car doesn't handle as well as it used to. Or you could get lucky and it makes an improvement. The most important thing when modifying your suspension is to understand the effect it will have on vehicle balance and road compliance, don't forget that the whole point of the suspension is to keep those little black things in contact with the road at all times. |
#19 (permalink) | ||||||
Joey
Just because the car is stiff does not mean it is handling better. Maybe it is stiffer and skating across the road? Quote:
I really hope you don't think they are just slapping stuff on these cars. Quote:
Someone who understands the way things work and designed.
#20 (permalink) | |
Also the Ex only difference is the addition of a rear sway bar - over the Dx/Lx. |
| Which suspension best for Sedan: Si Coupe Suspension or HFP? | mikeymike | Suspension and Brakes | 16 | 04-06-2008 02:08 PM |
| 1999ish Integra Type R suspension vs. HFP suspension | Illinoisone | Suspension and Brakes | 3 | 02-09-2008 10:05 PM |
| RSX suspension vs. Civic Suspension | DarkFlareon | Suspension and Brakes | 15 | 08-08-2007 08:47 PM |
| are sedan suspension and coupe suspension interchangeable? | iqbbang | Suspension and Brakes | 0 | 05-27-2007 07:59 PM |
