280whp, 219tq, GReddy FTW
My Si has 500 miles on it, and the rear rotors STILL have the factory grooves in them; The rear brakes, it seems, contribute hardly anything to the overall stopping power of the vehicle. I knew this already, but DAMN! They've still got the rust spots on them from getting rained on before I bought the car! I burned those off the FRONT rotors after like 10 miles!
If you must whine about my Avatar, do it in this thread: http://www.8thcivic.com/forums/showthread.php?t=35167 |
Do you guys want to know how to get them off really quick???
Drive to about 60mph, then slightly pull up on your E-Brake, thats how i got the spots and grooves off mine, they disapear really quick. NOTE: Dont do this alot, its not that good for your car, and don't yank up on the E-Brake really hard either, this can cause a serious loss of control. |
I Like Cheese
Done quite a bit of brake and suspension repair back in day. No matter if you have discs in the front and drums in the back, or all discs, or all drums. The front brakes will do about 80% of your normal stopping. That would explain why your rear brakes still look so new and why rust spots don't come off.
On a second note, I've never owned a car with 4 wheel disc. My question is this... Can you rotate the rotors like you rotate tires? If so then you can you switch your rotors after you fronts get worn down some? |
I Like Cheese
I figured it wouldn't be that easy. They coulda just just made them the same size and made life easier. Keep rotating them every 10,000 miles or so. It would take you quite some time before you actually had to change them.
#10 (permalink) |
Anyway, removing your rotor isn't user friendly as let's say, changing your wheels.
Your front rotor should last you at least 50 000 miles anyway. You will change your pads before the rotor. Rotors cost less than 100$ each anyway... It's not like it was in the 4 digits. Something nice to do would be changing the rear drums for disc if you have a LX/DX. |
#12 (permalink) | |
I Like Cheese
#13 (permalink) | |
Front rotors are usually bigger or equal to the rear because the fronts have the weight transfered to them when decelerating/braking.
- Mark 2008 Honda Civic SI (stock) 2006 Honda Civic EX (sold) |
| rear speakers removed! now what? | tomasro | I.C.E., Electrical, Security, & Navigation | 17 | 08-01-2006 10:57 AM |
| changing only rear spring? | CivicWithNav | Suspension and Brakes | 6 | 05-16-2006 05:53 PM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Driving Experience | 4 | 01-11-2006 03:40 AM |
| 2006 Civic sedan rear window | clm10k | Civic Coupe And Sedan | 5 | 01-07-2006 04:23 PM |
| Anyone with parking brake problems? | Silver06 | Garage | 7 | 12-16-2005 02:18 AM |
