#41 (permalink) | |
#42 (permalink) |
Tokico hp's are just OEM replacements. I dont care what anyone says. They are the same height as OEM, and valved identically. From what i've gathered it seems like having a pair of good lowering springs would suit your style better than anything. You can always buy upgraded shocks when they become available as long as you dont drive like a madman on the stock shocks.
#43 (permalink) | |
[quote=CanyonDriver;2440716]
#48 (permalink) | ||
Joey
I purchased my HFP suspension from them for my FA5. About 2 months into ownership one of the rear struts became defective. I sent both back to them, sent them original bill of sale from them with my VIN number and they sent out 2 new rear struts no questions asked.
#49 (permalink) |
How did you know one of the rear dampers was deffective?
All, I just finished the install myself on my FA5 with the use of two jack stands and a floor jack. As long as you have some mechanical ability, its a piece of cake! Just take time to understand the installation instructions and have the proper tools as well as patience. If you don't have impact tools, which I do, you will definately need a breaker bar to get the bolts off the trailing arms, struts, dampers, and the front. Also, you need a torque wrench...thats a must. The instructions also failed to mention that you need a 14mm socket and/or wrench to use on the rear suspension parts. Now as far as the ride goes, I love it!! Not that much harsher than the stock Si suspension. Those complaining about the rough ride must live in pretty poorly maintained areas because, yeah you feel the road a little bit more but its nothing to think about. And this is coming from soneone who had an 05 EXV6 Accord that drove like a boat compared to the Si
#51 (permalink) |
Joey
As I went over bumps, slow and light one of the rear struts rattled. Everything was tight. To test it, I put the driver side strut on the passanger side and vise versa. The noise I was hearing moved with that strut. Sounded like the strut insert was loose. Noise sounded like a marble in a plactic tube if you were to shake it. They are not supposed to sound like that. Haha.
#52 (permalink) | |
#54 (permalink) | |
#56 (permalink) | |
![]() zumzumzoom, you can get by without the trim tool for the screw type clips, but there are also 4 regular clips that you have to pry out- not sure if this is the same for the coupe. You can even get a cheap kit at like autozone if you want or use a pry tool from autozone. If not, just pick up four of these clips at the dealer- they're cheap and usually in stock. Don't worry- it will go fine |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/79596-recommend-hfp-suspension-kit-eibach-pro-kit.html
| Suspension and Brakes [Archive] - 8th Generation Honda Civic Forum | This thread | Refback | 02-19-2008 02:02 PM | |
| Eibach Pro-Kit + HFP [PICS] | llckll | Suspension and Brakes | 21 | 12-10-2007 12:43 AM |
| HFP Suspension + Eibach Pro-Kit Owners... | llckll | Suspension and Brakes | 33 | 11-08-2007 07:55 PM |
| HFP & Eibach Pro Kit ... | BigGreg030 | Introduction & Pictures | 11 | 03-29-2007 09:36 PM |
| hfp shocks and struts w/ eibach pro kit | rippars | Suspension and Brakes | 18 | 02-23-2007 12:48 PM |
| NEED HELP!!! HFP VS. Eibach Pro-Kit | Blackmouf2002 | Suspension and Brakes | 22 | 02-07-2007 12:30 AM |
