Old 02-04-2008, 01:53 AM   #1 (permalink)
o-hatch's Avatar
SiR
Improving the FN_Type R
We all know the Euro_Civic (FN) has the Torsion-Beam rear suspension. Which made it lag compare to the Independent (Us/Japan) unit.
I was wondering would it be possible to swap over...H.O.A Part# 65750-SNX-A00ZZ (rear crossmember)? Would the surface be direct tap-weld or will there be modifications needed? If so, would the independent-suspensions swap over w/o offsetting the (shocks/hubs/wheel-base)? Since the "Fit" is base off the FN, do they share the same surface in that area?
Just looking for ways to improve an under achieve Type R!
o-hatch is offline   Reply With Quote
Old 02-04-2008, 02:19 AM   #2 (permalink)
I Vtec, do you?'s Avatar
Well since the euro Type R is practically a different car than the JDM and USDM civic, I'm going to assume a major part like part of the suspension wouldn't be a direct swap. Then again, I'm usually wrong about these things
I Vtec, do you? is online now   Reply With Quote
Old 02-04-2008, 05:00 AM   #3 (permalink)
lukits01's Avatar
Why bother swapping the rear torsion beam?
its not as bad as people make it to be
Just get a set of KW coil overs and you're set!
although I think LSD makes more of a difference to the handling
lukits01 is offline   Reply With Quote
