Old 03-09-2008, 08:49 AM   #121 (permalink)
Scott
From some of your other post I got the impression that single adjustable coilovers were not worth sh@#. Does that mean I need Koni Race (double adustable twin tube) and Coilovers? I do mostly DD but want to do X-cross next month. Also, no one drives or rides in the car but me. I am willing to take a stiff ride. However, ATL is pothole land.
sb12007 is offline   Reply With Quote
Old 03-09-2008, 10:56 AM   #122 (permalink)
^^There is single adjustable meaning there is one knob that adjusts things....and Double adjustable meaning there is two knobs.Were talking only Double adjustable here... NOW the Shit of it is is that to save money cause its less expensive to make the shocks most "pre-built" coilover company utalize one knob that adjusts both settings..Rebound and Bump...So you will always have to compromise more bump for more rebound or less. Koni single adjustables only adjust rebound, bump stays constant. This can allow for finer tuning.
Old 03-09-2008, 02:01 PM   #123 (permalink)
Are the Koni sports and coilovers best for DD and once in a while track? Im waiting on these to come out to be my first mod.
Wierdochild89 is offline   Reply With Quote
Old 03-09-2008, 02:15 PM   #124 (permalink)
Yeah they would be fine for that...
Old 03-09-2008, 02:32 PM   #125 (permalink)
Doraemon!
marc-o-lishuz's Avatar
Marc
i read somwwhere that some modification is required to install these dampers... care to elaborate the extent of these modifications?
marc-o-lishuz is online now   Reply With Quote
Old 03-09-2008, 03:17 PM   #126 (permalink)
This is the standard insert instructions that use a bolt from the bottom.
http://www.koni-na.com/pdf/boltstrut.pdf
Our setup is different..yet similar.
"Our setup will include an insert that is fitted into the stock housing. The stock housing obviously has to be modified. The only modification required is cutting the top of the strut housing off and welding the fitted custom top that we have developed. The fitted top has a threaded exterior for coilover setups and a threaded top portion that is used to tighten the insert into the housing with the Koni threaded cap. These inserts are not the RSX-style inserts with the bottom set-screw; rather they are similar to VW and Toyota inserts that are held in with a threaded cap (a Koni part actually) that perfectly holds the insert without letting it move at all."
Old 03-09-2008, 03:54 PM   #127 (permalink)
for autoX, which of these setups are fine for stock class? I remember reading the rules stating that shocks are permitted, but springs aren't? Which of the choices is for someone who's already doing four open track days a year and autoX in between very soon? Thanks!
warhead111 is offline   Reply With Quote
Old 03-09-2008, 04:06 PM   #128 (permalink)
All of our setups will maintain the stock spring perch so you can utalize stock springs...Depends on how much money you want to spend
Old 03-09-2008, 04:12 PM   #129 (permalink)
FastTimesAtFGHigh's Avatar
http://jdmfg2.blogspot.com
I'm assuming this product is not a out-of-the-box koni product but rather, konis with your shop's custom modification, right?
FastTimesAtFGHigh is offline   Reply With Quote
Old 03-09-2008, 04:16 PM   #130 (permalink)
The housing are modified to accept the koni..
Old 03-09-2008, 05:26 PM   #131 (permalink)
^ so this is not the out-of-the-box no-weld solution from Koni that we are all waiting for?
In short, I want the Koni Yellows that are supposed to be a direct bolt-on replacement to our stock suspension. I don't want to modify or weld anything. Plug and Play is what I'm looking for and I'm not trying to bash your offering. I just need to clarify what exactly you guys are selling. Thanks!
Old 03-09-2008, 05:31 PM   #132 (permalink)
Koni has been doing inserts for YEARS for cars, nothing at all wrong with an insert.
And our setup will be more universal if you ever choose to upgrade to Double adjustables, in that the same housing setup is used for both....You also get the best of both worlds in that it is a coilover or can be used with any lowering spring..
Old 03-09-2008, 05:32 PM   #133 (permalink)
Louder than 4 F404-GE-400
Paul
Even the DA's will keep the stock spring pearch? Won't that cause some clearnce issues?
Old 03-09-2008, 05:35 PM   #134 (permalink)
Yes the DA's will maintain the spring perch also..Or for additonal weight savings it could be cut off..To run a standard spring the adjustable collare for the coilover sould need to be removed..
Old 03-09-2008, 05:39 PM   #135 (permalink)
About how much better will i expect with the Sports $1300 option over the stock setup on our SI's. Convince me with detail .
Old 03-09-2008, 05:41 PM   #136 (permalink)
Can't do that until I test them and am able to show you improved times Thats the real test isn't it to acutally show through lower time the car is faster...
Old 03-09-2008, 08:03 PM   #137 (permalink)
Paul
Chop mine off. I don't need no stinking stock pearches.
Old 03-09-2008, 11:19 PM   #138 (permalink)
Profoxcg's Avatar
can we see some pics please?
Profoxcg is offline   Reply With Quote
Old 03-09-2008, 11:20 PM   #139 (permalink)
Shortly...
Old 03-09-2008, 11:29 PM   #140 (permalink)
Doraemon!
Marc
Ditto. I want to see more details of this "modification".
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/75996-koni-redshift-coilovers.html
Suspension and Brakes [Archive] - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 07:31 PM
Koni FSD or Koni Coilover kit zspeedzkwy Suspension and Brakes 8 01-03-2008 04:51 PM
RedShift S/C + BOV?? 06civSi Forced Induction And Nitrous 44 05-19-2007 12:37 PM
