Old 08-29-2008, 08:50 PM   #501 (permalink)
Sensible member
Cookstar's Avatar
Chris
Originally Posted by Sirbelch View Post
It was down earlier when I checked it. I believe their rights to the domain had expired and they had to renew.
Cookstar is offline   Reply With Quote
Old 09-27-2008, 11:15 PM   #502 (permalink)
honda93's Avatar
After spending the last two weeks with my race-valved DA rears, I can say with confidence that I will be needing to make a decision on fronts sooner rather than later. The question now is do I wait for an FSD insert, or have Bilstein make me up something?
Anthony "Mario" Crea
NNJR-SCCA
Old 11-11-2008, 12:14 PM   #503 (permalink)
I'm bringing this back from the dead. How are people doing with their setups?
2point is offline   Reply With Quote
Old 11-11-2008, 02:17 PM   #504 (permalink)
honda93's Avatar
My custom valved DA's are stored in their box for the winter (salt will never touch these things).
I'll put them back on in late March.
NNJR-SCCA
Old 11-11-2008, 10:06 PM   #505 (permalink)
BigMoney8481's Avatar
Randy
I have the yellows. I like them. I had trouble with the front struts because Redshift used never seize on the threads which caused the caps to come loose and the strut inside the housing was clunking around bad. Then I had to try and fix it myself with the tool they sent but it was a piece of junk and was not proper for the application at all. I ended up using industrial locktite for larger then 1" diameter threads and a big pair of pliers to snug down the cap to the housing. I then clear coated the whole strut.
I believe now they are welding the caps shut to the housing once they get it as tight as possible but I'm not 100% on that.
BigMoney8481 is offline   Reply With Quote
Old 11-11-2008, 10:08 PM   #506 (permalink)
lets hope they are. thats very unlike redshift to eff something up that bad.
CanyonDriver is offline   Reply With Quote
Old 11-11-2008, 10:12 PM   #507 (permalink)
Randy
Well welding that caps wouldn't be ideal if you wanted to remove the strut to repair damage or wanting to use a different unit. It would absolutely be better than using never seize.
Old 11-12-2008, 12:46 AM   #508 (permalink)
to save and buy or get drop springs now, that is the question haha!
Old 11-12-2008, 01:38 AM   #509 (permalink)
save up and buy. lowering springs for the most part are a waste.
Old 11-12-2008, 09:29 AM   #510 (permalink)
honda93's Avatar
Isn't the Industrial Loctite red in color? IIRC, red is permanent, correct? Would the blue stuff (removable) have done the job just as well, considering the fact that many people just rebuild Koni's?
NNJR-SCCA
Old 11-12-2008, 11:20 AM   #511 (permalink)
Randy
I don't know what other kinds of loctite could be used. I know all the regular stuff (green, blue, red) they sell is for use with thread diameter <1". I had to go through an environmental company my friend works at to get the industrial >1" diameter applications.
Old 11-17-2008, 02:05 PM   #512 (permalink)
Yeah, the red is industrial strength. You need heat to remove it. That's how we've chosen to assemble all front housings now so that we never have an issue with them coming apart. I always used to assemble them with anti-seize; so that's why I did it this time. Not anymore. :)
And the cheap wrench we sent was something that we got and modified to make work. It doesn't need to be crazy tight on the strut; so I thought it was ok. Sorry about that. We use one that is similar in dimension for production assemblies and it works fine.
Chris
RedShiftChris is offline   Reply With Quote
Old 11-17-2008, 02:32 PM   #513 (permalink)
honda93's Avatar
Chris
Chris,
Assuming Koni used their SPSS3 valving, can more low speed compression be dialed into the DA housing? Or is the shock pretty much maxed out now?
Thanks.
Tony
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/75996-koni-redshift-coilovers.html
Suspension and Brakes [Archive] - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 07:31 PM
Koni FSD or Koni Coilover kit zspeedzkwy Suspension and Brakes 8 01-03-2008 04:51 PM
RedShift S/C + BOV?? 06civSi Forced Induction And Nitrous 44 05-19-2007 12:37 PM
