Old 04-24-2008, 06:16 AM   #421 (permalink)
Quick update. We are still on schedule to deliver everything as ordered by May 15th. :)
Suspensions:
Front -
In front, we'll be using 6" Free Length, 2.5" ID springs (3 cheers for travel). They are Eibach Race Springs, in case you didn't already know. Threaded collars are a treated steel incorporated into the top cap, which threads onto the OD of the stock housing (after we fab the housing to accomodate it). The stock lower spring perch will be removed on all coilover front setups so that the extra travel of a 6" front spring can be used.
The upper spring perch is a trick modified strut bearing which uses an anodized aluminum lower half with 0-rings to accomodate the 2.5" ID spring.
And optional front upper camber/caster plate is available for $295 ($370 retail). It's the K-Mac Camber/Caster Plate that you can see at the following links, under "New Products".
Welcome to K-MAC, Camber Kits, Caster Kits, Springs, Swaybars.
Rear -
In rear, we use an anodized aluminum upper spring collar with a 2.5" ID spring, held to the frame using 1 Nutsert per side (optional).
Shocks -
Shocks are Koni Sports, Koni Race (with Single or Double Adjustable Config). I should note that all rear RACE shocks (SA and DA) are available upon custom fabrication by Koni...we don't have control over that.
EXHAUSTS - We are going to have pictures of our new exhaust in about 1 week, probably just after this pre-sale. We'll have sound and power testing following that as we can get to it.
Sale end in less than 1 week! :)
Chris at RedShift
RedShiftChris is offline   Reply With Quote
Old 04-24-2008, 10:02 AM   #422 (permalink)
FastTimesAtFGHigh's Avatar
http://jdmfg2.blogspot.com
^ Do you have a poor-student-not-supposed-to-buy-car-stuff-cause-the-fiance-wants-us-to-save-money-to-pay-for-the-wedding discount?
FastTimesAtFGHigh is offline   Reply With Quote
Old 04-24-2008, 08:22 PM   #423 (permalink)
Yep, and this is it. The price will only go up. :) Sorry.....
Chris
Old 04-25-2008, 03:20 PM   #424 (permalink)
TeamBadger's Avatar
Will the Kmac camber plates work the stock struts?
TeamBadger is offline   Reply With Quote
Old 04-25-2008, 04:10 PM   #425 (permalink)
s0opa_Si's Avatar
M i l o
sorry i didnt read the pages of this whole thread, but i will probably get flamed for this,
but i'm still a bit confused with the Koni products. So far I understand that there are Koni coilover system, which are the Koni Redshift(race coilover). The Koni yellows are replacement shocks correct like the Tokico blues are? correct me if im wrong.
s0opa_Si is offline   Reply With Quote
Old 04-25-2008, 05:50 PM   #426 (permalink)
friedk's Avatar
*flame*
Now that we have the flaming out of the way..
Yes, koni yellows and tokico blues are both after market shocks. The difference is tokico blues are hardly even better than stock dampers while koni yellows are probably the best handling setup on these cars ATM.
friedk is offline   Reply With Quote
Old 04-26-2008, 08:33 AM   #427 (permalink)
Yes they will. And stock size springs or 2.5 ID race springs like in our coilover design. But you have to specify exactly what you want so it is sized correctly with the proper bearing sleeve and spring perch.
Chris
Old 04-28-2008, 01:24 AM   #428 (permalink)
would the koni reds w/sportlines or prokits handle better than the HFP suspension?
I not quite sure which one to grab, as they are similar in price. Only about at 200 price difference.
07k20si is offline   Reply With Quote
Old 04-28-2008, 10:37 AM   #429 (permalink)
s0opa_Si's Avatar
M i l o
Originally Posted by friedk View Post
*flame*
thanks man!!!
Old 04-28-2008, 10:42 AM   #430 (permalink)
They will be very similar I think. It will be hard to tell the difference maybe.
Chris
Old 04-28-2008, 02:54 PM   #431 (permalink)
honda93's Avatar
Support Chris and the good people at RedShift. The money will be well spent and at that price, you'd better hurry!
Anthony "Mario" Crea
NNJR-SCCA
Old 04-29-2008, 12:33 PM   #432 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
Spoke with Josh at Excelerate this morning and ordered the Koni yellows with the Eibach Prokit springs. Can't wait for them to get here
SiliconX is offline   Reply With Quote
Old 04-29-2008, 03:30 PM   #433 (permalink)
Doeboy211's Avatar
I just did the same thing!
Doeboy211 is online now   Reply With Quote
Old 04-30-2008, 01:06 PM   #434 (permalink)
Today is the last day for the pre-order sale!!!
Chris
Old 04-30-2008, 02:49 PM   #435 (permalink)
BigMoney8481's Avatar
Randy
Just ordered koni yellows w/ sportlines and front/rear camber
BigMoney8481 is offline   Reply With Quote
Old 04-30-2008, 03:13 PM   #436 (permalink)
Louder than 4 F404-GE-400
Paul
Chris
I guess I better get on it then ... oh wait ... I'm just poking a little fun Can't wait.
Old 05-01-2008, 11:11 AM   #437 (permalink)
s0opa_Si's Avatar
M i l o
i was thinking to run the yellow's with the neus'. seems like the sportlines are its best bet.
Old 05-01-2008, 11:19 AM   #438 (permalink)
honda93's Avatar
Run the Pro-Kits instead.
Old 05-01-2008, 11:35 AM   #439 (permalink)
pro kit springs + koni yellows = best for road racing?? Correct me if i'm wrong
autoxmnstr is offline   Reply With Quote
Old 05-01-2008, 02:37 PM   #440 (permalink)
what do you mean by road racing? ProKit isn't the best handling.... a good coilover setup with different rates would be best for what I call "road racing". What do you mean by road racing?
Chris at RedShift
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/75996-koni-redshift-coilovers.html
Suspension and Brakes [Archive] - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 07:31 PM
Koni FSD or Koni Coilover kit zspeedzkwy Suspension and Brakes 8 01-03-2008 04:51 PM
RedShift S/C + BOV?? 06civSi Forced Induction And Nitrous 44 05-19-2007 12:37 PM
