Old 03-16-2008, 12:59 AM   #181 (permalink)
jokka's Avatar
so these shocks will be built specifically for lowered cars right ?
I'mma lower my car on pro-kit and i want to eventually upgrade to something that will last alot longer than OEM.
jokka is offline
Old 03-16-2008, 01:11 AM   #182 (permalink)
Louder than 4 F404-GE-400
Paul
Pretty much, yeah but I think the Redshift base suspesion includes springs. Chirs? Greg? is that right?
Waking up dead inside of my head will never never do, there is no med, no medicine to take.
I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break.
Sirbelch is offline
Old 03-16-2008, 09:34 AM   #183 (permalink)
jokka's Avatar
o i see....
so the $800 koni listed on the original post = springs + shocks ?
jokka is offline
Old 03-16-2008, 02:59 PM   #184 (permalink)
CivicSi907's Avatar
Thomas
I just need "high adjustable" shocks! So am I right with the yellows?
CivicSi907 is offline
Old 03-17-2008, 11:26 AM   #185 (permalink)
CivicSi907's Avatar
Thomas
bump!
Old 03-17-2008, 12:18 PM   #186 (permalink)
8thcivic Sponsor
The RedShift/Koni Sports are for lowered cars running higher rate springs. They will work on Stock springs obviously too. We are running the Max Length in the back shock shorter so there is less issue with the rear spring falling out too.
Shock Dyno info available now on our website:
06 Civic Susp Packages
Cheers all,
Chris
RedShiftChris is offline
Old 03-17-2008, 04:29 PM   #187 (permalink)
can someone teach me how to read that graph and how do i know if its good or not over stock si setup.
Wierdochild89 is offline
Old 03-17-2008, 05:28 PM   #188 (permalink)
Paul
The x axis is speed the y axis is force. The negative values are compression and the positive values are rebound. Compression is less than a stock Si for a better ride and rebound is more than a stock Si for better handling.
Hey Chris, what's up with the last little bit of rebound where the curve becomes progressive?
Also, where's the DA graphs for us DAers? :)
Sirbelch is offline
Old 03-17-2008, 05:31 PM   #189 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
Can we see the shock dyno of the Koni's w/ each click, instead of max/min?
Looking at the graphs, it seems like the min setting on both front/rear seem to be a slight progressive curve. On max setting, the front is digressive but the rear is *very* progressive, with what seems to be too much high-speed valving. I'd guess the rears would be skittish on bumps.
aki is offline
Old 03-17-2008, 05:32 PM   #190 (permalink)
Profoxcg's Avatar
so when is late march ? next week?
What would make this setup superior to skun2's Pro-C suspension?
Profoxcg is offline
Old 03-17-2008, 05:36 PM   #191 (permalink)
Paul
There are no clicks on the konis. Is just a knob that spins.
Sirbelch is offline
Old 03-17-2008, 06:00 PM   #192 (permalink)
Curt
...for rebound. For compression, on DA shocks, there are clicks.
Chris / Greg, what, if any, are the differences between the shocks on my car and the ones you are getting ready to put out? I would like to comment on mine but only if we're talking apples to apples.
BigDog is offline
Old 03-17-2008, 07:21 PM   #193 (permalink)
Paul
Its only progressive during 0.22-0.33 other than that, the curve is digressive.
Sirbelch is offline
Old 03-17-2008, 09:38 PM   #194 (permalink)
I was looking at hfp till this, seems like the perfect DD setup that handles better than most setups that send you out of control on a rough turn in a real corner.
Anything a bit lower like the hfp thats not overly agressive so I don't look like one of those ricers that loose contact with the road when they hit rough patches on real roads.
I think most people would fall into this "needs to look good" category but only looking for about 1 inch to less than 1.5 inches of drop without underperforming in the daily environment like a factory setup would..
flomofo is offline
Old 03-17-2008, 10:52 PM   #195 (permalink)
meeks's Avatar
subscribed. saving up now!!
meeks is offline
Old 03-18-2008, 12:40 AM   #196 (permalink)
8thcivic Sponsor
Not sure about the last bit of that curve you mention other than it's progressive as you mention. And I do plan to get the DA dynos too, but I don't have them yet.
Chris
Old 03-18-2008, 12:42 AM   #197 (permalink)
8thcivic Sponsor
All I can give you is what Koni provides to me. These are min and max settings of a shock that does not have clicks but rather sweeps from min to max. And generally a shock is skittish with too much bump valving rather than rebound valving... and these certainly don't have too much bump valving.
Chris
Old 03-18-2008, 12:43 AM   #198 (permalink)
8thcivic Sponsor
Late march is not going to happen with us just getting our test shocks this week now. We have testing to do before we release anything. I don't know when we'll be done.... probably in a month or so.
Chris
Old 03-18-2008, 12:45 AM   #199 (permalink)
ESPAÑA SIEMPRE!
marc-o-lishuz's Avatar
Marc
Chris
NNNNOOOOOOOOOOooooooo00ooo0!!!!111111
*dies*
marc-o-lishuz is offline
Old 03-18-2008, 12:45 AM   #200 (permalink)
8thcivic Sponsor
Curt,
Your shocks are definitely stiffer than these Sport shocks. In fact, yours were built with an unusual amount of rear bump valving to help the car rotate. :)
But do tell us what you think of yours. :)
Chris
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/75996-koni-redshift-coilovers.html
Suspension and Brakes [Archive] - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 06:31 PM
Linear Mode Linear Mode
Threaded Mode
