conversion question
ok guys im a complete retard when trying to figure this out. im lowering my car and putting on the spc camber kit, i am using an air compressor that reads in psi of course and i want to use it to torque the bolts which go to 43 lbf ft, ok so can some conversion guru gimme a way to do this
Louder than 4 F404-GE-400
Well, (not a physics major but here goes) you need to know things like torque capacity of the gun/wrench. CFM of the compresser at a given PSI. Diameter and length of the hose. I think thats it. But even if you can calculate the torque of the gun/wrench, how are you going to control it. How do you know when to stop?
Buy an effing torque wrench.
You know what the sun's all about when the light go out. |
#9 (permalink) | |
Yup, the only way you can do it properly... air guns are for taking stuff off, not putting it back on! (yes, including your rims!) |
#10 (permalink) |
I am a physics major :) and torquing a bolt is so complicated. Is the torque spec wet or dry? But not getting picky when you torque do the following.
1) Always use a torque wrench. 2) Never use an air tool to put bolts on. 3) When applying the final torque make sure the wrench is moving as you hit the value. Static torque will be greater than dynamic torque. So if it needs 70 ft/lb and you tighten it to 65 first, probably won't move when you try to go to 70. Which reminds me I need to get my torque wrench recalibrated before I put my new suspension in. |
| Clamp Question for the Injen CAI | laughoutlloyd8 | Bolt-Ons And All-Motor | 4 | 03-20-2007 11:31 PM |
| JDM front end conversion | ezcivic type r | Inside and Out | 15 | 03-09-2007 11:27 PM |
| R18 conversion question? | H.C.D. | Civic Coupe And Sedan | 9 | 12-15-2006 12:21 AM |
| Does a HID conversion affect your warranty? | jdm_honda | Lighting, H.I.D.'s, & Neon | 8 | 10-14-2006 10:19 PM |
