Old 05-15-2006, 10:44 PM   #1 (permalink)
CivicWithNav's Avatar
changing only rear spring?
well I'm lazy as hell and don't feel like taking front ones off...rear ones on the other hand just comes off with ease
if i bought SI springs and only put them in the rear, how would it effect the handling?(if ther are any difference in the spring rate)
i have EX coupe with SI wheels and SI rear sway bar.
Old 05-15-2006, 11:15 PM   #2 (permalink)
I'd not try that. Springs set work together as a set. Changing only the rear will upset the car's balance
Tate is offline   Reply With Quote
Old 05-15-2006, 11:54 PM   #3 (permalink)
Tim
Tim's Avatar
The car might flip over.
Tim is offline   Reply With Quote
Old 05-16-2006, 02:29 AM   #4 (permalink)
2000civic's Avatar
Robert
uhhh i dont think it would be a good idea. i honestly do not know what will happen as a result of it but personally i would not let lazyness get in between me and a 20,000 dollar car. just my thoughts. performance wise i would imagen it would decreace your performance due to the lack of consistancy throughout the cars setup. the back would be stiffer than the front and lower. i am not an expert on this though. and looks that cant look all that good either. id say take them off or put the fronts on imiditaly to avoid a bad situation.
2000civic is offline   Reply With Quote
Old 05-16-2006, 04:56 PM   #5 (permalink)
^^ correct. It is ok to just put sways on the rear, since it is an reinforcement for corning only. Springs, however, is the integral part of the suspension and are responsible for the weight transfer when the car is in motion (acceleration, braking and corning)
Old 05-16-2006, 05:20 PM   #6 (permalink)
Tuna Fiddle
twistedframe's Avatar
Dave
i don't really see a problem with this. Plenty of aftermarket companys offer different spring rates for the front and rear. With stiffer springs in the back it will promote more oversteer, well not really more oversteer but less understeer. I would however recomend paring these with at least si shocks if not aftermarket shocks, b/c the valveing in the lx shocks is different than that of the si.
Old 05-16-2006, 05:53 PM   #7 (permalink)
on an EX too?
whats the worst it can do by putting SI springs on, they are not much different.. it's not like the SI springs are considerably lower, only thing would be it's stiffer. now all thats gonna do is make stock shock(ex) work less wouldn't it?
just going by the "theory"
i've been there and done ALL that...and i just don't have the time and effort to mess with cars anymore...
step by step lowering an si 06 silverciv06 Suspension 581 01-30-2010 09:06 PM
OEM SPRING RATES NE1 know? sbmon Suspension and Brakes 44 03-10-2009 04:19 PM
rear speakers removed! now what? tomasro I.C.E., Electrical, Security, & Navigation 17 08-01-2006 10:57 AM
2006 Civic sedan rear window clm10k Civic Coupe And Sedan 5 01-07-2006 04:23 PM
Rear Speaker Install Guide brolewis I.C.E., Electrical, Security, & Navigation 7 12-29-2005 12:53 AM
