Old 05-07-2006, 07:13 PM   #1 (permalink)
Bump Stop Question
I just bought some eibach sportline's for my Si and was debating on whether or not to cut the bump stop like it says to in the instructions. I also have 18" wheels with 40 wide tires. I know in the step by step, they didn't, so i was wondering is it completly necessary if im not going to be whipping around a 90* turn at 75mph.
bigbizznass is offline   Reply With Quote
Old 05-08-2006, 10:44 AM   #2 (permalink)
honda93's Avatar
Post
Cut it down (even if you take a 1/3 ~ 1/2 off it). Though you may not be autocrossing, you may hit a bump mid-corner that would cause you to hit the bumpstop.
Here's why...
My guess is that Honda has a progressive bumpstop (so the resulting story won't be as severe), but in the old days, they were not progressive and hitting them would be the equivalent of making the spring rate infinite... In other words immediate and extreme understeer or oversteer. I was co-driving a Camaro at an autocross once when I had this happen to me. I asked the owner what happened and he said we hit the bumpstop.
Old 05-08-2006, 11:30 AM   #3 (permalink)
CarbonLimited's Avatar
cut the bump stop, it wont hurt
CarbonLimited is offline   Reply With Quote
Old 05-08-2006, 11:06 PM   #4 (permalink)
kenchan's Avatar
almost alwasy cut the bumpstop unless it specifically tells you not to cut it.
also, check out koni's progressive rate bumpstops for those that are
riding very low with limited sus stroke.
new! and a noob question... hoanger Introduction & Pictures 2 04-16-2006 08:09 PM
trip meter question luke Mechanical Problems & Technical Chat 7 04-13-2006 02:50 PM
question about driving the si jdmk20z3 Civic SI 9 04-06-2006 12:28 AM
driving question... kurdtkobain87 Mechanical Problems & Technical Chat 5 03-24-2006 09:57 PM
question about vbb... TorGa3iGhT 8thcivic.com Site Questions/ Problems 4 09-20-2005 08:44 AM
