TEIN lowering spring
Hey guys, need some advice on this.
Thinking about dropping my ride a bit, should I go for TEIN S-Tech or H-Tech springs?? And I was talking to this performance shop in my area(really unfriendly and rude)and they said that if I go for H-tech I'd only need the spring itself, but if I go for S-Tech I'd need some other parts to go with it(forgot what it called)! So which way should I go?! S or H and if go for S, what else would I need other then springs?! One more question! By lowering my ride what would happen to my handling? Same as stock, worse or better?? |
I would go for the S-Tech's because of the lower drop
you will need a camber kit with the springs. With a bigger drop you will have a lower center of gravity which will give you slightly better handling, but there are many other factors that effect handling... camber,tires,shocks,etc. |
8thcivic Sponsor
The High Tech's are a "luxury" spring. They don't drop the car as much and have a softer spring rate whereas the S-Tech is typically a shorter spring with more of a drop and firmer spring rates.
So it depends on if you want more of a drop or not. Wth more of a drop too you will get more negative camber so you will likely need a camber kit and it may bring the damper out of its efficiency (travel) range.
EXCELERATE PERFORMANCE - Your Official 8thCivic Vendor and Honda Performance Parts Specialist!! See our CT Engineering, ROTORA, Injen, TEIN, TOKICO, Random Technology, AEM, KAIXEN HID, Unorthodox Racing, P2R, Buddy Club, Innovative Mounts, and K Sport Sales at The Sponsored Posting Forum by Excelerate Performance NEW WEB STORE: Store.ExceleratePerformance.com AIM: Excelerate04 Phone: 203-483-6100 http://www.ExceleratePerformance.com |
I eat my r6
they either told u to get a camber kit b/c the drop is gonna give u negative camber or they told u to get stuts (shocks) b/c the spring rate is different from the stock spring rate so it will blow out ur struts in maybe 15-20k miles and then it will feel like ur riding on brick tires.
I happen to like the s techs better for the drop and they do improve handling a little bit.
FG Squad Member #382 Tampa Crew Member #315% Tint///JDM FD2 Shift knob///JDM Red H emblems///Injen CAI Join the forum where you can exercise freedom of speech and say what you want -----------> http://tampastreetracing.lefora.com/forum/ |
| Megan racing lowering spring | BattleEndless | BattleEndless Performance | 12 | 07-14-2008 01:26 PM |
| TEIN Basic, Super Street, FLEX Coilover and S-Tech/High Tech Spring Sale | Excelerate | Excelerate Performance | 39 | 07-11-2008 12:12 PM |
| ASR Adjustable Rear Swaybar | PR_S14 | Suspension and Brakes | 20 | 12-21-2007 05:53 PM |
| Feedback of Tein S Tech Lowering Spring | Audiolab | Suspension and Brakes | 28 | 11-16-2007 03:37 AM |
