Old 12-03-2007, 10:45 PM   #1 (permalink)
08 HRP FA5
06NaviEX's Avatar
Brian
Question about dampers/springs
I've got an opportunity to pick up some Si dampers pretty cheap. Would it be worth it to pull my stock EX sedan suspension (and set it aside), and install the Si damper with some springs? Then I could put the stock suspension back on if the dampers blow.
Will the Si dampers last longer with a slight (around 1") drop since they are valved more aggressively?
Would just putting the springs on my stock EX dampers be a better idea?
I know I'm going to wear the dampers out early, but I'm like everyone else, waiting on Koni! I'm also looking a just around a 1" drop, nothing really aggressive.
Thanks for the help,
Brian
Originally Posted by Monty View Post
I tried some astroglide but it didn't seem to help. It's pretty cold here today, don't know if that's making the attachment tighter.
06NaviEX is offline   Reply With Quote
Old 12-03-2007, 11:02 PM   #2 (permalink)
Tod
The Si suspension will not drop your car, the Si is a heavier car and if anything your car will sit a few mm higher.
Solo2EG is online now   Reply With Quote
Old 12-03-2007, 11:06 PM   #3 (permalink)
Supreme Pizza!
Izzy's Avatar
The safe thing to say is to just keep your money and wait till the Koni comes out.
Old 12-04-2007, 03:59 AM   #4 (permalink)
Jardiniboy's Avatar
Jasten
Get the ground control and koni yellows. People way not know but it's not gonna be expensive like what others think.
Old 12-04-2007, 09:46 AM   #5 (permalink)
08 HRP FA5
06NaviEX's Avatar
Brian
Thanks guys!
That's kind of what I was thinking, but just wanted some opinions.
alignment question diepanthony Civic SI 4 12-01-2007 03:04 PM
Question on P2R Spacer.. abarab Bolt-Ons And All-Motor 4 09-21-2007 11:02 AM
rev limiter question 20civic07 Civic SI 27 07-25-2007 05:26 PM
Last question about 18" HFP on non-si + Tire PSI question amdhunter Wheel And Tire Upgrades 2 06-26-2007 06:11 PM
help with a question about getting a wing for my EX Filippelli Inside and Out 7 05-10-2007 12:08 AM
