Old 11-23-2007, 04:51 PM   #1 (permalink)
08 HRP FA5
06NaviEX's Avatar
Brian
Question Install SS lines and removing calipers??????
I'm wanting to repaint my calipers since before I used one of the brush on kits and it looks like crap. I was going to pull them off and spray them black or gray and clear them with some high temp paint. While I'm doing this, I might as well swap out the OEM lines for some SS ones.
I'm going to have to have the calipers off for around 24 hours so they can cure.
Questions:
Will all the brake fluid run out during this time and then I'll have air in my system?
Would it be OK to pinch off the rubber hose since I'll be putting SS lines on when the calipers go back on?
I did find some info on the order to bleed the brakes by searching. I have a Motive Power bleeder that I'll be using for the first time. Does any one have any tips on using that for our cars?
Thanks in advance,
Brian
Originally Posted by Monty View Post
I tried some astroglide but it didn't seem to help. It's pretty cold here today, don't know if that's making the attachment tighter.
06NaviEX is offline   Reply With Quote
My DIY Backup Sensor Install Orient Express Exterior Style Mods 65 10-16-2008 12:52 AM
DIY: Easy Low Beam Install [Super White Halogens] Tang841 Do It Yourself Articles 25 09-09-2008 04:19 AM
Removing stock brake lines? J-Ro Do It Yourself Articles 13 06-15-2007 04:10 PM
removing wavy lines in the paint turboawd Detailing 3 07-27-2006 01:53 AM
