Cornell
Does anyone know where i can get some rotors and brakes for my 06 lx for cheaper then honda? they are charging me 269.52 with tax..
considering brakes are one of the most important (life protecting) contraptions on your car, I wouldn't be so quick to be too cheap about them....just my opinion.
my last brake job i did on my last car, i gladly spent over 400 dollars just making sure i had quality rotors, and especially quality pads.... |
Acorns!
http://www.collegehillshondaparts.com/
they are a vendor on the site - if you are looking for oem honda parts. |
Your best bet would be e-bay but as said earlier...I wouldnt scrimp on brakes. Since you need to change them, maybe some slotted or cross drilled rotors?
I have 31k miles on mine and just need new brakes. I think I'm going to try the Hawk pads and possibly some slotted rotors |
#6 (permalink) | |
[quote=06blaksi;1724610]Your best bet would be e-bay but as said earlier...I wouldnt scrimp on brakes. Since you need to change them, maybe some slotted or cross drilled rotors?
Thats what I meant by ebay...there are a lot of nice packages slotted and drilled good break pads...all at a reasonable price...look to upgrade the breaklines while your there...significant improvement...generally around $100... |
#12 (permalink) |
Louder than 4 F404-GE-400
^^^ My local Kregan does that but they are busy and you should call ahead. The only way I see you needing new rotors is if you completely used up the pad material and then did a lot of hard metal (pad backing) to soft metal (iron rotor) contact. That could have put enough deap gouges into the rotor to make it useless.
#13 (permalink) |
why not try a local autoparts store like advance auto or autozone? thier pads and rotors or oem or better and you wont be paying as much as what the dealer would cost. plus you get like a 2yr warranty on the rotors (depending on which you buy) and a lifetime warranty on the pads (also depends on what you buy)
#15 (permalink) |
Cornell
how are these? http://www.8thcivic.com/forums/showthread.php?t=62074
#20 (permalink) |
Warping is not a good term......Warped rotors is a mis nomer....Heating a rotor to where it gets bent/warped on the street is near impossible. What the real issue is is probably uneven build up on the rotor surface of pad material. This will translate into thte pedal as a pulsation making the feeling like a warped rotor...Rotors are made of cast iron which are designed to withstand temps wel in excess of 1000 degress.
Awesome work with the Turbomafia issue too :) |
| Drilled rotors ** need answr ASAP ** plz | si_civic | Suspension and Brakes | 67 | 11-09-2007 08:08 PM |
| oem Civic Si front brakes on my LX!! -impressions...(pics) | Andrei'sCivic | Suspension and Brakes | 66 | 08-17-2007 07:11 PM |
| brakes and gas!! | carlossamano2004 | Civic SI | 14 | 07-27-2006 12:44 AM |
