Old 11-13-2007, 09:31 PM   #1 (permalink)
Kroze's Avatar
HFP suspension kit doesn't work for DX??
It said it only work for the LX & EX
also on a related note, will the SI suspension (Coupe) work on DX,LX,EX (Coupe)?
Kroze is offline
Old 11-13-2007, 11:11 PM   #2 (permalink)
zenith931's Avatar
Yes, I AM A WOMAN!
Don't know about the DX, but the SI HFP suspension will FIT on the DX/LX/EX, but it wasn't designed for them. I would get the HFP suspension that is made for your car.
zenith931 is offline
Old 11-13-2007, 11:32 PM   #3 (permalink)
Jardiniboy's Avatar
Jasten
The LX/EX will fit on the DX. All FG/FA have the same suspension design. The only difference with the LX and DX is the weight.
Jardiniboy is offline
Old 11-14-2007, 12:27 AM   #4 (permalink)
Kroze's Avatar
So i can buy the HFP for the SI (coupe) and it will work with my car right (06 civic dx coupe)?
the way they advertise on the honda's web site they made it looks like it won't work.
Kroze is offline
Old 11-14-2007, 01:05 AM   #5 (permalink)
Jardiniboy's Avatar
Jasten
Yes it would. But since the SI is heavier than the DX, the suspension is gonna be stiffer.
Old 11-14-2007, 01:56 AM   #6 (permalink)
Louder than 4 F404-GE-400
Paul
If you get the Si suspension for your DX, that should give you better handling than that of the DX for the DX. Although, stiffer isn't always better, in this case, it is better because the HFP suspension arent that stiff (relatively speaking).
Sirbelch is offline
Old 11-14-2007, 02:28 PM   #7 (permalink)
Xtreme Thunder's Avatar
Joey
All HFP Civic Suspensions will FIT on any Civic.
BUT
If you put the HFP Suspension that is designed for the Si Sedan and put it on a DX Coupe, the dampers WILL NOT be designed correctly, as with spring rates (FA5/FG2 vs. FA/FG [EX, LX, DX])
I would NOT recommend putting an Si HFP Suspension on a EX, LX, (DX).
If you are thinking it will handle better because the Si application is stiffer, I would put money it won't if you put it on a DX.
If anything get the HFP Suspension designed for the EX/ LX, AT or MT, Coupe/ Sedan (yes there is even different ones for tranny type too).
I hope you are understanding what I am trying to say.
Xtreme Thunder is offline
Old 11-14-2007, 11:26 PM   #8 (permalink)
Kroze's Avatar
I already got the SI front & rear sway bars installed on my DX...
So i think the HFP will complete the system :)
Kroze is offline
Old 11-14-2007, 11:48 PM   #9 (permalink)
try hfp struts with the dx springs.
fuqya is offline
Old 11-14-2007, 11:56 PM   #10 (permalink)
Jardiniboy's Avatar
Jasten
I would put back the front DX sway bar.
Old 11-15-2007, 02:10 AM   #11 (permalink)
Paul
That'll get that thing to rotate.
Sirbelch is offline
Old 11-15-2007, 12:14 PM   #12 (permalink)
zenith931's Avatar
Yes, I AM A WOMAN!
DX has no front sway bar, I thought?
But I was told by HighRev that with our cars (which understeer), to eliminate understeer, to put in a heavier RSB. Putting in a stiffer front sway bar does nothing but help it understeer more. It's thus best to have the stiffer sway bar in the back and a less stiff one in the front. I have the stock EX one on the front and the Si one on the back for me.
Old 11-15-2007, 02:23 PM   #13 (permalink)
zspeedzkwy's Avatar
so how about ex front sway and progress rear sway?
even better?
zspeedzkwy is offline
Old 11-15-2007, 03:27 PM   #14 (permalink)
zenith931's Avatar
Yes, I AM A WOMAN!
even better?
Possibly, you might be prompting oversteer, then. If you want the progress RSB, i'd go with the Si front.
But PM HighRev. He's the suspension god.
Old 11-15-2007, 04:22 PM   #15 (permalink)
Paul
Don't put the front Si bar on with progress rear swaybar. Just keep the stock ex front bar and go with the progress bar. You car is still going to push coming off the corner. What you need to worry about is braking to late and turning in at the same time. That might cause a spin. On the streets, I would keep a front sway bar unless I get stiff enough springs to make up for the lack of the front bar. FWD cars do better out of a corner when the front suspension are not tied together with a sway bar. FWD cars need the articulation to keep as much rubber on the road as possible. Also, sway bars put extra load on the outside tire. More load means less grip. Less grip is not good, unless its in the back (to a point).
Sirbelch is offline
HFP Suspension + Eibach Pro-Kit Owners... llckll Suspension and Brakes 33 11-08-2007 06:55 PM
For those of you with the HFP suspension setup! roadrunner1659 Suspension and Brakes 19 04-30-2007 08:52 PM
What I learned about the HFP Aero Kit!!!!!! cornerstrike Inside and Out 26 03-22-2007 10:07 AM
HFP Kit Info 2fast4u2 Civic SI 4 10-05-2005 03:50 AM
