civic road noise/engine noise
Hello everyone, this is my first post and i might be getting a civic coupe 06 this week, i wanted to ask you guys how is the suspension on this car? i currently drive a 94 lexus es 300 and the ride is smooth, road noise is minimal, engine noise is minimal, and over all the car is very smooth. My girlfriend drives a toyota echo 2000 and when you get on the freeway of step on the gas you can hear tons of noise from the engine and from the road, the car is kinda stiff and is just unplesent to drive. So my question is how does the civic coupe handle? i will prably get a ex or lx if it matters.
It rides pretty well. Although I don't like how it handles the faster I go. 90mph isn't too fun, and neither is 75mph ( at least to me).
*sigh* if only I could afford an airbag suspension to I could lower it an inch or so when I'm getting to highway speeds (65+) |
I drive an EX coupe with Auto. The road noise is not bad unless you are on rough or coarse pavement. It is mainly the POS Turanza's that come on many of the Civics that is the cause. Ride........... well if your coming from a Lexus, you can compare the ride of the coupe to a covered wagon. It is very stiff and bouncy, not to the point of it be annoying, but absolutely nothing like the car you have been driving. It handles well at most speeds, as has been said the stability goes south with speed. You WILL feel every bump,piece of tar or playing card that you run over. Lets keep this in perspective, it is a Civic, and can't be expected to ride like a luxury sport sedan. It is overall, fun to drive, great on gas and efficient.
#7 (permalink) | |
Sounds to me like you want to drive an Accord |
Noise Level -
I have only had my SI for a month or so, and the biggest adjustment I had to make was the stiffer ride. Coming from a Lexus, you are in for a suprise. If performance is more important, you can live with the ride. If NOT, then like the other fellow said-- get the accord (manual with the 6cyl- still fun)
#10 (permalink) | |
I have an LX sedan which is pretty noisy on some roads. I don't blame the excessive noise on the wheels only, because all or most of the stock tires that are found on the 06 sedan and coupe are well regarded for the low noise output. Check out Tirerack.com to read the user reviews. I dampened my LX's cabin, doors, trunk, and rear quarter panels and the improvement is very noticeable. I can now hear rear passengers at normal conversation levels while cruising on the expressway. Before I dampened the car, it was not uncommon for everyone in the car to have to raise their voice and repeat sentences in order to hold an intelligible conversation. Although it's still too noisy for my taste, the perceived ride quality has taken a step in the right direction. |
#11 (permalink) | |
#12 (permalink) | |
I also dampened the trunk and the upper rear 1/4 panel. Finally I dampened the floor of the vehicle. I used a single layer to all surfaces. I used Scosche Hyperflex. The stuff was extremely easy to work with and the material size makes it really easy to apply with very little trimming. This stuff is the equivalent to Dynamat Extreme. BTW, do not buy the Dynamat roller. Instead go to Home Depot and pick up the laminate roller. It's the one that's used to lay down formica. The handle is longer, making it easier to use in those hard to reach places and it's built for two-handed use. This allows you to apply greater pressure for better adhesion. And it's built to last. MAke sure you wear gloves to prevent cuts from the door openings. This is what it looks like:
| 2006 Civic Chassis Codes | 2fast4u2 | Driving Experience | 38 | 07-23-2008 05:36 PM |
| Civic SI Sedan Comes To America - Chicago Auto Show Debut | webby | Honda Industry News | 11 | 04-19-2008 10:24 PM |
| 2006 honda civic lineup pricing released | webby | Honda Industry News | 11 | 07-04-2006 07:12 AM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Driving Experience | 4 | 01-11-2006 03:40 AM |
| On The Track - 2006 Honda Civic - 8th Generation Civic 2006 Honda | webby | Honda Industry News | 0 | 08-07-2005 01:25 AM |
