what to do next?
hey guys, i've been a member here for a while now but am still a noob to fixing cars up. my fa5 is dropped on s-techs currently and my intention for this car is to mod it suspension wise only and not really for speed. i figured we live in cali and we cant really drive our cars as fast as we want cuz all the freakin laws we have. so i want to focus on suspension. what should i get next?
thanks in advance |
Louder than 4 F404-GE-400
Wait for Koni FSD shocks to come out and put those on. In the mean time, get 4 front camber bolts from Corsport and put them in. Get a shop to max out front negative camber (should be close to -2 degrees) and front positive caster (should be close to +8 degrees) and put the toe at zero all the way around. Big brake kits are a waste of money unless you plan to track your car at least once a month.
Also, read the highlighted blue threads at the top of this section and make an informed decision. |
good fluid is great, although if he is never actually pushing the car very hard for any length of time....then a much better fluid really isn't all that much of an upgrade.
and pads are good....just make sure you're not buying pads that operate best in a temperature range that you'll never see.... and i modify my suspension to go faster, i don't know about you... |
#8 (permalink) | |
I would think that if you're planning to have your car "handle like crazy", you're inevitably going to take turns faster, and in turn, drive faster. Obviously, upgrading your brake pads will increase your stopping, making your car safer for you and the other drivers on the road. So no, they are not useless.
#10 (permalink) | |
#11 (permalink) | |
thanks good info people. so what do i do first though cuz i dont have the money to get all of that at once?
#13 (permalink) | |
#14 (permalink) |
Just wait until the Koni yellows (FSD) come out and get some Ground Control springs. This will give you a little time to save up. Like others said, pads and fluid will be good but that should be a little latter down the line unless you plan on 40 minute canyon runs.
First thing to get is an alignment. The factory alignment is set up to push. Get 4 front camber bolts, 2 per side and put them in. Go to an alignment shop and tell them to max out neagtive camber in the front as well as mx positive caster in the front. Then set toe to 0 at all four corners. This is going to maximize the handling of the stock suspension for about 120 bucks. Once you get used to that, get some sticky tires or, if you can afford it, a lightweight wheel/tire package that is wider than stock, but not taller than stock, so no 18's. Then, once you get used to that, get the suspension. The best place to get used to all this suspension stuff is your local Autocross events. You really can't push it on the streets like you can here. Autocross is going to improve your driving skills too which is the best mod ever. If all this isn't enough, hit me up and i'll give you even more ideas. |
#16 (permalink) | |
#17 (permalink) | |
#18 (permalink) | |
Running lowering springs on stock dampers isn't necessarily a very optimal choice if your reasoning was strictly handling. http://8thcivic.com/forums/showthread.php?t=46108 http://8thcivic.com/forums/showthread.php?t=41081 Good reads.
#19 (permalink) | |
Don't worry at all about strut braces unless you are going to put R compound tires on your car and go racing in a class that doesn't allow roll cages. The sway bars should be last. If you get the ground control springs, you can chose the spring rate and shift the balance of the car a lot more than a sway bar can. |
