Old 05-08-2008, 01:38 PM   #121 (permalink)
Moose's Avatar
Originally Posted by mattsbobo View Post
Also Moose, I know you have no experience with the Rotora mini calipers, but I've read of others on the site using RSX-S brake kits on our cars, and that the two cars have the same brakes. Do you think the Rotora RSX kit will work with minor modification? http://www.rotora.com/press%20release/MINI4.pdf
One more thing, and I'll leave you alone. The description on the Rotora site for this kit says you can use the OEM rotors with it. Would this be advisable, or would it be better to get new rotors?
Rotora Does have a listing for the Si ....just download the catalog (Website is out of date)
FRONT BBK
RBK.143.01 - FC4 CALIPER - 330X23MM 1 PC ROTOR
RBK.143.02 - FC4 CALIPER - 330X30MM 2 PC ROTOR
RBK.143.03 - FF4 CALIPER - 355X32MM 2 PC ROTOR
FRONT REPLACEMENT CALIPER - WORKS WITH OE ROTOR
RCK.143.01 - FM4-C CALIPER
I personally would replace the rotors with new ... why groove / damage the new pads with an old rotor. At teh very least get the old rotor resurfaced.
Moose
Moose is offline   Reply With Quote
Old 05-13-2008, 04:18 PM   #122 (permalink)
smokenrowboy's Avatar
FMInterf00ler0_o
Excellent write-up, Moose. I'm an HPDE 2 driver, and choosing the right pads and upgrading to ATE Super Blue fluid are the way to go . And you gave some great advice when you recommended cleaning brake dust off before they corrode your finish. If I had known this sooner, my wheels wouldn't have little permanent black spots after each track day haha.
___
I've got two question for you (if you don't mind me asking):
1. Call it 'bling', but I want to replace my stock Si front rotors with Endless Basic rotors (Endless USA). Would an 00-05 S2000 application fit our OEM Si's? I guess I should probably ask Endless if the rotor is 300x25mm in Diameter x Thickness, since that's the size of our stock rotor.
2. Can you recommend any affordable caliper upgrade that fits OEM rotors (yet another bling question).
Thanks
smokenrowboy is offline   Reply With Quote
Old 05-14-2008, 12:14 AM   #123 (permalink)
Moose's Avatar
___
Thanks
I have "heard" that the S2000 will work .... BUT I cannot recommend as I have not tried this ... I have also seen numerous references that the RSX type S caliper Will work ... But again since I have not personally confirmed this I cannot confirm / reccomend.
The Only caliper that I am aware of that works is the Rotora RCK.143.01 - FM4-C CALIPER
Moose
Old 05-14-2008, 03:17 AM   #124 (permalink)
FMInterf00ler0_o
Thanks
Old 05-20-2008, 09:56 PM   #125 (permalink)
CIVIC's "R" US's Avatar
if you have drums outback, can you replace them with disc?
Sorry for not knowing or if this has been asked before...
CIVIC's "R" US is offline   Reply With Quote
Old 05-22-2008, 10:32 PM   #126 (permalink)
TurboBlue's Avatar
That's definitely a very informative write up Moose! But just curious..why did you not mention anything about SS brake lines? I went through your write up 3 times and saw no mention of it. Shouldn't that be one of the components to upgrade after pads and fluid?? And if im not wrong..SS brake lines just give you less pedal travel?
TurboBlue is offline   Reply With Quote
Old 05-22-2008, 11:37 PM   #127 (permalink)
Moose's Avatar
Yes ... you can do a rear disk swap (rotors/calipers/pads/knuckles/brake lines/abs sensors/e-brake lines etc)... either by purchasing the required components new or from a wrecked Si / EX
SS Brake lines are not a required part for a street car... more of a nice to have. They provide a slighty improved pedal feel with a bit less mush. You will see the biggest improvement with SS lines when you are replacing old worn out lines, rather than new lines.
The Si has WAY overboosted brakes ... there is little or no feel ... So SS lines really do not do much in my eyes for this particular car
I am going to try to fix the Booster issue before I fix the lines
Moose
Old 05-23-2008, 12:11 AM   #128 (permalink)
TurboBlue's Avatar
Moose
I see...but what do you mean by the si has overboosted brakes? So SS brake lines basically don't improve braking like upgraded pads would? Thanks for the help.
Old 05-23-2008, 12:12 AM   #129 (permalink)
Louder than 4 F404-GE-400
Paul
Moose
There better be a DIY for that, or else I'm coming out there and calling you names or something.
Old 05-23-2008, 07:26 AM   #130 (permalink)
Moose's Avatar
SS lines provide no additional performance / stopping power ... ONLY Pedal feel.
The Single best / cheap upgrade in performance is ... Good Pads and fluid.
BRING IT ON BELCH !!!!
Ya ... I am looking at some options ... I have to get a spare Si Booster and M/S and do some measuring ... I am hoping the S2000 booster will work. The M/C will be an issue becaase it is one of the few Honda M/C's with remote resevoirs.
The biggest issue right now is time ... and the Race scedule is keeping me busy (I am a Mechanic / crew member for a pro race team) So this side project may take a while ... I have "other" personal car projects that have priority right now.
Moose
Old 05-23-2008, 10:07 AM   #131 (permalink)
S52 > K20
St Jude
jrotax101's Avatar
Robert
Moose, would you say the SS lines are mainly feasible to use when the car is tracked a lot, just as a precaution from the oem ones splitting/blowing out or whatever , as all they do like you said is improve the pedal feel.
Mod+Pic thread
Originally Posted by Mike@ML-Works
I learned to not care about people who are scientifically retarded with the mental capacity of a tree.
jrotax101 is offline   Reply With Quote
Old 05-23-2008, 12:49 PM   #132 (permalink)
Moose's Avatar
The SS lines should provide better abrasion protection than OE ... Good condition OE brake lines are not likely to blow or split in any normal circumstances.
SS lines are not a bad thing, they will not hurt ... but they are way down on my list of things to upgrade brake wise, pretty much the last thing I will do UNLESS the OE lines are old / damaged and need replacing anyways
Moose
Old 05-23-2008, 01:54 PM   #133 (permalink)
racerx78's Avatar
Daddy
Moose
SS lines will not "dramatically" increase you braking capabilities. Especially if you have decent OE lines.
racerx78 is offline   Reply With Quote
Old 05-23-2008, 02:08 PM   #134 (permalink)
S52 > K20
St Jude
jrotax101's Avatar
Robert
I only replaced mine as the OE ones were rubbing against my coilovers ( pro-c) + the bit of extra piece of mind that they wont be as likely to fail, as i know what a brake failure at over 100mph feels like and head first into a tire wall. ( on a track)
Mod+Pic thread
Old 05-23-2008, 02:25 PM   #135 (permalink)
Moose's Avatar
I would also wrap the SS lines in Split loom ... it will further protect them.
This is what I did to protect my OE lines against rubbing on my Pro-C's
Moose
Old 05-26-2008, 05:50 AM   #136 (permalink)
Adri CiViC's Avatar
Why the aftermarket LX/DX/EX Front Rotor are 10,3" and OEM 10,8" ?
It will fit?
Adri CiViC is offline   Reply With Quote
Old 05-26-2008, 11:20 AM   #137 (permalink)
S52 > K20
St Jude
jrotax101's Avatar
Robert
Moose
I don't think i'd need to wrap them as they are already coated in something, it may be urethane or polypropylene, i'm not sure.
Mod+Pic thread
Old 05-26-2008, 01:38 PM   #138 (permalink)
Moose's Avatar
It will fit?
Hmmm ... My Data shows a 10.8" front rotor ... but the aftermarket says 10.3" ... not to sure what to say here. I will investigate further.
The Outer covering has limited abrasion protection and is really there to keep dirt etc out of the braid.
Moose
Old 06-02-2008, 03:16 AM   #139 (permalink)
VenomEX07's Avatar
Caliper Clearance for SI Front Brakes
Hi, I'm new to posting on this forum, but I've been browsing it off and on since I got my Black '07 EX Coupe 5spd a little over a year ago. I've finally gotten around to saving some cash for various mods(HFP suspension, SI sways) and was looking at the HFP brake kit. I know the SI's use a larger rotor then the EX, and I was wondering if this means that 17" rims are required to clear the caliper with those taller rotors. I'm sorry if this has been answered somewhere in here but I wasn't finding it on my search. Thanks much.
VenomEX07 is offline   Reply With Quote
Old 06-02-2008, 07:58 AM   #140 (permalink)
Moose's Avatar
Most 16" "Should" fit ... it depends on the design/shape of the hub and spokes
Moose
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 11:31 AM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 11:25 AM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 01:36 AM
DIY Front Brake Pads 60103 Suspension 76 06-30-2009 11:15 PM
ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only Excelerate Excelerate Performance 57 06-26-2009 12:09 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 5 04-02-2009 07:06 PM
DIY Parking Brake Adjustment 60103 Do It Yourself Articles 4 09-25-2007 03:42 PM
Minor Brake Upgrading 604_ep3 Suspension and Brakes 5 02-26-2007 12:13 AM
