Brake options - Page 6 - 8th Generation Honda Civic Forum
LinkBack (4) Thread Tools Display Modes
Old 04-28-2008, 09:17 PM   #101 (permalink)
Moose's Avatar
Originally Posted by Paco1120 View Post
hey Moose, great job on putting this info together.
i am in need of replacing my breaks and reading this gave a me a good idea of what i need to purchase, but wanted to make sure if its right before i go off and get it
i want to go with the axxis ULT in the front and rear and will be changing the brake fluid to Motul rbf600, can someone tell me if i will need to resurface the rotors or if new rotors will be needed. i dont do any autox, just looking for a good break upgrade. with that said would it be better for me to just buy the s2000 pads?? will the Axxix be overkill if i dont autox??
please pardon the dumb questions.. this will be the first time i do my own breaks and i'm kinda nervous.. haha
The Axis/PBR Ultimates are a good upgrade and very streetable.
Rotors, I generally reccomend that rotors be at the very least resurfaced, any iregularities in the surface (grooves etc) in the rotor will "cut" the new pads and wear them unnessarillly ... plus you will have trouble bedding in your new street pads over the existing pad material.
You also should check how much rotor (thickness) is left and what the run-out is. If it is close to OE limits, they have to be replaced.
If the rotors still have enough meat and are not grooved ...you can clean them up / knock down the high spots with a random orbital sander and some 100 grit sandpaper ...
IT may be easier / faster/cheaper/safer to pickup some new rotors at the same time ... Being a street car a set of AutoZone or similar OE replacement rotor will work well and not cost to much.
FYI - Pickup a copy of the Honda Helms manual ... it is chock full of critical info such as torque settings etc.
When you have the calipers off ... lube up the sliders with high temp brake grease ... it is something that should be done regularily ...particularily the rear calipers. I personaly swear by the PBR brake lube/grease.
If you are doing the rotors ...pick up a impact driver with the philips bit ... you will need it to remove the two rotor retaining bolts. If not you will probably have to drill out the retainig bolts ..they strip just looking at them.
You will also probably need a couple of extra 12mm? bolts to help "push" the rotor off the hub.
Moose
Moose is offline   Reply With Quote
Old 04-30-2008, 08:22 PM   #102 (permalink)
Im no brake expert and this thread has provided a lot of solid information. At the same time Im a little confused.
It seems there are more negatives then positives in regard to drilled/slotted rotors and BBKs in general. If this is the case, and this is where the confusion starts, why do so many OEM vehicles, which are intended to be daily driven and have similar weight to our Civics, come from the factory with drilled rotors in huge dimensions?
I would think that a brake system similar to our Civic's would be sufficient, if indeed a bigger brake set up with drilled rotors would produce inferior daily driven performance, not taking the front and rear brake bias in consideration.
Like I said, Im no expert, but this thread has just confused the hell out of me. Why the hell would the aftermarket develop BBKs for our cars, knowing that most of us would daily drive them anyway?
cornerstrike is offline   Reply With Quote
Old 04-30-2008, 09:13 PM   #103 (permalink)
Moose
thanks again Moose. i will probably be installing my new breaks this weekend. i will be going with the Axis, motul, and i will resurface my rotors. i will try to find the pbr rubber grease, do you think autozone carries it? and where can i get the 12 mm bolts from? dealer? and is there an impact driver you would recommend? lol, what a pain in the azz i am huhh!!
i also tried searching for a diy brake install, i found a couple that will help me out but none of them had actual pictures..is there one with pics? i trippen..
am i making this harder than it accually is?? i sound like a chick!!!
thanks
Paco1120 is offline   Reply With Quote
Old 05-01-2008, 08:48 AM   #104 (permalink)
Moose's Avatar
thanks
Any good high temp "brake specfic" grease will work ... I just really like the PBR stuff
Impact Driver: Sears
Craftsman Impact Driver - Model 47641 at Sears.com
To remove Rotor,
Using impact driver above loosen and then remove the two philps head retaining bolts
Sorry I said 12mm above (it is a 12mm head) it is a 8mm x 1.25(thread pitch) bolt ...which you should be able to pick up anywhere that stocks metric bolts.
As for proper instructions ... If you are going to be working on your car regularily I HIGHLY reccoemnd that you buy a copy of the Helms Service manual ... BUT for this weekend you can probabaly download a PDF copy of a RSX shop manual ... The TypeS the front and rear rotors and calipers are essentially the same ... therefore the process and torque settings should be the same as well.
Brakes are pretty easy ...You just have to take your time and make sure you do it right (Use a shop manual) ... remember it is your safety we are talking about here.
Moose
Old 05-01-2008, 09:06 AM   #105 (permalink)
Moose's Avatar
This is my theory ....
It is all about perception of what is better, and marketing a concept of high performance ... when you hear that the new "XXX" car come stock with Brembo's and x-drilled rotors .... you think WOW !!! it must stop really well ... THAT is A PERFORMANCE CAR !
Reality does NOT matter ... it is all about perception.
If look arround most people "really" want a BBK to "fill out the rims" and because it looks cool ...plus the bragging rights that they have "XXX" BBK. Only a small persentage of BBK buyers do so purely for the performance advantages.
Related to this ... Over the past 5-6 years we have seen a large increase in OE rim sizes ... 10+ years ago the average rim size was 14-15", 5-6 years ago 15-16" rims were the norm ...now 17-18 are very common. When you have big rims you "need" big rotors to "fill" in the rims so that it looks right. You have probably seen a EG civic rolling on OE brakes (9.5") with 17" rims .. it looks kinda silly (The small brakes look lost inside the rims)
The Aftermarket brake comapnies are just filling the demand for these parts ... If people will buy them, they will sell them ... the reason for buying does not matter to them.
Related to this, Cars have been getting heavier and heavier ... the Base civic in 1992 weighs about 2100# ..Now it is close to 2700# ...this requires EITHER more aggessive pads, or bigger brakes to dissapate heat generated when stopping a MUCH heavier car. Since Manufactures and most consumers do not like aggressive brakes, they increase the size of the brakes ..and they fil out the biggger rims ...making them look better.
Moose
Old 05-01-2008, 11:13 PM   #106 (permalink)
Moose
maybe i should just have someone do it for me...ha-ha
naw i'm going to try it,i've asked my buddy to give me a hand.. he's done brakes on these types of cars so everything should be ok. if not i can fly you down here from Canada to hook it up for me..
thanks Moose
Old 05-01-2008, 11:49 PM   #107 (permalink)
Moose,
I appreciate the reply. I can understand your theory about filling in those rims with bigger brakes, because small brakes with large rims look weird. But it cant be always the case. Correct me if Im wrong, but the DC2 Type R debuted as a 96 model with 15 inch wheels. In 98 Honda change the wheels to 16 inches and with it increase the size of the brakes as well. I doubt Honda make this brake change for looks only. Also, the rest pretty much stayed the same, with minor touches done to some suspension components and the final drive ratio, but nothing that would add enough weight that they would need bigger brakes. This is just my thought.
I myself am planning to start tracking my Si this summer. I was considering a BBK myself, both for more consistent braking(since brake fading seems to be a weak point of the Si) and looks, but after reading this thread Im too worried to screw up the brake bias of the car. I guess I will go a different and less expensive route. We shall see. Thanks again.
Old 05-02-2008, 12:06 AM   #108 (permalink)
Sirbelch's Avatar
Paul
Here is a BBK kit that was designed to work with the rear brakes.
http://www.8thcivic.com/forums/suspe...lwood-bbk.html
Old 05-02-2008, 09:42 AM   #109 (permalink)
Moose's Avatar
Moose,
Most of the USDM DC2 ITRs came with 15" rims (I think 16" were an option on the later ones) ... the JDM ITR'S came with 16" rims mostly
Brakes on the DC2 ITR were 11"F and 10" rear for the entire production run and could run 15" rims. The regular DC2's had 10.2" f and ~9.5" rear rotors.
The only variation in brakes for the DC2 ITR's was the 96 JDM ITR which was a 4x114.3 bolt pattern (I "think" they were also 11" front rotors ...but could have been 10.2") ... and that changed to 5x114.3 bolt pattern for 97 on.
Brake Fade is more a function of the Brake pads and fluid than the rotor / caliper. I would start with a good set of pads and fluid first ... it is way cheaper ... and IF that does not work out for you ... then look at a quaility BBK ... Keep in mind that not only do you have to pay for a BBK, but also potentially for more rims / tires that will clear the calipers.
If you are heavy into lapping then a dedicated set of rotors and good race pads is the way to go ... this way you have a streetable setup, and a setup that is good for the track.
It is dead easy to swap rotors and pads at the track ... 1/2 hour and you are done. I used to do it all the time.
Moose
Old 05-02-2008, 11:01 AM   #110 (permalink)
Moose
Thanks for the reply. Yeah, i was referring to the JDM DC2 previously. But Im pretty sure that the 98 model had an increase in brake size. In any case, I might just start with some pads and fluid first and see how that works. Just waiting for them to finally open the road course here. Thanks again.
Old 05-06-2008, 03:07 AM   #111 (permalink)
NJcivic06's Avatar
Hey Moose,
Quick question,
Am i going to need a torque wrench if I'm just changing the rotors and pads? A few years ago i changed the rotors and pads on my Altima and i never used a torque wrench, however I've seen it mentioned on a few websites.
Thanks
NJcivic06 is offline   Reply With Quote
Old 05-06-2008, 09:26 AM   #112 (permalink)
Moose's Avatar
Originally Posted by NJcivic06 View Post
Hey Moose,
Quick question,
Thanks
It is always a good idea / practice to torque to spec ... Honda prints torque specs on ALL their fasteners for a reason.
Moose
Old 05-06-2008, 03:05 PM   #113 (permalink)
Hey Moose, you'll be glad to know that the brake install went well. changed the Pads to Axxis ULT, Motul RBF, and lubed and lubed and lubed...does lubbing normally take a while??
i was being extra careful to not get any one the side of the pads and rotors... haha
overall a really good experience, and saving on the dealer installation cost is also great!!! they wanted like 450.00...
as for the new brakes, feels much better!!! i dont think ill be going back to regular honda pads ever again..
these axxis have much more breaking power, better pedal feel, no noises yet but they are much dustier than OEM pads, but its all good.... ill just clean them more often..no biggie
thanks again Moose
Old 05-08-2008, 09:24 AM   #114 (permalink)
just curious, but how is it that this BBK is designed to work with the stock rear brakes, when other BBKs are not? Its just kind of strange that only one company would design a kit that does not interfere with the brake bias, instead of everyone designing their kits like that.
Old 05-08-2008, 09:37 AM   #115 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
"Stance"...The new jockstrap
From what I understand, it's not designed to work with the rears.
Old 05-08-2008, 11:27 AM   #116 (permalink)
Moose's Avatar
thanks again Moose
Great ... I am glad things went well and you are happy with the results
There is NO aftermarket Rear BBK that will work well with most cars for a couple of reasons ... there is no rear aftermarket multi-piston caliper that I am aware of that has provisions for a e-Brake / parking brake. It just cannot be easily done. This is a rather large safety issue, that can get your car pulled off the road by the POPO
The brake bias is the other issue. They have to be properly designed to work with the system as a whole, most are not ...they are just off the shelf components with the appropriate adaptor brackets
Related to this ... there is NO need to upgrade the rear cailpers/rotors for any street driven car, pads are all you will ever need. The rear brakes do SO little of the overall braking that they are not even close to be over-streesed.
On one of the race cars I am working on currently ... a heavy pig at ~2600 #'s goes thru front brake components very quickly, while the rear's have not been changed (nor do they need to be - 75% of the pad and rotor is left) in over three years of track abuse.
Moose
Old 05-08-2008, 11:31 AM   #117 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
Moose, didn't you say the best BBK (as far as brake bias was concerned) was the Rotora 4piston mini caliper?
Old 05-08-2008, 11:34 AM   #118 (permalink)
Moose's Avatar
Based on some initial calculations it "Appears" that the Rotora Mini Caliper upgrade will be close in performance to OE (F/R bias) ... I have not taken a closer look as I am not planning to do this upgrade as of yet.
Moose
Old 05-08-2008, 12:10 PM   #119 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
Moose, I'm sure you're not a smoker, but you could really use these:
Autoart ashtray (top half of caliper comes off so you can store your smoking supplies). Smaller rotor ashtry, and rotor coasters with metal caliper holder were part of a Camel cigarette promotion
Also, the Autoart ashtry is a 2 piece, vented rotor
Old 05-08-2008, 12:51 PM   #120 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
Also Moose, I know you have no experience with the Rotora mini calipers, but I've read of others on the site using RSX-S brake kits on our cars, and that the two cars have the same brakes. Do you think the Rotora RSX kit will work with minor modification? http://www.rotora.com/press%20release/MINI4.pdf
One more thing, and I'll leave you alone. The description on the Rotora site for this kit says you can use the OEM rotors with it. Would this be advisable, or would it be better to get new rotors?
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
Suspension and Brakes on 8th Generation Honda Civic Forum | BoardReader This thread Refback 07-24-2011 09:03 PM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 12:31 PM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 12:25 PM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 02:36 AM
DIY Front Brake Pads 60103 Suspension 255 02-02-2012 12:22 PM
ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only Excelerate Excelerate Performance 85 07-05-2011 03:40 PM
DIY Parking Brake Adjustment 60103 Do It Yourself Articles 11 09-26-2010 11:17 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 5 04-02-2009 08:06 PM
Minor Brake Upgrading 604_ep3 Suspension and Brakes 5 02-26-2007 01:13 AM
