#381 (permalink) |
Hi Moose, u should try Endless CC-X or CC-R for ur next pads. To me, they are a big upgrade from HP+ that I was using previously. You might like them too over project Mu and HP+.
To me, surely the HP+ stops decently and is a big improvement over stock pads, but they squeel a lot throughout their entire lifespan and also eats my rotor like crazy. I tracked about maybe 4-6 times with them and those pads only lasted me about 6-7months, including winter. The endless pads works great. I track on avg 3-4times a month and the CC-X handles it really well. The CCX pads never squeeled after i fully broken them in, friendly on the rotor, and they were awesome on the track too (much better than hp+). On the street, they are kinda overkill, but nothing beats being able to stop on a dime. The CCR that im using right now are suppose to be an even more aggressive pad but still maintain it's DD function. On the track they are just awesome. A noticable improvement over CCX, and it also have a higher operating temperature so i can have more confidence in stepping on my brakes hard (i do like hardbrake/late braking when im racing or doing Time Attacks) without worrying about overheating my brakes(which i had an issue with in the past). In terms of pads life, it's still too early to tell so i will give u and update on it later when im done with them. So in conclusion, if u are looking for a track worthy pads that can still be daily driven, these are just perfect, and are my recommendations. Note : Pads, that I tracked with includes (In upgrade sequence), OEM < HFP < HP+ < Endless CC-X < Endless CC-R Last edited by agentragex; 09-24-2008 at 07:23 AM. |
#382 (permalink) |
ok i dont really feel like reading through 10 pages of posts but I was wondering if anyone has experience with the brake lines available for the Si? I'm looking at the corsport one but i don't really know much or have heard much about them. I'm down to try the other brands too just don't know which one is "good" and has a sleeve or whatever it is to keep the dust out of the braids. So if anyone with experience of any could chime in...
![]() thanks
#384 (permalink) | |
S52 > K20
Robert
Toan - corsport ones are good.
![]() Mod+Pic thread Quote:
#388 (permalink) | |
Sounds good...I might look into these pads! Where do you get them from? I couldn't seem to find them for the fg2. If they are so much better like you say...you sure they're not corrosive to the rotors? I have Hawk HPS...not any good at all man. Feels exactly the same as OEM pads. lol Last edited by TurboBlue; 10-18-2008 at 06:47 AM. |
#389 (permalink) |
2006 Acura TSX Front Calipers / Rotors / Pads on a 2006 Civic Si Knuckle
![]() Brake Comparasin Rotors: Si Rotor 25mm thick (300mm diameter) TSX rotor 28mm thick (300mm diamter) - 11% thicker Noticably more rotor mass, and bigger cooling passages Si Rotor Weighs 14.6# TSX rotor Weighs 15.2 # Not alot more rotational inertia to overcome ![]() Pads: Si Pad (bottom)vs TSX Pad (Top) Si Pad is 4.75cm x 10.03cm friction size, 47.6 cm2 surface area TSX Pad is 5.1cm x 12.5cm friction area, 63.8 cm2 surface area - 26% larger ![]() Caliper Si Caliper(left) VS TSX caliper (Right) Hard to see here .... but the TSX Caliper is so much more massive Si Caliper weighs 6.8# + 2.9# for bracket = 9.7# total TSX Caliper weighs 8.6# + 4# for the bracket = 12.6 # total ![]() ![]() ![]() Bottom line WAY more thermal mass in the rotors, calipers, and pads to dissapate heat Si Piston OD - 5.3 cm - Surface area 47.2 cm2 - piston surface area to pad surface area ratio 2.13:1 TSX Piston OD - 5.6 cm - Surface area 63.75 cm2 - Piston surface area to pas surface area ratio 2.6:1 Moose Last edited by Moose; 11-17-2008 at 09:19 PM. |
#392 (permalink) | ||
Moose |
#393 (permalink) |
Thanks for the great info Moose. Did you just convert the front, or are you doing the back brakes as well? Sorry to re-ask the same question from earlier, but did the TSX brackets simply bolt up, as well as the calipers? One more thing, what did a set of TSX brakes run you?
#396 (permalink) | |||
EVERYTHING bolted up (Caliper bracket / Caliper / rotor/ pads) no mods, no machining, no BS - The only issue is the dustsheild - it needs to be trimmed a bit for clearance arround the caliper itself. Under $500 CDN shipped bought me 2 remanufactured (by Cardone) OE (Nissin)TSX calipers, 2-OE Jobber TSX rotors, 1 set of TSX PBR ceramic pads. FYI - I get better than jobber pricing thru a contact of mine ... street prices may be higher. You can also save a couple of bucks by hitting the wrecker for a nice set used calipers / rotors/pads. Quote:
As a note - Order the 2006 TSX Rotors/Calipers/Pads .... they changed in 08/09 Moose Last edited by Moose; 11-18-2008 at 02:11 PM. |
#397 (permalink) |
Moose, as always, you provide invaluable info to the masses of the 8th. I wish I could still give you rep, but your bars would probably go off the screen.
Moose, will you be with Compass 360R again at VIR next year? I saw a picture from SEMA of the orange FA5 I imagine they'll be running next year, and it looked mighty hot. |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 11:31 AM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 11:25 AM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 01:36 AM | |
| DIY Front Brake Pads | 60103 | Suspension | 76 | 06-30-2009 11:15 PM |
| ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only | Excelerate | Excelerate Performance | 57 | 06-26-2009 12:09 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 5 | 04-02-2009 07:06 PM |
| DIY Parking Brake Adjustment | 60103 | Do It Yourself Articles | 4 | 09-25-2007 03:42 PM |
| Minor Brake Upgrading | 604_ep3 | Suspension and Brakes | 5 | 02-26-2007 12:13 AM |
