Old 07-23-2008, 12:39 PM   #301 (permalink)
Originally Posted by jrotax101 View Post
^^ Making me jealous.. I wish i had enough $$ for tires at the moment.. damn hytech header.
On a side note, UPS came for me too today, they brought my " I Void Warranties" t-shirt so i can wear it when i go into honda..
i think the only thing left on my warranty is the interior..
Where did you get that shirt? That is awesome!
DRIVEN1 is offline   Reply With Quote
Old 07-23-2008, 12:40 PM   #302 (permalink)
jrotax101's Avatar
Robert
ThinkGeek :: Stuff for Smart Masses getting a " Keep out of Direct Sunlight" as i have really fair skin and burn when it rains.. haha
Next Project : E36 M3 boosted track car
fawk.. if my volks were hyperblack/formula silver.. my ballz would jump out and blow my pee pee
jrotax101 is online now   Reply With Quote
Old 07-23-2008, 12:54 PM   #303 (permalink)
Thanks
Here is a picture of one of the wheels. I think I will take the trak sticker off now while they are nice and clean. The tires look nice.
The wheels are 14.6 pounds and the tires are 21 pounds. When I get home later today I will weigh them. Going to install some suspension stuff, hopefully come home with all my knuckles.
Old 07-23-2008, 12:57 PM   #304 (permalink)
jrotax101's Avatar
Robert
are they really 17x8?
Old 07-23-2008, 01:00 PM   #305 (permalink)
THat is what was ordered. The tires having no weight from the car on them are not flat like the tires on the car. I will try to measure them when I get back.
Old 07-23-2008, 01:00 PM   #306 (permalink)
jrotax101's Avatar
Robert
they look good man, nice to see another fiji 4dr being readied for the track. We're prolly the only ones on the forum.
Old 07-23-2008, 01:03 PM   #307 (permalink)
After I put the suspension stuff on today and get the alignment the next day,the car should be handle well. All of my track rotors and pads show up at the end of the week. Now I just need an open date for an event and I will be ready. We will have to get them on the track together!
Old 07-23-2008, 01:53 PM   #308 (permalink)
Moose's Avatar
Originally Posted by DRIVEN1 View Post
Thanks
Nice ....
THAT is a stupidly clean Garage ... WRONG WRONG WRONG ... Call yourself a ""car-guy" !!!!
Moose is offline   Reply With Quote
Old 07-23-2008, 05:42 PM   #309 (permalink)
Originally Posted by Moose View Post
Good link !!! (Volvo) ... I am going to use it one page one in my Fluid overview
Thanks !!!
Moose
I found it completely by accident in a post on another board I had made three years ago by doing a Google search.
Old 07-23-2008, 05:53 PM   #310 (permalink)
So how long did they last? Do we even need to have them on there?
That depends. They may last the life of the car if you just commute, or, like me, you may notice them being toasted during the first year if you beat on it. I replaced my calipers with remans from Auto Zone, but they just cracked again. I probably drove them that way for 90,000 miles, but I didn't have any winter to worry about except for a week each Christmas to visit family.
I'd kinda like to hear what Moose does to rebuild his, since I've heard that rebuilding Honda calipers is a complete PITA when it comes time to get the dust boots seated unless you've got some specialty tools. I skipped that hassle by swapping calipers and it cost around $40 each after core charges were refunded. Probable costs more for the Si, since brake parts are much more expensive for it than an Integra.
I should note that I use gummi pflege on the dust boots (and any CV boots) when I do a brake job to help keep the rubber flexible and lubricated. I haven't seen any cracking in 26,000 miles, but I don't drive quite as hard and I believe that the rotors don't get quite as hot for when I do as in an Integra with 10.3" front rotors that only weighed 250 lbs. less than the Si.
Old 07-23-2008, 06:14 PM   #311 (permalink)
Nice ....
That is one two car garage. The other two car garage has awesome cabinets on all walls where I can keep all the tools and crap. The wife does not like clutter in there. But yes I do like to keep it clean and hose it out once a month. The wife calls me anal since I wash my car in the garage to stay out of the sun.
Old 07-23-2008, 06:18 PM   #312 (permalink)
Moose's Avatar
If you are further south and you do not get "winter" per say then your car will last longer ... and the parts. Up here in the North end of the continent it is below freezing regularily about 4 months of the year, add the salt that they use on the roads to keep them clear of snow and ice and you have a corrosion issue.
On my past Cars I also just did remans ... BUT the Civic / Teg calipers were cheap and easy to find. This caliper is not so much, and a I assume that it is pricey as well.
The Rebuild is not to bad ... $22 for new seals and gaskets, and about about $30 for a piston bore hone.
All you need is an air source to pop the piston out of the caliper.
First things First BUY a HELMS Shop manual ...it is the best $100 you can spend if you intend to work on yor car
Basically you remove the caliper and then caliper bracket from the knuckle and temporarily plug the brake line.
Bring it to your work bench and do following
Caliper
-Drain the excess fluid out
-Remove the pads
-Clean the loose crap off the calipers with a soft wire brush and brake cleaner
-Lay down clean rags / paper on the work surface to keep dirt away
-Put a block of wood in the caliper where the rotor would normally sit and apply air to banjo bolt fluid inlet
9A rubber tiped air nipple works best) ...this air pressure pops the piston out (watch you fingers) ..... the wood stops the piston from going to far and damaging itself.
-Remove the piston, remove boot/seal from the piston, and put it aside
-Carefully remove the old seal/o-rings, from the bore becarefull not to scratch or damage the bore
-Clean the bore with brake cleaner
-Inspect the bore for rust / damage ... clean up the bore with the hone if nessessary. If it is badly damaged ... then reassemble and look for a reman, and use this as a core.
-Clean really well and apply a LIGHT coating of brake fluid to the bore to lube it, and install the new seal/o-rings (lubed up with brake fluid)
-Inspect the piston - if it is scored or damaged - replace it
-Clean up the piston, apply a light coating of brake fluid to the dust boot and install it on the piston, lube piston with brake fluid, and slip it into the bore
-Paint the exterrior of the caliper up with high temp BBQ paint if you like. (Clean well first with Brake cleaner)
-Caliper is basically done
Caliper bracket
-Clean the loose crap off the caliper bracket, with a soft wire brush and brake cleaner
-Pop the slider boots off
-Clean the sliders REALLY well, and remove (carefully any rust) - do NOT scratch or remove the protective coating. If they are damaged or scored, replace them
-Lubricate REALLY well the slider with high temp synthetic brake Lube - I really like the PBR stuff
-Install the new slider boots
-Paint them up with high temp BBQ paint if you like. (Clean well first with Brake cleaner)
Re-attach the caliper bracket to knuckle, torque to spec
Re-Attach the caliper to Caliper bracket, torque to spec
Install brake pads
Attach brake line and torque to spec
Bleed brakes
EDITED after checking the Honda Shop Manual (Helms) - no special tools required except what is noted above ...
Taaa Daaaa
Moose
Old 07-23-2008, 06:26 PM   #313 (permalink)
jrotax101's Avatar
Robert
You dropped yourself in it now moose - so many questions so little time
How/with what do you plug the brake line with?
Old 07-23-2008, 06:31 PM   #314 (permalink)
Moose's Avatar
I plug the hole with what ever I can find that fits
Actualy I have some tapered rubber plugs that I got somewhere that work well ... You can also use an old banjo bolt with some Electrical tape arround the shaft to block the hole and to provide a tighter fit, or a peice of fuel line / vac line / random small hose you have lieing arround.. I then Wrap tightly the entire head of the banjo bolt tightly with a HD Ziplock bag ... the trick is to not allow "space" for the fluid to flow into. The bag also captures any fluid that leaks out, so it does not drip onto something important
#21 is the rebuild kit (Seals etc)
Moose
Old 07-23-2008, 07:58 PM   #315 (permalink)
Moose's Avatar
Edited the Rebuild process with more info based on checking the Honda Service Manual (Helms)
Old 07-23-2008, 09:51 PM   #316 (permalink)
Thanks. I already have the two volume set.
Old 07-23-2008, 10:00 PM   #317 (permalink)
Did you buy from Helms direct or is there somewhere cheaper to buy?
Old 07-23-2008, 10:11 PM   #318 (permalink)
Moose's Avatar
I bought mine here .. $90-100+ shipping
Shop Manual | Owners Guide | Restoration Book
Helms wants $125 new + SHIP
Helm Incorporated: Search Results
Moose
Old 07-23-2008, 10:15 PM   #319 (permalink)
Moose
Thanks, they are $125 from Helms direct. Put the front camber bolts, rear sway bar, and rear camber arms on today. Going to get the alignment in the morning. I am thinking -2.25 in front and around -1.75 in the rear. Scared to go the -3.0 that you running with the good street tires that I am running right now. Well I guess I will see what they can do when they do it.
Old 07-23-2008, 10:33 PM   #320 (permalink)
I paid ~$80 from Helms a year ago, but either we're dealing with Canadian pricing, or the price went up since then.
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 12:31 PM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 12:25 PM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 02:36 AM
