#281 (permalink) |
I didn't feel like reading whole thread so here is my question... Would stock NSX brakes work on our car and would they provide better braking? Are the rotors/calipers bigger? Has anyone tried it cuz I'm sure you might be able to find some cheap cuz i'm willing to bet that alot of those rich guys have upgraded their brakes?
#282 (permalink) | |
Winter ... Pfffff ... First you are Wet and well ... Wet in the UK ... now you are humid and hot .... As these are fairly new cars ..they "should" be fine for a while ...however ... -Caliper rebuild - full flush - and I normally repaint the calipers, rotor hats, and rotor vanes with high temp BBQ paint (tremclad) to keep the rust at bay. -Inspect all the bushings, replace where nessesary -I normally dissamble the coil-over assemblies, clean them up, anti-seize and re-assemble, checking for leaks, bad seal, or excessive play -The Upper Camber plate Mono-balls have to kept an eye on ....they tend to get excessive play in them over time, and need to be replaced fairly often. -I check the motor mounts as they can tear / wear over time -Check all wheel bearings for excessive play and run-out ... ONLY use OE as I have had early failure with NON OE wheel bearings and hubs - THis is Important -Inspect the wheel studs ... with the number of wheel changes we do, it is easy to strip / bend etc them. At the same time check your lug nuts ... see if they thread on nicely or not ... if you have to much resistance with a particular lug or stud ... it should be replaced. -Hubcentric rings .... the plastic ones tend to melt / warp -Race rims ... have them spun up to check balance etc ...both the tire and rim can go out of round. -Coolant - Flush and fill. -Inspect Balljoints for play and tear in the boots -Inspect CV's for play and wear in the boots Thats about it ... Accelerated general maintenece and a good visual inspection of all brake and suspension systems. Moose Last edited by Moose; 07-23-2008 at 09:30 AM. |
#283 (permalink) | |
NSX - Not likely without a fair bit of work ...the calipers are a direct replacement only for the Integra Type R, Accord Wagon, Vigor, CRV and similar earlier 11" 5 lug front brakes ... not for the Mac Strut FG/FD cars In reality all you need is good tires, good pads, and good fluid to improve braking perfomance Moose Last edited by Moose; 07-23-2008 at 12:13 AM. |
#284 (permalink) | |
Haywood Jablomi
I cooked my dust seals on my last Integra in street driving. |
#285 (permalink) |
Hey Moose,
Im still very new to all this information regarding brake fluids and I was going to be changing my brake pads soon. I was just wondering, is it ok to mix an aftermarket brake fluid with the OEM brake fluid? Any idea which brake fluid out there (not a racing brake fluid) has the same DOT or contents as the OEM brake fluid? Or is it best to just flush the whole system and add new brake fluid? Thanks! |
#286 (permalink) | |
Haywood Jablomi
I recommend Valvoline Syntech DOT4 and that's what I use. It's probably the best over-the-counter brake fluid you can commonly find at any chain auto parts store. Last edited by FALer; 07-23-2008 at 02:38 AM. |
#287 (permalink) | |
#288 (permalink) | |
Haywood Jablomi
OEM fluid is DOT3, FWIW. |
#290 (permalink) |
Haywood Jablomi
Brake Fluid Comparison
The new Valvoline DOT 3 & 4 synthetic formula has a dry BP of 503 and a wet BP of 343. http://www.valvoline.com/products/Va...ke%20Fluid.pdf Last edited by FALer; 07-23-2008 at 03:16 AM. |
#291 (permalink) | |
Good link !!! (Volvo) ... I am going to use it one page one in my Fluid overview Thanks !!! Moose |
#292 (permalink) | |
BTW - Thanks for responding to Turbo Blue Moose |
#293 (permalink) | |
#296 (permalink) |
So they are tolarable? I think I will order those then for the street and see how they do.I have to assume that they brake a lot better than the stock ones on the street. When they are cold still grab pretty good. Not that it is ever cold in Florida. |
#298 (permalink) | ||
YUP - They sweak / squeel occationally when cold,and you are stopping with only a little pad pressure ... I have found that a couple of hard stops, cleans them up and gets rid of the noise. Using anti seize on the backing plates ears, and some anti-squeal paste on the backing plates minimises this Quote:
![]() They will perform WAY better than OE on the street ... they a a great pad. Moose |
#299 (permalink) | |
On a side not the UPS man just pulled up and unloaded the track wheels and tires. It feels like christmas here in FLorida. |
#300 (permalink) |
![]() Join Date: Jul 2007
^^ Making me jealous.. I wish i had enough $$ for tires at the moment.. damn hytech header.
On a side note, UPS came for me too today, they brought my " I Void Warranties" t-shirt so i can wear it when i go into honda.. ![]() i think the only thing left on my warranty is the interior.. |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
| Suspension and Brakes on 8th Generation Honda Civic Forum | BoardReader | This thread | Refback | 07-24-2011 09:03 PM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 12:31 PM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 12:25 PM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 02:36 AM | |
| DIY Front Brake Pads | 60103 | Suspension | 255 | 02-02-2012 12:22 PM |
| ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only | Excelerate | Excelerate Performance | 85 | 07-05-2011 03:40 PM |
| DIY Parking Brake Adjustment | 60103 | Do It Yourself Articles | 11 | 09-26-2010 11:17 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 5 | 04-02-2009 08:06 PM |
| Minor Brake Upgrading | 604_ep3 | Suspension and Brakes | 5 | 02-26-2007 01:13 AM |
