#241 (permalink) |
![]() Join Date: Jul 2007
Robert
The KDW's do not last on a track, you were sensible going with track tires.
here are mine after 30 laps ( 1minute 10 each) ![]() track wheels/tires are much cheaper in the long run.. unless u want new street tires every 2 track days.
![]() Next Project : E36 M3 boosted track car Last edited by jrotax101; 07-21-2008 at 12:11 PM. |
#242 (permalink) | |
I saw what happened to those stock tires in such a short time on the track and that is what made up my mind. Expensive up front but hopefully better in the long run. Are the PBR/Axis Ultimates quiet enough on the street to pass the wife test? Also what did you say would be good starting pressure for the track tires? I ended going with the Pilot Sport Cups to try to get some decent use out of them. |
#243 (permalink) | |
I want to get at least at year or longer out of my street tires, and since they won't see the track I thing that I am not asking too much out of them. |
#244 (permalink) | ||
PBR/AXIS Ultimates are much more quiet than the HP+ ... Only in Winter do they get a "bit" noisey ... but this is in Canada, and our winters are much colder than yours. Quote:
My Hankook Z212 looked worse than Jrotex's ... beleive it or not after about 20 hot laps ... In part becuase i did not have enough camber. In part becasue they are full tread depth ... and the "squirm" you see with full tread depth tires (Not shaved) builds WAY more heat. |
#245 (permalink) |
[quote=Moose;3305547]You may want to reseach on the Pirrelli Site for their range of reccomened Hot temps. It will vary by Manufacturer/Tire model. My Toyo RA1's like to be about 36 PSI hot, so I start at about 26 Cold allowing for 10 degree's of temp increase (Air Fill) ... you should see less PSI increase with a Nitrogen fill. With that said arround a 37 PSI hot should be a good starting point for you. A Probe Type Pyrometer and a good air gauge will help you tune for the best hot PSI
PBR/AXIS Ultimates are much more quiet than the HP+ ... Only in Winter do they get a "bit" noisey ... but this is in Canada, and our winters are much colder than yours. Okay I will do some research to see what they recommend. I will have to buy a good pyrometer . Hey we get cold winters! I think we got under 40 last year. Don't know how you survive those cold winters. |
#247 (permalink) |
Robert
Moose -
![]() now i just need the tires ![]() bad news.. the guy i bought them from didn't send me any hubcentrics :insertmadsmileyhere:
![]() Next Project : E36 M3 boosted track car |
#250 (permalink) |
Robert
No, i told him they were needed, he said they were never on.. however they are needed.
I'll get them from tire rack - hopefully they know the correct size needed
#252 (permalink) |
Robert
Once i recover from the $1400 withdrawl to Hytech
![]() out of curiosity, what else do you drive? bearing in mind your mugen has 2xx miles on it.. and i have 18000 on mine in a year
![]() Next Project : E36 M3 boosted track car Last edited by jrotax101; 07-21-2008 at 07:36 PM. |
#253 (permalink) | |
![]() ![]() Last car before that was this 300 SRT8 with a 6.1 liter 460hp(no governer and it would do just under 180) ![]() ![]() ![]() This was my favorite most recent car, ran low 12s with a crappy stock clutch back in 2003. ![]() ![]() I think this was a 12.5 run against a big hp cobra, clutch was slipping real bad at this point and was kind of hard to launch. Never posted a video thru photobucket so not sure if this will work. ![]() Everything else is in something called a photo album. It is a hard concept to understand anymore. But there was a time when we would print our pictures and put them in our car album. If I could get them onto the computer and looking good I would probably do that. But I am not the computer genius in the family. |
#254 (permalink) |
Robert
nice selection. my girl has the excursion with the 7.3l engine in, so i know the costs on them are a nightmare.
i was at road atlanta with a srt8 . the tag was MYSRT8U nice evo too :)
#255 (permalink) | |
Funny tag. I loved the EVO and would surprise allot of people with that car. Were you able to see the video or not? That guy is the cobra was my buddies dad and was saying that he runs in the 11s all the time. These was no way he would lose to a 4 banger. He was not happy after that run was made. |
#259 (permalink) |
Robert
GM W-Car Rear Caliper Piston Retractor
will work also - and then there is always a big screw driver like i use.
#260 (permalink) | |
Different subject, did you take the diffuser off when putting on the lower arm bar or did you trim it? If you trim it what did you use? |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/62478-brake-options.html
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 12:31 PM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 12:25 PM | |
| I need brakes/Sways - ClubSi | This thread | |||
