#221 (permalink) | |
Been about 7 years and it was on the Alcons on my Audi. I am hoping that it is like riding a bike. Got a impact driver, I am hoping that since the car has 200 miles on it right now that nothing is too rusted up yet. |
#224 (permalink) | |
Use one of these (I bought mine at Pep Boys, but Sears has/had them too) Lisle tools to twist them back in:
#228 (permalink) |
Just make sure you X-reference with multiple vendors ... IF 3-4 differnt brake vendors say that they are the same you are pretty safe assuming that the parts are compatible ... but if there is only ONE vendor saying you are compatible, be wary ... I have seen some errors
Moose |
#232 (permalink) |
I Just spent the evening at Shannonville Motorsport Park, I local 2.5 mile / 4 KM track. I installed a set of track only Pads, as I was not happy with my current Dual-duty pads, that I found got a bit "soft" after multiple laps.
I installed a Set of front Hawk DTC-60's ... their latest compound. Wow ... while not as initialy aggressive(bite) as the Hawk Blues, they grab hard, and were VERY consistant, never going off or soft on me ... EVEN when I was punishing them. I pulled them at the end of the evening to swap back to the Street setup and they looked great, no excessive wear ... and happly there was no where near as much dust as I was seeing with the Hawk Blues ... Two Thumbs UP !!!! Moose Last edited by Moose; 07-21-2008 at 09:51 AM. |
#233 (permalink) | |
I could not find the DTC60 in stock anywhere, so ordered the HT 10 Compound Temp Range: 300-1,300 degrees Fahrenheit Torque: Intermediate to high Recommended Use: Road racing or pavement circle track use that requires more torque than Blue 9012. Going to try these in the front with track rotors and the hawk plus on the rear doing track and street duty. So it sounds like you are making the switch and leaving your old blues to the side? Where did you get the DTC60? Do you think that the DTC70 would have too much torque? I am so jealous that you got to go the track yesterday. I was sweating in the hot Florida air yesterady putting in the short shifter and bushings. Last edited by DRIVEN1; 07-21-2008 at 09:55 AM. |
#234 (permalink) | |
I am currently running Project Mu B-Force in the rear ... similar to the Hawk HP+ I have officially made the Switch from Blues to DTC-60 ... I do miss the inital "bite" of the blues, BUT i do not miss the difficult modulation that the Blues had ... The DTC are MUCH easier to modulate and the ABS was NOT freaking out. The HP+ out back should work well with the HT-10 ...they need / want less heat than a Race pad The DTC-60 also Dust WAY less than the Blues ... BIG THUMBS UP !!! The track was fun .. but I spent allmost 5 hours (there and back) traveling for about 2 hours of track time ... But it was worth it. HOWEVER I may have pooched a front wheel bearing in one of my " off track adventures" I do not want to know how much this is going to cost me. I got my Hawks from my local Hawk Distributor, here in Toronto, Canada ... Northern Motorsports. They have stock in EVERY compound that Hawk carries for the RSX-S / 06 Si / S2000 Moose Last edited by Moose; 07-21-2008 at 10:05 AM. |
#235 (permalink) | |
But at least you got 2 hours of track time. That is why I don't autocross, spend all day to get less than 5 minutes of track time. If I am going to bake all day in the heat I want to get 2-3 hours of track time a day. I am lucky that I have Sebring about 2 hours from my house or can go down to Homestead if I want to drive 4 hours. Can also get to Moroso or Daytona in 3 hours. I wonder if your guy will ship to Florida. The couple people that I tried from the Hawk website did not have them and could not give me an answer when they would get them. Hopefully I will be happy with the HT10 and it will not be an issue. I ordered two sets of them since not sure how long they will last at track and don't want to cut a day short. How much fluid do I need to change the fluid out? I just got a liter of Castrol SRF. I am assuming that will be enough to do a complete flush and one or two events? So what does that wheel bearing feel like now while driving? Last edited by DRIVEN1; 07-21-2008 at 10:15 AM. |
#236 (permalink) | |
![]() Quote:
I am not to sure about how corrosive the HT-10's are ... Pete (my contatct below should know, if not you could talk to Hawk directly Northern Motorsport Automotive Parts And Accessories Talk to Pete Mills (Say Moose sent you) ... They have a US Wholesale Warehouse, so they "should" be able to ship to you I used about 3/4 of a bottle (1 litre) of SRF to COMPLETELY flush and fill the system. So you should be good to go. The Wheel bearing is Noisy as F**K ... sounds like I have an exhaust leak .. I CANNOT get the stereo loud enough to hide it ![]() Moose Last edited by Moose; 07-21-2008 at 10:35 AM. |
#237 (permalink) | |
I will call Pete when I need some more and see what he says. Does the car drink any brake fluild while at the track? Do you have to top it off after some driving? I have never been in a car with the wheel bearing making that much noise. Hopefully you do not have to drive it on the street long before you get it fixed. I was going to get an alignment done this week. So what do you think? I would rather not have to dismount tires and remount them every couple thousand miles but want as aggressive as possible. So with that being said -2.0 in front and rear? Or more negative in the front? -2.5 front and -2.0 rear? |
#238 (permalink) | |
If you are doing a lot of lapping then go aggresive as you can in the front ... it will save your tires. If your toe up front is not to aggressive then the overall street wear will not be to bad (Toe is more aggressive wear wise than Camber) ... just rotate your tires more often to (front to back and flip them on the rim. One good lapping session with not enough camber will TRASH a set of street tires ... TRUST Me ...I finished a Set of new Hankooks with minimal camber after 2 hours of lapping. I used to run -2.7 F and -2.0 rear on my old daily driver / Track Whore (EG Hatch) ... with no excessibve camber wear .... now I am running -3 all arround since this car NEEDS more front camber ... Based on my last lapping session and my aggressive driving style ... -3 F is about right for me. I street drive on cheap street tires so any excessive wear does kill me $$$ wise. BUT is saves me HUGE $$$ in track tires. Last edited by Moose; 07-21-2008 at 11:18 AM. |
#239 (permalink) | |
I hope that I don't have to bleed them after every session. In between sessions I want to be drinking gatorade sitting in the shade relaxing. Also what pads are you running on the front on the street? Since I will be running those Hawk plus in the rear, wondering if I should run something little better than stock on the front. The only thing is I don't want squeeling on the street, could care less about squeeling on the track. Was wondering if the Hawk HPS for the front on street would be a good choice or just save the money and wait until the front stock ones wear out. You don't think that the stronger HP plus in the rear with stock fronts will throw off the bias do you? What do you set your toe at? I bought some track wheels and tires, so I don't kill the nice stock ones that came on the Mugen. Figure if I am going to be swapping out rotors might as well put some different wheels and tires on. |
#240 (permalink) | |
The Best cheap option for the street is the PBR/Axis Ultimates ...they are almost as good as the HP + , better than the HPS and CHEAP ... I would go for those as a street pad persoannly. My Toe is pretty aggressive at 1/16" out a side (1/8" total) Good for you !!!! Track Tires / Pads are required if you are doing a lot of track days ... full tread depth street tires cannot hack the heat of lapping Cheers Moose Last edited by Moose; 07-21-2008 at 12:12 PM. |
