Old 10-19-2007, 11:21 PM   #1 (permalink)
ct20's Avatar
Need Help...Si FSB Installation
Hey guys..I know most of you are out on the town...I am at home trying to diagnose why after the installation of Si FSB on LX sedan...the car is pulling to the right...seems like the "toe" is off...but it only started pulling to the right after I installed the fsb last weekend...
I got home tonight and put the car on the ramps...sure enough the inside of the right tire is worn a little...
Does anyone know how to line up the fsb or has anyone else installed one of these in the past...?
I thought I had the bar pretty much centered, but now I am thinking it may stagger to the left a little...
Need help...please.....
ct20 is offline   Reply With Quote
Old 10-19-2007, 11:27 PM   #2 (permalink)
The FSB, really shouldnt effect tire wear, unless you installed it upside down? Even then it wouldnt effect tire wear, sound more like a toe issue, and teh added Rollcouple distribution to the front of the vechile accentuated it.
Old 10-19-2007, 11:28 PM   #3 (permalink)
RCKola1011's Avatar
Ryan
It depends on how many MHz it runs at
RCKola1011 is offline   Reply With Quote
Old 10-19-2007, 11:32 PM   #4 (permalink)
ct20's Avatar
I thought it might be a toe issue also...but maybe I just didn't notice it until i installed the fsb. I was just reading about alignment on another thread..since I guess this will be the next step, without camber bolts for the front, or spc camber kit for the rear, what is the best alignment I can get? -.8 for front something near that for the rear?
Thanks again for your help...and btw...you were right, the si fsb doesn't do near what the si rsb does for the car...Even thought about putting the stock lx fsb back under the car...
i am going to try to get an alignment, if that doesn't fix it, I will put the lx fsb back under the car and just sell the si fsb...
Old 10-19-2007, 11:40 PM   #5 (permalink)
Put the LX back. No camber can be adjusted with a stock setup camber kits are needed.
Old 10-20-2007, 12:13 AM   #6 (permalink)
ct20's Avatar
I didn't listen to you the first time when you said the fsb wasn't worth the money...this time I am listening, the Si fsb has been taken out and LX fsb has been re-installed. I liked having just the Si rsb installed, it reduced body roll and understeer, but I guess I though the fsb would help body roll. the fsb did some, but not what I expected. I did make sure it wasn't installed upside down, and it was not..I do make mistakes every once in a while, but this wasn't one of them.
Thanks again, highrev1..I appreciate it.
Old 10-20-2007, 12:16 AM   #7 (permalink)
Next time
windows vista problems MAMA'S~HONDA Technology 42 08-30-2007 03:16 AM
Civic Si HFP Braking System Installation Video CollegeHillsHonda Inside and Out 1 08-29-2007 05:39 PM
Quick Draw! FREE HFP Brake Installation! CollegeHillsHonda Inside and Out 36 08-19-2007 12:24 AM
Installation of AEM CAI macmonkey84 Bolt-Ons And All-Motor 38 04-17-2007 11:04 PM
Navigation (Z1) Installation SiCruzer I.C.E., Electrical, Security, & Navigation 1 06-05-2006 12:12 PM
