Old 10-05-2007, 10:04 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Jennifer
Control Arm problem on my 06 Civic EX
I took my coupe in last week for the regular tire/oil change. I realized when I got the car back that the tires were SO loud. I called the dealership and asked if I had bad tires and if so, why didn't they tell me. They said the tires were fine and acted as if I was making everything up. Well I had an appointment to get a recall fixed this week so I brought it to their attention then. Apparently, my car has a control arm problem. The service manager said he had about 15 Civics with this same problem. With the problem it is causing my tires to wear poorly. Honda is working on a recall and he mentioned new tires as part of the recall. Anyone else have a similar issue?
jennerz22 is offline   Reply With Quote
Old 10-05-2007, 10:14 PM   #2 (permalink)
EDDIE
There is a safety recall on the abs rear wheel sensor o-ring which may cause the wheel to separate and fall resulting a crash all dealers should no about this issue my car is scheduled this saturday to get fixed .
crazyed is offline   Reply With Quote
Old 10-05-2007, 10:18 PM   #3 (permalink)
He is talking about the Rear upper camber arms I believe. I think those are getting redone also lemme do a search BRB.
Old 10-05-2007, 10:21 PM   #4 (permalink)
mO 64 StAnG 06's Avatar
Should I be getting things in the mail from my dealer's about these recalls? I don't think I've gotten one at all...
Maybe I got a good one then....
mO 64 StAnG 06 is offline   Reply With Quote
Old 10-05-2007, 10:24 PM   #5 (permalink)
EDDIE
It's the wheel speed sensor located on the hub assembly . some of the wheel sensors were improperly installed and do not seal the hub assembly . water may enter the hub assembly and damage the wheel bearing .
Old 10-05-2007, 10:25 PM   #6 (permalink)
Wow... Just asked my mom if she has seen any of these notices in the mail and guess what she almost threw away.
I wonder how many more were thrown away...
Looks like I'll be at Honda tomorrow or here shortly all day. Anyone know how long it takes for these guy's to fix it? I know my dealer is pretty incompetent and unknowledgeable...
Old 10-05-2007, 10:26 PM   #7 (permalink)
EDDIE
yeah all 06 and 07 civics should be getting something here is a toll free honda safety munber you can contact 888-327-4236 toll free
Old 10-05-2007, 10:27 PM   #8 (permalink)
EDDIE
make sure you schedule an appnt its an all day thing .
Old 10-05-2007, 10:30 PM   #9 (permalink)
Found it...I bet this is the fix Honda will be doing
"* New rear upper arm that decreases the amount of rear camber from -1.5* to -0.75*.
This was all done because of the camber change that was necessary to prevent abnormal tire wear (especially prevalent on Canadian market cars). The camber change caused less rear grip, so the engineers had to soften the rear... Perfect example of Honda's insurance lawyers defeating the engineers I suppose. However, my contact has driven both back to back and said that while the new setup is definitely more conservative, its not horrible. He bets that most drivers would not be able to pickup the difference.
BTW, I still don't know if the new rear upper arm has a unique part number or if it will use the existing number.
Anthony "Mario" Crea
NNJR-SCCA"
Old 10-05-2007, 10:45 PM   #10 (permalink)
Eh, thats a bit of a difference.. Hopefully their isn't that much of a difference.
So when you said they had to soften the rear to compensate, Im taking you mean the shocks/springs. I doubt they will be changing those too during the fix.
Hmm. All day huh... What other recalls are there? Might as well get all these done at once then...
Old 10-05-2007, 10:45 PM   #11 (permalink)
Don't be so sure
"2008 Civic changes...
* For all 2DR models the rear spring has changed to the 4DR spring (lower rate)."
Old 10-05-2007, 10:50 PM   #12 (permalink)
Wait, so lower rate means stiffer correct?
Well even then I doubt they would install these at no charge with the recall right?
BTW, where are you getting this info? I would like to have these printed out just in case the dealer decides to BS me.
Old 10-05-2007, 10:54 PM   #13 (permalink)
Lower rate means softer. I searched this forum for them
Old 10-05-2007, 10:55 PM   #14 (permalink)
Softer?! Damn, I think I'll pass then.
Hah, search the forums huh... I thought you were going to a site that had all the TSBs posted.
Old 10-05-2007, 10:58 PM   #15 (permalink)
Well having access to the HDS software doesn't hurt either
Old 10-06-2007, 06:49 PM   #16 (permalink)
Andrei'sCivic's Avatar
Andrei
I mentioned this to my dealer in Long Beach CA and he had no idea what I was talking about. He said maybe other dealers are experiencing complaints like this, but not them. He said no recall or technical service bulletin so far. I'll see what the dealer at Cerritos says.
Andrei'sCivic is offline   Reply With Quote
Old 11-14-2007, 08:31 AM   #17 (permalink)
Highrev1:
Do you know if Honda is any closer to a TSB or having parts availability for the updated control arms? Do you know if the TSB involves changing the spring rates?
I am up here in Canada with a 2007 Acura CSX and the rear tires have been ruined in about 8,000 miles. I wonder why the abnormal tire wear is more “prevalent on Canadian market cars”.
Anyhow, I will defer the installation of winter tires until I get the camber sorted out. Hopefully it isn’t too far in the future.
Jeff
jeffNB is offline   Reply With Quote
Old 03-16-2008, 02:45 PM   #18 (permalink)
giantquesadilla's Avatar
Colby
Who's your dealer??
What dealer did you go to? I am making a list of dealers willing to fix this problem (at Negative Camber Problem; What You Need To Do To Get The Upper Control Arms Replaced - GreenHybrid - Hybrid Cars) and I would greatly appreciate any dealer names. Anyone else willing to give dealer names, they would be greatly appreciated!
giantquesadilla is offline   Reply With Quote
Old 03-16-2008, 03:09 PM   #19 (permalink)
tomasro's Avatar
Turner
TSB 08-001, search for it
tomasro is offline   Reply With Quote
Old 03-19-2008, 09:02 PM   #20 (permalink)
If you have abnormal tire wear to the point its making noise you need to get it fixed ASAP. Your dealer should know what to do to. Have them contact tech line if they don't. I believe they are changing to the 08' upper arm to fix the wear issue.
-SWRT
SWRT is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/59619-control-arm-problem-my-06-civic-ex.html
Rear alignment/tires - Page 2 - Acura CSX Forums This thread Refback 12-06-2007 03:47 AM
Rear alignment/tires - Page 2 - Acura CSX Forums This thread Refback 12-05-2007 08:48 AM
06 Civic EX Coupe vs.08 Lancer GTS Review... Cybergypsy Water Cooler 20 09-01-2007 06:50 PM
