Old 09-23-2007, 12:53 AM   #1 (permalink)
hoanger's Avatar
Jason
Function Form Coilovers
So, after all the hype about function form, I decided to go with it.
heres the quick review about em
fronts: cake. they were in and out, adjusting them were easy and there were no problems.
rears: heres the problem...
in this picture, you can see both F2 shock and spring in place. USUALLY, if you leave 3-4 threads left on it, you could get a nice 1 finger gap or a little more tucked. in this case, when we put the wheel on.. the gap was actually BIGGER than stock. stock = 2 1/2 fingers.. with the set up you see here = 3 1/2 fingers and almost 4. What's the deal? the spring is smaller than stock, the shock is smaller than stock.. i don't understand why it'd be BIGGER.
so what we decided to do was take that whole perch out, and let the spring sit on the rubber mounts (both top and bottom), sorta like how stock springs sit, we put the wheel on and it's slammed like no tomorrow.
so heres pics of the negative camber in the back, its ridiculous but i kinda like it.
there is no finger gap, you gotta stick your finger in and then bend it to touch the top of the tire.
so my question is... maybe those with F2 coils, or anyone with some insight... why is it that, even with the rear coilover at the LOWEST setting, gives a ride height which is higher than stock even though everything (spring and shock) is shorter than stock. How do I adjust it WITH the perch to make a lower setting? it doesn't make sense.
is it bad to ride with such negative camber and on such a low height? I know the shocks will be fine because the shocks are meant to handle heights like this.
any help would be appreciated!
hoanger is offline   Reply With Quote
Old 09-23-2007, 02:15 PM   #2 (permalink)
hoanger's Avatar
Jason
bump for some help?
Old 09-24-2007, 12:11 AM   #3 (permalink)
padded's Avatar
J. Grahn
your first picture isn't well lit nor highly detailed, but it appears that if you adjust the adjuster the other way, you will achieve the lowering you desire.
padded is offline   Reply With Quote
Old 09-24-2007, 03:17 AM   #4 (permalink)
Jardiniboy's Avatar
Jasten
He's saying that when he dropped it to the lowest setting, it still had a 2 1/2 finger gap.
Old 07-23-2008, 05:08 PM   #5 (permalink)
RiceBowL54's Avatar
Gio
super late reply, but yeah, I bought the F2 coilovers too a few months before you and I had the same problem.
First off, the shop placed the perch below the spring so my car ended with a gigantic 3+ inch gap, which was rediculous. Then they decided to take off the perch completely which yeah, slammed the shit out of the car. Finally, we took off that second ring off the perch, and installed it correctly. I ended up with a 2ish finger gap.
What happened with your's since?
RiceBowL54 is offline   Reply With Quote
Old 07-24-2008, 12:36 AM   #6 (permalink)
hoanger's Avatar
Jason
Ah, here is the deal.
No matter what combination you try to use with the springs, you won't get what you want. I went through the EXACT same thing. I was 4x4 like crazy and I didn't understand why. Then I took it off and i was slammed like no tomorrow, but it was sick hahahaha
I left it like that for a bit then I was tired of it and decided to call up F2.
They said they made the wrong spring, you have to tell them to send you their new set of springs to replace. As long as you filled out that warranty sheet that was included, then they should have you on file and they'll send it free of charge.
I can slam it now, or can raise it like a 4x4. I'm sitting perfect now.
Old 07-24-2008, 01:19 AM   #7 (permalink)
Jardiniboy's Avatar
Jasten
Wow that's hot. You have seat covers?
Old 07-24-2008, 01:20 AM   #8 (permalink)
hoanger's Avatar
Jason
ha
you wish buddy!
Old 07-24-2008, 02:33 AM   #9 (permalink)
RiceBowL54's Avatar
Gio
NO ******* WAY... wow, I drove my car like a 4x4 for 1 freaking year.
I had called F2 back around April 07 and they didn't say shit about it. Sigh. Lame.
Old 07-24-2008, 10:44 AM   #10 (permalink)
hoanger's Avatar
Jason
Yeah, I told em and right away they said "Oh, we need to get you some new springs" they got here within 2 weeks.
Old 07-24-2008, 01:46 PM   #11 (permalink)
RiceBowL54's Avatar
Gio
I just called F2, and the guy was clueless. I mentioned that you had called them and had the rear springs swapped out, but the guy told me that there hasn't been any instances of wrong springs being packaged. He did mention someone who had asked for ep3 coilovers for his fg and those got swapped out for the right ones.
What do you think? Maybe I'm just not talking to the right person. Do you remember who you had spoken to?
Old 07-24-2008, 05:20 PM   #12 (permalink)
hoanger's Avatar
Jason
No I don't.. never got any names
he had a heavy accent though.. that's so weird.
maybe they've stopped doing that? I just mentioned it and they knew what I was talking about right away, try asking for the boss or something.
Function and Form Coilovers civxracer99 Suspension and Brakes 6 04-25-2007 04:17 PM
Function and form F2 Max2.0 Suspension and Brakes 3 02-07-2007 02:30 PM
Function and Form coilovers? ImTipSi Suspension and Brakes 27 01-07-2007 10:43 PM
Megan coilovers due soon ever12 Civic SI 6 07-25-2006 10:44 PM
