Old 09-17-2007, 03:36 PM   #1 (permalink)
Si Springs on LX
I just got Si springs and was wondering if I need to purchase a set of shocks or will the factory shocks be okay? Pease give me some recommendations before I proceed. My main goal is to improve ride quality, not drop it too much.
Thanks.
imrur is offline   Reply With Quote
Old 09-17-2007, 09:03 PM   #2 (permalink)
Jardiniboy's Avatar
Jasten
You can use the current shocks you have from your LX. Just make sure you get a spring compressor.
Old 09-23-2007, 02:12 AM   #3 (permalink)
Tod
FYI when you install Si springs on your non-Si it will sit higher than before (because the Si is heavier and the spring is stiffer)
Solo2EG is online now   Reply With Quote
Old 10-15-2007, 08:59 PM   #4 (permalink)
27IVTEC's Avatar
Jones
I have an EX coupe and just got some stock SI springs and rear sway from a friend, I put the rear springs on and can notice a little difference in height. How much will it raise it once I get the front springs on? Also where can I find the brackets to bolt the sway bar up?
27IVTEC is offline   Reply With Quote
Old 10-15-2007, 09:56 PM   #5 (permalink)
i think you'll have to hit up a honda dealer to get the brackets/correct bushing...but i'm pretty sure its not too expensive.
there are online OEM parts stores, but i doubt for a part that insignificant that you'd garner much of a deal going that way..
or if you can find a salvaged/junkyard Si somewhere, then you can just rip off theirs, most likely for pretty cheap...and hope they're still good...
LucasBlack is offline   Reply With Quote
Old 10-15-2007, 10:07 PM   #6 (permalink)
27IVTEC's Avatar
Jones
That should be easy, my dad is a honda dealer. Anyone notice a big difference in ride height with both front and rear Si springs?
SKUNK2 Springs on LX??? 06silvercivic Suspension and Brakes 7 03-15-2007 08:55 PM
EX STRUTS AND SPRINGS AND DAMPENERS on LX??? Way2Short Suspension and Brakes 7 06-02-2006 02:33 AM
si springs for a lx? CHRIS Suspension and Brakes 0 04-04-2006 10:14 AM
