Old 09-17-2007, 12:53 PM   #1 (permalink)
stebru84's Avatar
Problems with skunk2 rear camber arms
I have had skunk2 rear camber arms on my 06 Si since April, and have gone to 13 auto-xs and done 7k miles.
I nearly failed tech because of the large amount of play in the bushing where it attaches to the hub assembly, I took off my wheel and checked all the bolts and they are tight.
Both sides have play when I grab the top of the tire and shake in and out (can hear small clunk), it feels like the sleeve through the bushing is too large or it is worn out.
Could someone out there with skunk2 arms check to see if they have any play. Should they wear out that fast?
Thanks
stebru84 is offline
Old 09-17-2007, 10:45 PM   #2 (permalink)
I have the same problem. I have not really checked it out fully, But I have play from top to bottom on both sides.
sisedan is offline
Old 09-17-2007, 10:52 PM   #3 (permalink)
8thcivic Sponsor
New Recall: Rear Bearing (Revised, threads merged)
BUY MY CIVIC
Highrev1 is offline
Old 09-17-2007, 11:52 PM   #4 (permalink)
That recall is on the speed sensor o-ring. I don't think that it would give any play in the wheel. Could it be the rear sway bar end links?
sisedan is offline
Old 09-18-2007, 12:51 AM   #5 (permalink)
8thcivic Sponsor
Unless his bearing is acutally effected and that is what is causing the play...which is what the recall is about.
BUY MY CIVIC
Highrev1 is offline
Old 09-18-2007, 02:21 AM   #6 (permalink)
rwc
rwc's Avatar
Randy
thats not good.. i was just about to order one too. maybe ill get the spc one instead.
rwc is offline
Old 09-18-2007, 01:21 PM   #7 (permalink)
stebru84's Avatar
I checked it again when i got home, there is play in the bushing on the skunk2 arms, not the wheel bearing,
Any Suggestions ?
stebru84 is offline
Old 09-18-2007, 01:37 PM   #8 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
Ugh, I was about to get these camber arms. That mean I should go w/ SPC?
aki is offline
Old 09-18-2007, 01:42 PM   #9 (permalink)
8thcivic Sponsor
Size the bushing, and order a new one from Energy Suspension.
BUY MY CIVIC
Highrev1 is offline
Old 09-25-2007, 02:39 PM   #10 (permalink)
Jim W.
Nope, definitely the bushing
I was there at the Auto-X parked next to him, that play was definitely in the bushing.
How did you make out with Skunk2?
Hatepylons is offline
Old 01-14-2008, 10:04 PM   #11 (permalink)
footy's Avatar
Sounds good. It will be great if this 'upgrade'/replacement option to purchase the bushes is made available thru' ur web. I am sure lots of members will be getting them. I am sure I will be one of them.
footy is offline
Old 01-15-2008, 08:18 AM   #12 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
no play here, but im not autoxing or anything, ive had em about 6months and drive pretty aggresively
TW FG2 Sold....
"Ridge"Racer is offline
Old 02-27-2008, 10:52 PM   #13 (permalink)
ak.chris85's Avatar
Chris
I'm having the same problem. Just installed mine today and the bushing where it connects to the spindle seems to be a little bigger than the stock bolt. When i have it jacked up you can grab the top of the tire and move it in and out a (very)tiny bit. Can you here the clunk when your suspension moves? Any solutions? gotta get some new tires before I really test mine out.
UPDATE: After a few miles I went back and tightebed everything up again, and now no more rattle.
ak.chris85 is offline
Old 07-10-2008, 08:27 PM   #14 (permalink)
dannyd86's Avatar
Danny
dannyd86 is offline
Old 07-10-2008, 09:09 PM   #15 (permalink)
FastTimesAtFGHigh's Avatar
http://jdmfg2.wordpress.com
i just had these installed today. how can i check for "play"?
FastTimesAtFGHigh is online now
Old 07-11-2008, 03:04 PM   #16 (permalink)
dannyd86's Avatar
Danny
I was hearing a clunking noise when going over certain bumps on my right rear, checked it out today and the rubber bushing on the outer part of the arm is broken. Damn it, I think I wasn't careful enough when installing this one, which led to the premature wear (left side is fine).
Anyone know if I can get just the bushing from Skunk2? If not, what to do?
This rubber bushing:
dannyd86 is offline
Old 07-14-2008, 08:39 AM   #17 (permalink)
stebru84's Avatar
call skunk2, mine were 7 months old (6 month warranty) but they had me ship them back to them and they replaced the bushings on both ends free.
stebru84 is offline
Old 07-14-2008, 08:42 AM   #18 (permalink)
NIGHTHAWKSI's Avatar
Ian
delete
NIGHTHAWKSI is online now
Old 07-14-2008, 08:49 AM   #19 (permalink)
DRIVEN1's Avatar
So you were down for awhile or did they ship you new ones first? I am going to be installing mine next week and starting to have second thoughts after reading about these problems.
DRIVEN1 is offline
Old 07-14-2008, 08:53 AM   #20 (permalink)
stebru84's Avatar
i had to ship mine and put stock back on
stebru84 is offline
skunk2 rear camber kit AXIS Suspension and Brakes 3 08-30-2007 09:41 PM
what are best options for camber in rear? LadyEmily Suspension and Brakes 17 06-21-2007 10:56 AM
