Old 09-17-2007, 04:32 AM   #1 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
Here's CTR front/rear sway bar size
Update: Official figure from Mugen (9/6/08)
So after much wondering, there's finally a source to indicate what the FD2 CTR sway bar size is, esp for the rear.
The rear is using a 21mm bar. Source (in Japanese):
–³ŒÀ | CIVIC TYPE R | PARTS
This would mean that Cusco's numbers were true (I explain at the bottom), so the CTR sway bar sizes are:
CTR (F/R): 26.3mm/21.4mm
The possible sources for CTR sway bar thickness
I've been trying to get the Civic Type-R (FD2) sway bar specs from Japanese sites, but these dang Japanese sites aren't terribly informative. There's two sources for where I'm getting this number: one is from an aftermarket sway bar company, the other from Honda itself.
1) Honda's official site:
HondabƒNƒ‹ƒ}bƒVƒrƒbƒN TYPE RbWebƒJƒ^ƒƒObƒTƒXƒyƒ“ƒVƒ‡ƒ“
According to the official site, the CTR has stabilizers that are 107% bigger for the front and 191% bigger for the rear in diameter when compared to the 2.0GL Civic (not quite an EX since it has a 155hp K20 engine, more like the 155 hp CSX). Note that it's not talking about stiffness, but diameter. This begs the question, what is the size of the 2.0GL stabilizer? Problem is, I have no idea
But we can somewhat safely assume it's using the same sway bars as our stock cars over in the US. Based on that:
Stock sedan sways (F/R): 24.2mm/10mm
CTR (F/R): 26mm/19.1mm
OR, if the JDM Civics are using coupe sways for some reason:
Stock coupe sways (F/R): 25.4mm/11mm
[b]CTR (F/R): 27.2mm/21.0mm[/i]
2) Cusco's numbers.
???? Type-R FD2?????????? ????? ???? ?????????
Cusco in Japan put out a sway bar for the FD2 Civic Type R, which claims 128% more stiffness up front for the 28mm, and 134% for the rear 23mm bar. Since you get the stiffness using the fourth power:
Front:
28^4/x^4 = 1.28
x = 26.3 mm
Rear:
23^4/x^4 = 1.34
x = 21.4 mm
Since we have no idea what the 2.0GL Civic's stabilizers are like, and since Cusco's numbers are consistent with Mugen, then we have what is a pretty good indicator of the CTR sway bar sizes.
aki is offline   Reply With Quote
Old 09-17-2007, 08:31 AM   #2 (permalink)
Originally Posted by aki
http://www.cusco.co.jp/products/new_...typer_fd2.html
Front:
28^4/x^4 = 1.28
x = 26.32mm
Rear:
23^4/x^4 = 1.34
x = 21.37mm
I'm scratching my head at why they're not rounded up numbers (eg 27mm and 22mm), hmmm. Correct my math if I'm wrong, but those should be the right numbers?
maybe their percentage increases are slightly incorrect.
because i wonder if the stock CTR bars would be more than just one mm smaller than cusco's bars.
- i would assume cusco would want to provide a difference more so than just one mm when putting aftermarket sways out on the market.
...and i furthermore wouldn't be surprised if the CTR ran a slightly smaller bar than our FA5's run, along with a larger rear sway...only makes sense really.
...of course then, if we want to consider manufacturing and production, they might use the same front sway as we run to reduce costs.......?
either way, the CTR and progress rear bar now seem to be basically the same size.....does the CTR have reinforced mounts?
LucasBlack is offline   Reply With Quote
Old 09-17-2007, 12:35 PM   #3 (permalink)
aki
aki's Avatar
Not sure about reinforced mounts--the only reference we have are these images from the official site:
Front:
Rear:
It only mentions that the stabilizers are beefed up, nothing about reinforcement.
Old 09-17-2007, 01:27 PM   #4 (permalink)
quality_sound's Avatar
Paul
Maybe the difference is hollow vs. solid? Anyone know if the OEM bars are solid of hollow? If they're hollow then even going to a bar with the same thickness but solid will increase the stiffness.
quality_sound is offline   Reply With Quote
Old 09-17-2007, 01:41 PM   #5 (permalink)
aki: yeah, i've scoured the japan honda website.....that was...an interesting endeavor.
quality sound: not as much as you might think...or could tell/feel.
the si's OEM bars are solid i believe.
Old 09-17-2007, 01:44 PM   #6 (permalink)
Paul
Weird. I changed my PAssat's OEM hollow bars for Autotech solid bars that were the same diameter and you could tell. Maybe it harder to tell on a car as stiffly sprung as the Si.
Old 09-17-2007, 01:50 PM   #7 (permalink)
^^You can't compare Hollow vs Solid, just by size, they use different calculations.
WHy though, we know the stiffer end of the car breaks loose first and there are benifits to a smaller front bar. :) Alot will come from testing different setups, I already know I want a smaller front bar than they make, probably gonna get a 12mm FSB made up.
Old 09-17-2007, 02:20 PM   #8 (permalink)
aki
aki's Avatar
I added numbers from Honda's site. The more research, the more I get confused. Bleh.
Old 09-17-2007, 02:31 PM   #9 (permalink)
Paul
I agree. I was just thinking that one set my be solid and oone hollow which might explain why the numbers aren't jiving.
Old 09-07-2008, 02:05 AM   #10 (permalink)
aki
aki's Avatar
Finally there's a figure from Mugen about the CTR sway bar size, so I've updated the original post. Woot woot.
Old 09-07-2008, 04:57 AM   #11 (permalink)
meeks's Avatar
Resident DHL man
good info!
meeks is offline   Reply With Quote
Si Rear Sway Bar on CSX iluvmycsx Suspension 21 10-02-2008 08:44 AM
Roll Call! Who with a non-Si has upgraded the rear anti sway bar? Si bar fits LX? Andrei'sCivic Suspension and Brakes 13 07-01-2008 04:07 PM
Problem with the Progress Sway Bar on an 07 SI Sedan. SIis4ME Civic SI 7 04-17-2007 02:34 PM
Si sway bar size? poopsi Suspension and Brakes 7 07-30-2006 01:20 AM
