#21 (permalink) |
Its pretty simple really. Want kind of handling do you want. If you put springs on and don't do an alignment, I promise you, your alignment is off. Wrong toe and camber. I used an Eibach pro kit on my car and had an alignment done right afterwards and the toe and camber were way off. Then I put front and rear camber kits on and realigned.
Here is what I dont understand. Why spend money on springs and wheels only to have the car perform worse? Spend a little more and do front and rear camber kits so you can adjust the front and rear of the car during an alignment. This I also promise you, your car after the alignment will handle way better than before. My alignment now is -1.75 camber in the front and -1.5 in the rear. Toe front and rear is set at 0. Without camber kits, well, good luck. |
#25 (permalink) | |
not according to that calcuralor. They are 1.8% larger. 11mm taller... May not even be enough to effect camber, i just know that it's not the same size. With a spring chance you definately need to. You are moving suspension components all around screwing camber and toe reading all up. I drove my car to the alignment shot with my camber all screwey and it handled like shit. Post alignment it handled like it was on rails. |
| Camber Kit with HFP suspension? | K20FG2 | Suspension and Brakes | 5 | 04-27-2007 03:16 AM |
| Tein S-techs w/ SPC camber kit | Si_yoc | Suspension and Brakes | 3 | 04-12-2007 09:02 AM |
| Eibach Pro Kit Install Help in Phoenix | Tigger1 | Suspension and Brakes | 3 | 06-12-2006 12:20 PM |
| Eibach pro kit pictures | pigman | Garage | 11 | 05-13-2006 11:54 AM |
