Old 09-13-2007, 04:38 PM   #1 (permalink)
black07coupe's Avatar
2" drop?
Which springs could I get for my r18 coupe that would give me a 1.8-2.0 drop? Is that too much? Also, which springs will give a comfortable ride, and which ones will prevent bottoming out? Thanks guys
black07coupe is offline   Reply With Quote
Old 09-14-2007, 02:48 PM   #2 (permalink)
i don't suggest you drop your car that low with springs..you'll mess everything up!
you're gonna need a whole kit. sway bars, springs, coilovers...
tolgaSI is offline   Reply With Quote
Old 09-14-2007, 04:36 PM   #3 (permalink)
friedk's Avatar
My friend had a 2.5" drop on his car for like 2 years on stock shocks.
Not that I'm suggesting that though.
Check out the sticky next time.
Neuspeed Race//// 2.0” / 2.0” //// (P)+-303in. lbs / +-460 in. lbs
If you want a comfortable ride I really wouldn't go that low.
Eibach sportlines will get you a really nice drop and still maintain a smooth ride.
friedk is offline   Reply With Quote
Old 09-14-2007, 07:31 PM   #4 (permalink)
Boink
divinebarrel's Avatar
Nathan
what are u talking about how does a sway bar have anything to do with a 2 inch drop, its like like u will burn the shocks out in 20k miles cause u don't have a sway bar.
now on the otherhand a 2inch drop is a big ass drop and on stock struts they are toast but but i don't see how a sway bar has anything to do with this
divinebarrel is offline   Reply With Quote
Old 09-14-2007, 07:33 PM   #5 (permalink)
Boink
Nathan
i had a 1.5 front 1.4 rear drop on sportlines with konis,s on my sentra ....with backproblems not a good idea but the sentra is also notorious for very little suspension travel
Old 09-14-2007, 07:45 PM   #6 (permalink)
jspecFG's Avatar
IMO, a 1.8-2" drop is overkill on our cars without atleast a set of Yellow's to go along with that drop.
FG/FA's come pretty low in stock form compared to past and some present cars. I'm talking about suspension wise, our body is a different topic :P.
Personally, I have s-techs w/ 17x7.5 214/45 tires and they rub whenever going over huge inclines.
That kind of drop w/ no stiffer shock to help is asking to be bottom'd out. Cutting the bump stop might help, but still.
K.
jspecFG is offline   Reply With Quote
Old 09-14-2007, 08:05 PM   #7 (permalink)
K, so then which springs should I get for my 2dr r18? I want cheap, but i dont want so cheap that I'm hurting on quality.
Old 09-14-2007, 08:54 PM   #8 (permalink)
Boink
Nathan
with any lowering spring i would do after market shocks... if u cant afford that then put ur money elsewhere. Not to be rude but a 2 inch drop won't make every motorist jaw drop and look at ur car so if thats what ur after then save the money just springs will burn the shocks out much faster then stock spring
Old 09-15-2007, 03:47 AM   #9 (permalink)
blah blah blah. im not trying to impress other motorists. i like my car the way i want it to look. and about the struts blowing... theres a thread where everyone says that their struts were fine even with huge drops. ppl had them on their tegs with 2" drops and their struts were fine. ima go with somethin like 1.4, just need to figure out which springs to buy.
Old 09-15-2007, 03:59 AM   #10 (permalink)
peenoySI's Avatar
Christian
go with like eibachs
peenoySI is offline   Reply With Quote
Old 09-15-2007, 06:05 AM   #11 (permalink)
Jardiniboy's Avatar
Jasten
If you're not in a rush to get them, get ground control.
Old 09-15-2007, 06:11 AM   #12 (permalink)
JeShUa's Avatar
i can has lower?
Eibach Sportlines
Old 09-15-2007, 11:24 AM   #13 (permalink)
Originally Posted by JeShUa
Eibach Sportlines
thank you.
Old 09-15-2007, 11:41 AM   #14 (permalink)
Boink
Nathan
no need to get huffy puffy with me. Im just trying to do everyone a favor and get rid of the bad rep the honda guys get for slamming their cars to the ground then cruising around on blown struts for the next 20k miles before or if they fix them.
maybe others would argue differently but suspension is really not something that should ever be halfassed its just not safe imo
but that aside i have always trusted eibach over any other spring and never regretted it :)
Old 09-15-2007, 02:51 PM   #15 (permalink)
K20 KNIGHT
nighthawk06Si's Avatar
Toan
skunk2 springs has close to a 2" drop.
nighthawk06Si is offline   Reply With Quote
Drop Drop Drop it like itz hot [a photoshoot] BrineSI Introduction & Pictures 63 08-14-2007 11:43 PM
Cedar Point Selling Demon Drop Ride! - Ohio peeps get in. webby Water Cooler 8 07-31-2007 06:18 PM
2" Drop on 18's a problem? CaliGuy Suspension and Brakes 1 07-14-2007 02:12 AM
K&N drop in filter xlanevo7x Bolt-Ons And All-Motor 7 05-03-2007 09:55 AM
