Old 09-06-2007, 04:07 PM   #1 (permalink)
Need Help Fast!!!!
Closed This Thread Mods
07SIK20 is offline   Reply With Quote
Old 09-06-2007, 04:11 PM   #2 (permalink)
NIGHTHAWKSI's Avatar
Ian
wow...i have no idea what your talking about?
camshaft? rotor? trans? all in the same sentance....
whatever your doing, you should have left to the professionals.
Old 09-06-2007, 04:14 PM   #3 (permalink)
ok sorrie im trying to say that i pulled the rotor out to far i think and can't push it back
Old 09-06-2007, 04:16 PM   #4 (permalink)
Ian
lol. doing suspension work? same thing happened to me when putting on springs.
just give the axel a good shove back in. if everything is still lined up (which it should be) it should slide back in place.
Old 09-06-2007, 04:18 PM   #5 (permalink)
yeah suspension work so just line the rotor back to the postion and push it really hard?
Old 09-06-2007, 04:21 PM   #6 (permalink)
Ian
the rotor isnt loose, but if you grab the axel, it is no longer atached to the drivetrain? if so, pick up the axel so it is aligned back up where it goes, and the give the rotor a good push to slide the axel back in place. once the axel is in place, the rotor should be very close to where it should be to bolt the strut up (assuming thats what your trying to do).
Old 09-06-2007, 04:22 PM   #7 (permalink)
ok ill do that and get back to you
Old 09-06-2007, 04:27 PM   #8 (permalink)
ok did it but should i put the struts on first or after its in the drivetrain?
Old 09-06-2007, 04:46 PM   #9 (permalink)
Ian
attach the strut after the axel is in place. now you should be able to push the top of the rotor in (towards the engine) and then bolt the bottom on the stut on.
Old 09-06-2007, 04:47 PM   #10 (permalink)
we got the it in but the struts dont line up to the rotor
Old 09-06-2007, 04:50 PM   #11 (permalink)
Ian
^^^edited
Old 09-06-2007, 05:22 PM   #12 (permalink)
Last Post Edited
Old 09-06-2007, 06:15 PM   #13 (permalink)
Nvm Mods Close
So drinking out of the toilet is better than fast food ice? webby Water Cooler 41 01-09-2008 08:22 PM
New Fast and the Furious? youchasedafterme Water Cooler 12 02-28-2007 02:01 AM
tripple fast - tripple furious!!!! webby Water Cooler 9 09-27-2005 06:25 PM
