Old 09-04-2007, 12:50 AM   #1 (permalink)
blackrose's Avatar
Dan
Taking front sway bar off
what would happen if i took it off...........Pros and Cons....... if some one does not mind telling me
blackrose is offline   Reply With Quote
Old 09-04-2007, 05:08 AM   #2 (permalink)
Jardiniboy's Avatar
Jasten
Try it out. You'll feel it when you experience it.
Old 09-04-2007, 05:12 AM   #3 (permalink)
Firestrife's Avatar
Keenan
you'll feel a lot more body roll.
Firestrife is offline   Reply With Quote
Old 09-04-2007, 07:56 AM   #4 (permalink)
shipo's Avatar
I gotta ask... Why???
shipo is offline   Reply With Quote
Old 09-04-2007, 08:46 AM   #5 (permalink)
mO 64 StAnG 06's Avatar
Probably to lessen understeer. But I would just add a thicker rear sway bar if you haven't already.
Maybe add some toe out on the front with some caster and you'll be set.
mO 64 StAnG 06 is offline   Reply With Quote
Old 09-04-2007, 04:00 PM   #6 (permalink)
Louder than 4 F404-GE-400
Paul
It would increase oversteer a lot. It would be good for auto x event, but might be too scary on the streets. Corner exit speeds would be higher due to the increase in front end grip (more roll couple disterbution has moved foward). If you do do it, make sure in increase front negitive camber with some camber bolts, otherwise, you won't be able to take advantage of the increase in front end grip because the increase in body roll will cause the tires to roll over on the outside edge decreasin grip.
Old 09-04-2007, 04:13 PM   #7 (permalink)
blackrose's Avatar
Dan
because i want to lessen understeer......... and i want to see how well the car can turn with out it..... i just wanted to know if it would have any bad effects on the suspension........ iam new to moddin this is my first car i ever modded so iam trying to gain all the knowledge i can
Old 09-04-2007, 06:42 PM   #8 (permalink)
blackrose's Avatar
Dan
good advice tried it out and all have to say hell yeah.... i love it
Old 09-04-2007, 06:59 PM   #9 (permalink)
Andre07FG2NBP's Avatar
Andre
You love it with it...or love it without it?
-Andre
Andre07FG2NBP is offline   Reply With Quote
Old 09-04-2007, 07:48 PM   #10 (permalink)
blackrose's Avatar
Dan
the love is without the sway
Old 09-04-2007, 10:25 PM   #11 (permalink)
Paul
Then read all the light blue threads at the top of this section and read this thread start to finish. That will learn you a lot about handling.
Suspension Theory/Chat Thread
Old 09-04-2007, 10:44 PM   #12 (permalink)
blackrose's Avatar
Dan
oh dont worry i read all the stickys........very good information i might add
i just asked that question because i dont think any one makes a smaller sway bar for the front and i cant find the reason why no one does
Old 09-05-2007, 12:05 AM   #13 (permalink)
SiRyan's Avatar
Would you recommend it for spirited driving for a DD.
SiRyan is offline   Reply With Quote
Old 09-05-2007, 12:32 AM   #14 (permalink)
blackrose's Avatar
Dan
whats DD
Old 09-05-2007, 01:17 AM   #15 (permalink)
SiRyan's Avatar
Daily Driver
Old 09-05-2007, 02:06 AM   #16 (permalink)
fg2!kid's Avatar
エリク eric
are driving with vsa on or off ?
fg2!kid is offline   Reply With Quote
Old 09-05-2007, 02:23 AM   #17 (permalink)
Firestrife's Avatar
Keenan
spirited driving is best done with VSA off.
Old 09-05-2007, 02:34 AM   #18 (permalink)
fg2!kid's Avatar
エリク eric
i know that but i was just wondering if he test drove it with vsa on or off oh also if you daily drive it? and how does it feel on the streets?
Old 09-05-2007, 02:09 PM   #19 (permalink)
blackrose's Avatar
Dan
i have an 06 r18 so i dont have vsa and also i dont know if its for the daily driver all depends on how you drive i guess
Old 09-05-2007, 02:12 PM   #20 (permalink)
blackrose's Avatar
Dan
i do daily drive with the sway bar off and i seem to like it one the streets but i also like to push my car on turns untill the wheels start squeeling
Dumb Laws C2i0v0i1c Water Cooler 58 10-03-2008 09:27 AM
Progress Sway Bar Special!!! Excelerate Excelerate Performance 62 06-15-2008 11:17 PM
Grace: 2006 Honda Civic Si ASM PWRDByAdobo Introduction & Pictures 67 01-24-2008 07:24 PM
Anyone using the 30mm Front Progress Sway Bar? brthorner Suspension and Brakes 35 05-11-2007 09:22 PM
Front and Rear Lower Tie Bar / Hbrace unplugged Suspension and Brakes 12 04-06-2007 12:45 AM
