Old 09-05-2007, 04:08 PM   #21 (permalink)
aki
aki's Avatar
Semi-Si Sedan Hater
Some autocrossers take off the front on the RSXs. The pros an cons:
Pros:
1) More traction up front. Since understeer = front losing traction first, it counteracts dastardly understeer
Cons:
1) Too much body roll can distribute too much weight to one side, to a point where the tires can't handle the extra work. Not sure if that'd happen with your car
2) Steering responsiveness will be reduced. You'll probably need to have a slightly earlier apex to compensate.
3) Increased transitional oversteer can make your car less stable in hard turns, possibly making your car prone to spinning out (kinda doubt this would happen just from taking off the front sway though)
As an alternative, you could also get the Si rear sways and counteract the understeer too. The stiffer you go though the more you car can get antsy in hard turns, but Si rears are a modest upgrade. Also, sways that are too big can cause you inside wheel to lift in hard cornering.
aki is online now   Reply With Quote
Old 09-05-2007, 05:52 PM   #22 (permalink)
blackrose's Avatar
Dan
Pros:
Cons:
3) Increased transitional oversteer can make your car less stable in hard turns, possibly making your car prone to spinning out (kinda this would happen just from taking off the front sway though)
cool thats the answer i was looking for
blackrose is offline   Reply With Quote
Old 09-05-2007, 09:57 PM   #23 (permalink)
fg2!kid's Avatar
エリク eric
if the spring rate was increased in the front could that improve responsiveness ? after removing sway bar
fg2!kid is offline   Reply With Quote
Old 09-06-2007, 12:40 AM   #24 (permalink)
SpeedDemon's Avatar
They call me, El Diablo.
Try driving in the rain.
SpeedDemon is offline   Reply With Quote
Old 09-06-2007, 03:09 AM   #25 (permalink)
Louder than 4 F404-GE-400
Paul
To a point. The higher spring rate you use, when you hit a bump (even a small one) the spring compresses less and uncompresses faster which can launch the car, tire included, off the ground. This is called suspension frequency. A tire that isn't touching the ground, isn't increasing traction.
Old 09-06-2007, 05:32 PM   #26 (permalink)
aki
aki's Avatar
Semi-Si Sedan Hater
Although the frequency is faster, the uncompressing is dictated more by the rebound dampening, afaik. The launching happens when the spring doesn't compress enough and launches into the air instead. It also happens with excessive rebound dampening on consecutive bumps, where the uncompressing resistance is so high that it just jumps on the next bump.
Old 09-06-2007, 09:03 PM   #27 (permalink)
Paul
Thank you for the much better explaination than my sorry excuse for one Its hard to talk to your woman and type at the same time.
Old 09-06-2007, 10:07 PM   #28 (permalink)
fg2!kid's Avatar
エリク eric
i noticed a lot of japan tuner cars are like that the first that comes to mind is the mines skyline i seen a vid of Keiichi Tsuchiya driving it and the car seemed really bouncy or jumpy over every little bump on the track or is that something different ?
Progress Sway Bar Special!!! Excelerate Excelerate Performance 62 06-16-2008 12:17 AM
Grace: 2006 Honda Civic Si ASM PWRDByAdobo Introduction & Pictures 67 01-24-2008 08:24 PM
Anyone using the 30mm Front Progress Sway Bar? brthorner Suspension and Brakes 35 05-11-2007 10:22 PM
Front and Rear Lower Tie Bar / Hbrace unplugged Suspension and Brakes 12 04-06-2007 01:45 AM
