When should I replace my brake pads? (guestimates)
My car now has about 30,000km on it from driving on the highway. I was just wondering if anyone had to replace them around this time or when they first wore out. I skipped my B service ($200 fee to tell me how much life remained on the pads + "inspections") so I would like to get a ball park figure?
#10 (permalink) |
Like someone already mentioned, dont skip the "inspections" because it's not just an inspection.
I work at a Honda Dealership and this bugs me to no end people who think it's a $164 oil change. It's not. Yes inspections dont take long and should cost $164, and they dont. You are paying mostly for labour envolve din SERVICING the brakes.....that means every part of the brake, pulling the calipers (drums) apart, relubricating all the slide pins and saddles, to keep noises away, breaking rust build up off the outside edge of rotor to prevent it from creeping onto your braking surface......all of these things will extend the life of your pads a lot. The civic, SI depending on how its driven should easily get 80k on their pads.... For the guy who has 18k on his car and is going to replace his pads, thats absurd....there is no way they should be worn out, you are probably hearing some squeal from the pads being glazed over from braking. (when the metal in the pads spreads out more over the surface causing a squeal in some braking situations) which the service will take care of btw. Long story short, don't skip the servicing, you dont want to have a pad seize up against your rotor either because rust has stopped the pad from moving freely cause then you will be replacing the pads prematurely and unexpectedly. Hope this helped. Cheers. On another note, I have a customer who has an EX sedan and does all highway, but he replaced his first set of pads at 156k, he does all his servicing....he has now over 230k on his civic with no problems. It is a 2006. |
#11 (permalink) | |
#12 (permalink) | |
Ears bleed at 70mm
#13 (permalink) | |
He travels for a bank all day long, none stop driving for 8 hours a day. The vehicle was bought right when the civics were released in the fall of 05. Cheers. |
#16 (permalink) |
Absolutely I am, now it all depends on the driver, but as an example I have a lady in her 40's who owns an AS Si with 30k on it and at her last B service she had 80% remaining on her pads. As you can probably tell she isnt hard on the car so she might be at the top end of the pile. I personally plan on getting atleast 60k out of mine.
#17 (permalink) | |
I relubricate the slider pins with every brake job, which takes me all of an extra 5 minutes. No dealer rebuilds the caliper pistons. I "brake" the rust off my rotors, since I never see rust form on the pad/rotor interface unless they've been rained on or sat a long time. A few miles of driving and braking gets this right off. Interestingly enough, the place where I see the rustiest rotors are at new car dealers on the vehicles sitting on the lot. Tell me the dealer scrubs the rust off each one. As for glazed pads, that is an indicator that the pads aren't all that good and can't take the heat they've been subjected to and have melted at the friction surface. Higher quality pads are in order. |
#18 (permalink) | |
All in all, this is all my opinion take it as you want, but if you are in a northern area of the continent it is worth the money if you cant do it yourself, it just bugs me that people call it an "inspection" of the brakes for $160, it's not. Sure you can do it yourself for a fraction of the price, but it's like anything a business is a business and needs to cover it's own cost of operation to provide these services. You dont go and rip into roofers when they quote you a cost of $2000 to redo your shingles when the parts only cost $300, the fact remains that most peple wont and cant re-shingle their roofs....thats my point. |
#19 (permalink) | |
My rotors get lips on them, but not of rust, even though the lip is rusty. Pad wear of the rotor causes that. I don't do anything about it until it gets fairly significant and then I pitch the rotors and buy new ones at the next brake job. Never caused noise issues for me. |
#20 (permalink) |
^ i have been avoiding dealerships ever since i got my exhaust and intake. Am i just being dumb? will dealerships accept to service my car when they see this:
![]() hate to jack, but i really want to get my brakes or the whole car serviced by a dealership |
| Difficult to replace drivers side airbags? | mdenning | Civic SI | 0 | 08-02-2007 05:24 PM |
| OEM or replace HU and speakers | familycar | I.C.E., Electrical, Security, & Navigation | 0 | 04-24-2007 10:45 PM |
| Will a full exhasut replace your stock resonator? | Civic Pride | Bolt-Ons And All-Motor | 13 | 04-23-2007 05:00 PM |
| To replace MTF or not to replace MTF! thats the question | 93sidood | Mechanical Problems & Technical Chat | 28 | 03-24-2007 02:48 PM |
| Honda replace my MTF for free. | raycl | Mechanical Problems & Technical Chat | 12 | 03-19-2007 11:36 PM |
