Replacing Rear Brake pads question
Hey Everyone! I'm going to be replacing the rear brake pads on my 06 EX coupe sometime this weekend. I've replaced the front before without issues, but some of the stuff on the rear has me wondering. Here's a couple of questons:
1) The piston on the rear calipers has to be screwed back into the caliper in a clockwise fashion? While doing this should I bleed off te brake fluid from the caliper? 2) Since the e-brake is self adjusting is there anything I need to do to reset it to be wide open? Does it need resetting at all? 3) While bleeding the brakes have people been using the manual bleed method or gravity bleeding? Any issues with the ABS system using the manual bleed method? Thanks for the help! |
I think I might have been mis-interpreted
1)the piston the actuates the brakes needs to be screwed back into the caliper, not the bolts that mount the caliper to the hub. 2) My car has 36k miles on it, and I plan to flush the fluid out after changing the pads. Thanks again |
#4 (permalink) | |
i havent had to bleed the brakes yet...but i think its just as any other car. abs doesnt make a difference. |
#5 (permalink) | |
Tuna Fiddle™
it is safer to open the bleeder screw when compressing the caliper piston. There have been cases of brake fluid being forced back through the abs module and ruining it. I always do it just to be safe. And yes if you do use that method its a good idea to do a quick bleed when you are done.
For Sale Forum Rules READ THEM!
#12 (permalink) |
Just for other people to reference:
The Rear brake caliper piston have to be pushed in while turned clockwise to seat them further into the caliper. The rubber brake hose on the driver's side leaves almost no room to work with, so be careful when trying to put the caliper back on the rotor. The passenger side has a dust shroud bolt sticking out that interferes with the e-brake cable mount. You'll have to fiddle around with it to get it back on but shouldn't need to remove the bolt. Thanks again for the help! |
| Brake caliper question | pickle430 | Wheel And Tire Upgrades | 17 | 10-31-2008 09:25 AM |
| question about sway bar w/ rear tie | projectprelude | Suspension and Brakes | 6 | 01-31-2007 01:40 PM |
| K2 fog replacing OEM question? | lovin_it06 | Lighting, H.I.D.'s, & Neon | 2 | 01-23-2007 11:22 PM |
| Question on rear speakers | xinsungx | I.C.E., Electrical, Security, & Navigation | 2 | 11-26-2006 02:43 PM |
| a stupid question - when do i change my brake pads? | NoMoreHonda | Mechanical Problems & Technical Chat | 4 | 10-15-2006 11:50 AM |
