Old 02-14-2008, 11:21 AM   #21 (permalink)
ryker's Avatar
Originally Posted by Highrev1 View Post
2. Loosely install the new flange nuts (A).
3. Loosely install new damper pinch bolts (A) and new self-locking nuts (B) to the damper (C).
I'm going to place some Si springs on my EX. Just need to find out what new bolts or other items I need to order. Going to do this before I have the TSb for rear camber fixed. So I can get a free alignment out of the deal hassle.
So what do I need for the rear?
ryker is online now   Reply With Quote
Old 02-25-2008, 11:51 AM   #22 (permalink)
i see red x's for the front install?
jdmcivic517 is offline   Reply With Quote
Old 02-25-2008, 02:02 PM   #23 (permalink)
Right click and click show picture, they work for me
Old 02-28-2008, 11:35 PM   #24 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
Thanks Highrev, I'll be using this DIY tomorrow night when I go to install my Comptech springs.
02civicsi is offline   Reply With Quote
Old 03-26-2008, 10:27 PM   #25 (permalink)
SIchodelic's Avatar
Nam
ifl. I got directed to this thread because my Comptech springs were making a popping noise. hopefully this will be the fix! thanks!!!
SIchodelic is offline   Reply With Quote
Old 04-02-2008, 02:03 PM   #26 (permalink)
SlicerDicer's Avatar
I'm planning on installing some Tein S-Tech springs on my Si, and am probably going to be using this (Thanks for posting). I'm a noob at this, but do I have to load the suspension with the cars weight before tightening?
And.....For the front, should I loosen the center nut on top of the strut assembly before taking it off or after?
I saw a novice basically break my friends strut because he took the whole assembly off, and couldn't get that center nut on top to turn. So he got a wrench and gripped it straight onto the piston rod (because it turned along with the top nut) which broke the seal when compressed again. I just didn't want to run into this problem, as I've heard of it happening.
Thanks in advance (oh yeah I plan on buying my sway bar setup from Redshift after this install is done).
SlicerDicer is offline   Reply With Quote
Old 04-02-2008, 07:11 PM   #27 (permalink)
SIchodelic's Avatar
Nam
loosen it while the strut is still on the car, or use a open socket with an allen key, or use an impact gun and just get it off. good luck!
Old 04-04-2008, 07:50 PM   #28 (permalink)
simons2k's Avatar
Simon
Okay, I know this question has come up several times and I'm getting different answers from different threads.
Will I need a camber kit if I just went with the Eibachs for a mild drop? Does someone know the definite answer?
simons2k is offline   Reply With Quote
Old 04-09-2008, 11:58 AM   #29 (permalink)
What size allen key is it? Also, just another question since you may know. what allen key size do I need to remove the rear stabilizer link?
Da2ndCivic is offline   Reply With Quote
Old 05-31-2008, 11:31 PM   #30 (permalink)
Rawhyde
Thanks for posting this thread! I just finished installing Si springs and shocks on my LX. It was an easy job thanks to good directions!
For removing the rear shocks and the top nuts on the front struts, a flex-head GearWrench is a real time saver.
Rawhyde
Rawhyde is offline   Reply With Quote
Old 08-13-2008, 03:03 PM   #31 (permalink)
truflip's Avatar
hello..
what torque value for this flange bolt?
i think its one of these but want to make sure :)
Rear upper arm (arm to body), 43.0
Rear upper arm (arm to hub), 80.0
truflip is offline   Reply With Quote
Old 08-26-2008, 06:00 AM   #32 (permalink)
g0chu's Avatar
Jae
wow, this DIY kicks arse
g0chu is offline   Reply With Quote
Old 10-05-2008, 12:09 AM   #33 (permalink)
TaI
TaI's Avatar
aaaannnnddd....bookmarked, thank you sir
TaI is offline   Reply With Quote
HFP Front Underbody Spoiler ONLY! iluvcivic Inside and Out 34 04-30-2008 05:12 AM
Front License plate kdb California North 9 09-21-2006 04:40 AM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 03:32 PM
2006 Civic Summary from Temple of VTEC shoptb Driving Experience 4 01-11-2006 03:40 AM
