Hi everyone from Russia, Moscow.
I have own my civic at November of 2006. And now i have a trouble with my brake discs. they was very warm and now it's looks like VERY DARK BLUE metal ![]() And when i'm braking from 100 mph i'm feeling some vibration and very bad sounds from my wheels. A have the 1.8 liters engine, 4dr sedan. What can i bye to remove my stock brake discs and pads without changing something, only front brake discs and pads? thanks a lot for your help!
You ruined your front rotors and pads most likely. Iron turns blue if it gets very hot.
New rotors, better brake pads and flushing your brake fluid and replacing it with the equivalent of DOT4 would be in order. Also, getting brakes that hot can and will damage the rubber dust seals on the calipers. |
Iron turns blue when its hot? I've only seem them go orange but whatever.
Russian friend, make sure its not the ABS kicking in, check to see if your wheels are balanced, make sure the rotors are not warped. Otherwise, you can buy and change just the brake disc and pads only
#6 (permalink) | |
#8 (permalink) | |
#10 (permalink) | |
Stephen "Vince" Carter
#11 (permalink) | |
![]() Its not warping really its pad transfer, for example if you drive hard and then stop at a light and hold down on the brakes pad material can transfer to the rotor causing a warped feeling. As for the parking brake it isn't suggested to use after heavy hard driving/braking. It can trap heat into the rear rotors, which can cause cracking and possible damage to rubber boots and hats. |
#12 (permalink) | ||
63.7% Bostonian.
. Si away for the winter ![]() Winter projects: - LED taillights (following in Nomar's footsteps) - two-tone seats - misc electrical stuff - audio overhaul - random powdercoating Quote:
#14 (permalink) | |
#15 (permalink) | |
Yes. Replace the disc, replace the pads and replace the fluid. Cast iron discs can withstand being that hot for a certain time, with proper break-in, but they can also stress crack and the best way to tell this is happening is if the surface has heat checking that looks like Japanese Raku pottery: ![]() High quality rotors + pads that can take 500 degrees C before they melt and smear over the face of the rotors, causing Disc Thickness Variation (DTV, aka "warpage"). You get the rotors and pads that hot and you'd be smart to pick better brake fluid and replace what you've gotten hot in the caliper piston. |
| Changing your brake pads | mtbiker278 | Do It Yourself Articles | 19 | 05-12-2007 04:53 PM |
| Brake Pads Wear: | PrivateTune | Suspension and Brakes | 3 | 02-08-2007 01:14 AM |
| Possible brake problem? | deelo83 | Mechanical Problems & Technical Chat | 3 | 07-21-2006 02:03 AM |
| Anyone with parking brake problems? | Silver06 | Garage | 7 | 12-16-2005 02:18 AM |
