Old 03-08-2008, 02:46 PM   #21 (permalink)
jjackowski's Avatar
Jeff Jackowski
(TOP RIGHT) Positive camber: The bottoms of the wheels are closer together than the tops. (TOP LEFT) Negative camber: The tops of the wheels are closer together than the bottoms.
Unless I'm completely confused (which has happened before, and will happen again), either the illustration or the text got right and left reversed. It is interesting, though, how I kept wanting the text to describe the image in the same direction that I read regardless what side the text said. Anyone else notice that?
Besides that one little detail, its a great post. I learned a lot. Thanks!
jjackowski is offline   Reply With Quote
Old 04-15-2008, 02:26 PM   #22 (permalink)
jdizzle37's Avatar
J.D.
Thank you so much for putting this together. This was extremely helpful and I applied a lot of this information in selecting my suspension setup. Can't wait to see the final results!
jdizzle37 is offline   Reply With Quote
Old 06-24-2008, 10:37 AM   #23 (permalink)
asndragonboii's Avatar
What does rear neg camber do? Our 06-07 civics come with something like 1.something degrees of neg camber. The TSB allows it to be fixed via new arms. I was not going to get it replaced because i was under the assumption that the neg camber will give me better handling or traction when i take turns fast. I like to use my brakes as little as possible so i take my turns a little fast. Am i right?
Old 06-24-2008, 11:08 AM   #24 (permalink)
jrotax101's Avatar
Robert
Neg camber generally results in more grip.
more neg camber in the rear than the front will cause understeer..
Next Project : E36 M3 boosted track car
fawk.. if my volks were hyperblack/formula silver.. my ballz would jump out and blow my pee pee
jrotax101 is offline   Reply With Quote
When To Use Camber Kits?/do I Need A Camber Kit? Highrev1 Suspension and Brakes 204 11-15-2008 08:38 PM
*8thCivic Tire Help 101* CrackThatTec45 Wheel And Tire Upgrades 52 10-30-2008 05:49 AM
Suspensions!!! Highrev1 Suspension and Brakes 243 10-22-2008 07:16 PM
