SI rear sway bar
Does anyone have a DIY article to install the 06 si rear sway bar on an 06 ex. I saw the article by 1493cc, but does not it does not seem to give the break down on installing it. I'm a newb to car machanics so a detailed DIY would be helpful,
Thanks. |
yes.. it fits
ex vs si ![]() well i have some pics of when i did it just need an allen key and attach it to the endlink like is show on the pic... and whit a wrench remove the bolt... ![]() ![]() the i just dremmeled the stock bushing... cus i dont order the Si bushings... and since im from mexico i was to lazzy to wait to order it... so thats the way i had dremmeled... btw i had read that the Si bushings and clamp doesnt fit the Ex holes right... (ill confirm that later, i just have it arrived) ![]() then just reinstall the new sway bar whit the dremmeled ex bushings and the stock ex clamps ![]() ![]() ![]() ![]() remember to use the allen tool!!! cus i just spend 1 hour trying to get out the bolt, then when i was to tired of unscrew it... i just saw that it need it too dumb lol hope this can help you |
#11 (permalink) | |
I just ordered the sway and bushings.. came out to 65 bucks.
- Mark 2008 Honda Civic SI (stock) 2006 Honda Civic EX (sold) |
#12 (permalink) | |
#13 (permalink) | |
#15 (permalink) |
well i get the sway bar and bushings tomorrow.. so i'll see what else i need.
I'm not sure if the SI brackets will bolt up to the EX's holes though. It might be spread apart more? If the brackets are too much money, i'll just return the bushings and drill the EX bushings to fit the SI sway.
#17 (permalink) |
Ok, i'm a new to this kinda stuff. unplugged, since you got the sway bar installed with the modified ex bushings, do you need the si bushings and brackets? Or did you order them as a precautionary measure? Do I need to order anything else but the sway bar?
#18 (permalink) | |
Installation took 10-15 minutes. Longest part was cleaning the threads on the end links to make removing the nuts quick and easy.
#19 (permalink) | |
any big difference? |
| *Installed* : Si 17mm Swaybar on Lx Sedan. | 1493cc | Suspension and Brakes | 48 | 03-12-2007 10:16 PM |
| rear speakers removed! now what? | tomasro | I.C.E., Electrical, Security, & Navigation | 17 | 08-01-2006 09:57 AM |
| 2006 Civic Summary from Temple of VTEC | shoptb | Driving Experience | 4 | 01-11-2006 02:40 AM |
| 2006 Civic sedan rear window | clm10k | Civic Coupe And Sedan | 5 | 01-07-2006 03:23 PM |
| Rear Speaker Install Guide | brolewis | I.C.E., Electrical, Security, & Navigation | 7 | 12-28-2005 11:53 PM |
