Old 05-10-2006, 12:11 AM   #41 (permalink)
Kurt's Avatar
They called to tell me some part(s?) were on backorder last week. I hope I get it soon
Kurt is offline   Reply With Quote
Old 05-14-2006, 11:10 AM   #42 (permalink)
Moderator
iluvmycsx's Avatar
Originally Posted by lbjgh
I assume the SI rear anti sway bar will bolt onto an Acura CSX?
yes it will the csx and civic uses the same kind of suspension i am doing this mod on my csx this weekend
got mine saturday here is a pic of the difference
My Ride
Toys 4 Tots 2008
iluvmycsx is offline   Reply With Quote
Old 05-14-2006, 11:18 AM   #43 (permalink)
iluvmyel, I saw your post on the other forum. I hope you provide lots of pics and your driving impressions. I'm gonna do the same on my wife's car too...
lbjgh is offline   Reply With Quote
Old 05-14-2006, 01:26 PM   #44 (permalink)
unplugged's Avatar
Originally Posted by CivicWithNav
I just got mine installed and DAYAM is all i gotta say. Handles 10x better but car still plows in a hard turn...typical FWD
I agree 100%
- Mark
2008 Honda Civic SI (stock)
2006 Honda Civic EX (sold)
unplugged is offline   Reply With Quote
Old 05-14-2006, 06:50 PM   #45 (permalink)
iVTEC's Avatar
When installing the sway bar, do you need to put grease between the sway bar and the bushings? If so, what's the best kind?
I recall having to do that with my RSX when I used polyurethane bushings. The OEM bushings, however, are made of rubber.
Thanks!
iVTEC is offline   Reply With Quote
Old 05-14-2006, 06:58 PM   #46 (permalink)
Kurt's Avatar
I ordered mine 4/30, still haven't gotten it
Old 05-14-2006, 10:30 PM   #47 (permalink)
Took you guys long enough to start doing this.
I was so much happier after I installed the Si bar on my Lx a while back.
1493cc is offline   Reply With Quote
Old 05-15-2006, 04:07 PM   #48 (permalink)
unplugged's Avatar
Thanks!
for oem bushings, i have never greased them. I don't think there is a need either.
- Mark
Old 05-17-2006, 04:26 PM   #49 (permalink)
iVTEC's Avatar
I ordered mine on 4/28. I received the sway bar, bushings and brackets on 5/11 but the holders are on back order. So I can't install it yet. No word on when they'll come in.
Old 05-17-2006, 11:28 PM   #50 (permalink)
So this swaybar from the Si coupe fits the EX sedan?
yacoub is offline   Reply With Quote
Old 05-18-2006, 10:25 AM   #51 (permalink)
yacoub - Yes it does just make sure that you get the brackets, bushings, etc.
I will be installing mine this weekend!
tegrady is offline   Reply With Quote
Old 05-21-2006, 03:04 PM   #52 (permalink)
Kurt's Avatar
got my stuff yesterday, installing it today!! I'll take pics :)
Old 05-21-2006, 03:22 PM   #53 (permalink)
Just finished about an hour ago. Fairly easy install, definately needed the brackets, bushings, and the bolts for the bushings.
I took it for a quick test ride, and it feels noticeably stiffer in the back.
Old 05-21-2006, 03:30 PM   #54 (permalink)
Kurt's Avatar
how long did it take you to do?
Old 05-21-2006, 07:52 PM   #55 (permalink)
Kurt's Avatar
wow that was a BITCH.
getting those screws off was next to impossible.
Old 05-21-2006, 08:34 PM   #56 (permalink)
Kurt, it only took about an hour and half. The endlink screws were a bitch until I figured out you had to stick an allen wrench in the end and hold it to loosen the bolts.
Old 05-21-2006, 11:07 PM   #57 (permalink)
Kurt's Avatar
I had the allen wrench in there and it was still very very hard. Those screws were on SOOO tight. I was using some lube, and while it helped, it took all my strength to get them off. It wasn't even like where you loosen it a little then it gets a ton easier... mine was a bitch the entire thread of the bolt!
But the end product was worth it. Car handles very noticeably better; best 65 dollars I've spent so far.
Old 05-22-2006, 10:29 AM   #58 (permalink)
Mine weren't easy either, it took some effort all the way down the threads.
I agree, it's a very good "bang for the buck" upgrade.
Old 05-22-2006, 02:25 PM   #59 (permalink)
Kurt's Avatar
man, this is one awesome upgrade. i can cut so much faster now and the car is just so 'together', unlike before. absolutely love it.
Old 05-22-2006, 09:31 PM   #60 (permalink)
you guys are exciting me. i ordered the parts. i hope it's noticeable improvement! =)
*Installed* : Si 17mm Swaybar on Lx Sedan. 1493cc Suspension and Brakes 48 03-12-2007 11:16 PM
rear speakers removed! now what? tomasro I.C.E., Electrical, Security, & Navigation 17 08-01-2006 10:57 AM
2006 Civic Summary from Temple of VTEC shoptb Driving Experience 4 01-11-2006 03:40 AM
2006 Civic sedan rear window clm10k Civic Coupe And Sedan 5 01-07-2006 04:23 PM
Rear Speaker Install Guide brolewis I.C.E., Electrical, Security, & Navigation 7 12-29-2005 12:53 AM
