Old 04-23-2006, 03:57 PM   #21 (permalink)
iVTEC's Avatar
Originally Posted by el_ben2
yes.. it fits
ex vs si
remember to use the allen tool!!!
cus i just spend 1 hour trying to get out the bolt, then when i was to tired of unscrew it... i just saw that it need it
too dumb
lol
hope this can help you
Did you have to jack up the car to install the sway bar or were all four wheels on the ground?
Thanks
iVTEC is offline   Reply With Quote
Old 04-23-2006, 07:12 PM   #22 (permalink)
el_ben2's Avatar
i had jacked it up... since i had the tein installed... and it wasnt room to work down there
el_ben2 is offline   Reply With Quote
Old 04-23-2006, 09:57 PM   #23 (permalink)
unplugged's Avatar
Originally Posted by 06civicsilver
any big difference?
its definitely noticeable and great for just a regular daily/spirited driver. If you do auto-x, you might want something more.
- Mark
2008 Honda Civic SI (stock)
2006 Honda Civic EX (sold)
unplugged is offline   Reply With Quote
Old 04-23-2006, 09:57 PM   #24 (permalink)
unplugged's Avatar
Originally Posted by CivicWithNav
you need every part except the bolt and nuts
Bracket where the bushing bolts on to is wider on the SI's(this bracket is bolted onto the body)
or modify the bushings.
- Mark
Old 04-23-2006, 10:03 PM   #25 (permalink)
CivicWithNav's Avatar
im trying to do it right
and it's less of a pain to change the bracket than trying to grind the bushing down and having fitment issues(irregularity)
for allll parts, it only cost me $50 inc. taxes
Old 04-24-2006, 10:36 AM   #26 (permalink)
unplugged's Avatar
yeah i know its cheap. i actually bought the brackets too, except one is on backorder until the end of next week.
- Mark
Old 04-27-2006, 11:53 AM   #27 (permalink)
where did you order the sway bar from?
06civicsilver is offline   Reply With Quote
Old 04-27-2006, 06:08 PM   #28 (permalink)
Tim
Super Moderator
Tim's Avatar
I had read somewhere (perhaps on vtec.net) that Si's may actually handle better with the EX rear sway bar. I can't remember exactly. Anyone heard anything to this effect?
Tim is offline   Reply With Quote
Old 04-29-2006, 01:12 AM   #29 (permalink)
Moderator
iluvmycsx's Avatar
try www.hondapartsdeals.com or try you local dealership
i just bought a si rear sway bar for my csx got it for $70 cad with the bushings from the local dealership.
My Ride
Toys 4 Tots 2008
iluvmycsx is offline   Reply With Quote
Old 04-29-2006, 11:44 AM   #30 (permalink)
Wink newb
what all do i need to order? what are the item numbers for the sway bar, the brackets, and bushings? the diagram is to confusing for me when i don't know what i am doing!!!
Old 04-29-2006, 01:23 PM   #31 (permalink)
iVTEC's Avatar
https://www.hondapartsdeals.com/hond...omponent=B++29
Order:
010 (spring, RR. stabilizer) = sway bar ---> order one
011 (bush, stabilizer holder) = bushing/holder for sway bar ---> order two
012 (holder, stabilizer bush) = metal holder to hold bushing and sway bar in place ---> order two
013 (bracket, R. RR stabilizer) = bracket to hold sway bar and hardware onto the car, needed because the EX bracket won't fit the Si hardware ---> order one
014 (L. RR stabilizer) = same as 013 but for the left side ---> order one
Don't quote me, but I think that you can use the old EX bolts, etc to mount the actual hardware onto the car. At least I'll find out when I get my own sway bar. Just ordered it last night!
EDIT: Upon a closer look at the diagram, comparing the EX to the Si, I think that you must also order four 10 x 20 mm bolt-washers (item 039 - bolt washer 10x 20). The EX uses a smaller size than the Si for this bolt. My guess is that the Si holders are bigger than the EX holders. DANG! Now I have to change my order!
Old 04-29-2006, 01:40 PM   #32 (permalink)
unplugged's Avatar
Order:
bolts work fine
- Mark
Old 04-29-2006, 01:41 PM   #33 (permalink)
unplugged's Avatar
there's been a national back order on some SI parts especially pertaining to the sway bar.. i'm wondering if all these people buying them have anything to do with it...lol
- Mark
Old 04-29-2006, 01:50 PM   #34 (permalink)
iVTEC's Avatar
Originally Posted by unplugged
bolts work fine
Oh, okay. Cool.
Old 04-30-2006, 09:45 AM   #35 (permalink)
Talking
Order:
thanks it was bought saturday night!!! thats all i needed! NOW I NEED SI RIMS!
Old 04-30-2006, 02:35 PM   #36 (permalink)
iVTEC's Avatar
You're welcome.
I'm looking forward to the new bar. When I put a bigger rear sway in my old RSX, I immediately noticed a much more solid, planted feeling in the turns.
Old 04-30-2006, 11:28 PM   #37 (permalink)
Kurt's Avatar
just ordered it :)
Kurt is offline   Reply With Quote
Old 05-02-2006, 08:44 PM   #38 (permalink)
make sure they order the right brackets...they sent 3 WRONG ones(same ones) so i had to wait like 2 weeks for it
I just got mine installed and DAYAM is all i gotta say. Handles 10x better but car still plows in a hard turn...typical FWD
I even have SI's Michelin tires but they just don't cut it... next summer come Stickier tires :)
Old 05-03-2006, 07:29 PM   #39 (permalink)
Just ordered mine also
1zach4 is offline   Reply With Quote
Old 05-09-2006, 11:57 PM   #40 (permalink)
I assume the SI rear anti sway bar will bolt onto an Acura CSX?
lbjgh is offline   Reply With Quote
*Installed* : Si 17mm Swaybar on Lx Sedan. 1493cc Suspension and Brakes 48 03-12-2007 11:16 PM
rear speakers removed! now what? tomasro I.C.E., Electrical, Security, & Navigation 17 08-01-2006 10:57 AM
2006 Civic Summary from Temple of VTEC shoptb Driving Experience 4 01-11-2006 03:40 AM
2006 Civic sedan rear window clm10k Civic Coupe And Sedan 5 01-07-2006 04:23 PM
Rear Speaker Install Guide brolewis I.C.E., Electrical, Security, & Navigation 7 12-29-2005 12:53 AM
